Public Slots | Signals | Public Member Functions | Properties | List of all members
pqInputSelectorWidget Class Reference
widget for input property to choose a pipeline input. More...
#include <pqInputSelectorWidget.h>
Inheritance diagram for pqInputSelectorWidget:
Collaboration diagram for pqInputSelectorWidget:
Public Slots
void setSelectedInput (pqSMProxy)
Signals
void selectedInputChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqInputSelectorWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqInputSelectorWidget () override
pqSMProxy selectedInput () const
 Chosen port. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Generally, pqProxyWidget does not show widget for input properties. This is by design since changing input to filters is generally not a thing we let the user treat at same level as changing other properties. In some cases, however, we may want to show a combo-box to let user pick the input from the available pipeline proxies. pqInputSelectorWidget is designed for such exceptional cases. To use this widget for a vtkSMInputProperty, set panel_widget attribute to input_selector.
Definition at line 29 of file pqInputSelectorWidget.h.
◆ pqInputSelectorWidget()
pqInputSelectorWidget::pqInputSelectorWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqInputSelectorWidget()
pqInputSelectorWidget::~pqInputSelectorWidget ( )
override
◆ selectedInput()
pqSMProxy pqInputSelectorWidget::selectedInput ( ) const
Chosen port.
This returns vtkSmartPointer<vtkSMOutputPort> for the chosen port. if any.
◆ setSelectedInput
void pqInputSelectorWidget::setSelectedInput ( pqSMProxy  )
slot
◆ selectedInputChanged
void pqInputSelectorWidget::selectedInputChanged ( )
signal
Property Documentation
◆ selectedInput
readwrite
Definition at line 33 of file pqInputSelectorWidget.h.
