pqStandardPropertyWidgetInterface provides a concrete implementation of pqPropertyWidget used by ParaView application. More...
#include <pqStandardPropertyWidgetInterface.h>
| pqStandardPropertyWidgetInterface (QObject *p=nullptr) | |
| ~pqStandardPropertyWidgetInterface () override | |
| pqPropertyWidget * | createWidgetForProperty (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parentWidget) override |
| Given a proxy and its property, create a widget for the same, if possible. More... | |
| pqPropertyWidget * | createWidgetForPropertyGroup (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parentWidget) override |
| Given a proxy and its property group, create a widget for the same, of possible. More... | |
| pqPropertyWidgetDecorator * | createWidgetDecorator (const QString &type, vtkPVXMLElement *config, pqPropertyWidget *widget) override |
| Given the type of the decorator and the pqPropertyWidget that needs to be decorated, create the pqPropertyWidgetDecorator instance, if possible. More... | |
| void | createDefaultWidgetDecorators (pqPropertyWidget *widget) override |
| Create all default decorators for a specific widget. More... | |
Public Member Functions inherited from pqPropertyWidgetInterface | |
| virtual | ~pqPropertyWidgetInterface () |
It adds logic to create some of the custom widgets and decorators used by ParaView's Properties Panel.
Definition at line 15 of file pqStandardPropertyWidgetInterface.h.
| pqStandardPropertyWidgetInterface::pqStandardPropertyWidgetInterface | ( | QObject * | p = nullptr | ) |
For unsupported/unknown proxies/properties, implementations should simply return nullptr without raising any errors (or messages). Supported types are:
calculator : pqCalculatorWidget camera_manipulator : pqCameraManipulatorWidget color_palette_selector : pqColorPaletteSelectorWidget color_selector : pqColorSelectorPropertyWidget color_selector_with_palette : pqColorSelectorPropertyWidget with palette menu command_button : pqCommandButtonPropertyWidget display_representation_selector : pqDisplayRepresentationPropertyWidget double_range : pqDoubleRangeSliderPropertyWidget filename_widget: pqFileNamePropertyWidget glyph_scale_factor: pqGlyphScaleFactorPropertyWidget image_compressor_config : pqImageCompressorWidget index_selection : pqIndexSelectionWidget input_selector : pqInputSelectorWidget int_mask: pqIntMaskPropertyWidget list : pqListPropertyWidget proxy_editor: pqProxyEditorPropertyWidget texture_selector : pqTextureSelectorPropertyWidget transfer_function_editor : pqTransferFunctionWidgetPropertyWidget viewtype_selector: pqViewTypePropertyWidget language_selector: pqLanguageChooserWidget view_resolution: pqViewResolutionPropertyWidget pause_livesource: pqPauseLiveSourcePropertyWidget data_assembly_editor: pqDataAssemblyPropertyWidget selection_query : pqSelectionQueryPropertyWidget file_list : pqFileListPropertyWidget xy_chart_bounds : pqXYChartViewBoundsPropertyWidget Reimplemented from pqPropertyWidgetInterface.
For unsupported/unknown proxies/property-groups, implementations should simply return nullptr without raising any errors (or messages). Supported types are:
AnnotationsEditor : pqColorAnnotationsPropertyWidget ArrayStatus : pqArrayStatusPropertyWidget BackgroundEditor : pqBackgroundPropertyWidget ColorEditor : pqColorEditorPropertyWidget ColorOpacityEditor : pqColorOpacityEditorWidget FontEditor : pqFontPropertyWidget SeriesEditor : pqSeriesEditorPropertyWidget InteractivePlane : pqDisplaySizedImplicitPlanePropertyWidget InteractivePlane2 : pqImplicitPlanePropertyWidget InteractiveBox: pqBoxPropertyWidget InteractiveHandle: pqHandlePropertyWidget InteractiveLine: pqLinePropertyWidget InteractiveSpline: pqSplinePropertyWidget InteractiveSphere: pqSpherePropertyWidget InteractivePolyLine: pqSplinePropertyWidget (with mode==POLYLINE) InteractiveCylinder: pqCylinderPropertyWidget YoungsMaterial: pqYoungsMaterialPropertyWidget OMETransferFunctions : pqOMETransferFunctionsPropertyWidget PropertyCollection : pqPropertyCollectionWidget DataAssemblyEditor: pqDataAssemblyPropertyWidget CheckableProperty : pqCheckableProperty EqualizerPropertyWidget : pqEqualizerPropertyWidget MetaDataPropertyWidget : pqMetaDataPropertyWidget Reimplemented from pqPropertyWidgetInterface.
For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). Supported types are:
CTHArraySelectionDecorator : pqCTHArraySelectionDecorator EnableWidgetDecorator : pqEnableWidgetDecorator ShowWidgetDecorator : pqShowWidgetDecorator InputDataTypeDecorator : pqInputDataTypeDecorator GenericDecorator: pqGenericPropertyWidgetDecorator OSPRayHidingDecorator: pqOSPRayHidingDecorator MultiComponentsDecorator: pqMultiComponentsDecorator CompositeDecorator: pqCompositePropertyWidgetDecorator SessionTypeDecorator: pqSessionTypeDecorator Reimplemented from pqPropertyWidgetInterface.
Created decorators are:
AnimationShortcutDecorator : pqAnimationShortcutDecorator Reimplemented from pqPropertyWidgetInterface.
