Public Member Functions | Friends | List of all members
pqArrayStatusPropertyWidget Class Reference
#include <pqArrayStatusPropertyWidget.h>
Inheritance diagram for pqArrayStatusPropertyWidget:
Collaboration diagram for pqArrayStatusPropertyWidget:
 pqArrayStatusPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parent=nullptr)
 pqArrayStatusPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqArrayStatusPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Friends
class pqInternals
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 14 of file pqArrayStatusPropertyWidget.h.
◆ pqArrayStatusPropertyWidget() [1/2]
pqArrayStatusPropertyWidget::pqArrayStatusPropertyWidget ( vtkSMProxy *  proxy,
vtkSMPropertyGroup *  group,
QWidget *  parent = nullptr
◆ pqArrayStatusPropertyWidget() [2/2]
vtkSMProperty *  property,
◆ ~pqArrayStatusPropertyWidget()
pqArrayStatusPropertyWidget::~pqArrayStatusPropertyWidget ( )
override
◆ pqInternals
friend class pqInternals
friend
Definition at line 31 of file pqArrayStatusPropertyWidget.h.
