Public Slots | Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqProxyEditorPropertyWidget Class Reference
Property widget that can be used to edit a proxy set as the value of a ProxyProperty in a pop-up dialog. More...
#include <pqProxyEditorPropertyWidget.h>
Inheritance diagram for pqProxyEditorPropertyWidget:
Collaboration diagram for pqProxyEditorPropertyWidget:
Public Slots
void setProxyToEdit (pqSMProxy)
Signals
void dummySignal ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqProxyEditorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqProxyEditorPropertyWidget () override
pqSMProxy proxyToEdit () const
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void buttonClicked ()
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
e.g. RenderView proxy has a "GridActor3D" ProxyProperty which is set to a "GridActor3D" proxy. Using this widget allows the users to edit the properties on this GridActor3D, when present.
To use this widget, add 'panel_widget="proxy_editor"' to the property's XML.
Since it's common to have a property on the proxy being edited in the popup dialog which controls its visibility (or enabled state), we add support for putting that property as a checkbox in this pqProxyEditorPropertyWidget itself. For that, one can use ProxyEditorPropertyWidget hints.
Example XML:
<ProxyProperty name="AxesGrid" ... >
<ProxyListDomain name="proxy_list">
<Proxy group="annotations" name="GridAxes3DActor" />
</ProxyListDomain>
<Hints>
<ProxyEditorPropertyWidget property="Visibility" />
</Hints>
</ProxyProperty>
Definition at line 40 of file pqProxyEditorPropertyWidget.h.
◆ pqProxyEditorPropertyWidget()
pqProxyEditorPropertyWidget::pqProxyEditorPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqProxyEditorPropertyWidget()
pqProxyEditorPropertyWidget::~pqProxyEditorPropertyWidget ( )
override
◆ proxyToEdit()
pqSMProxy pqProxyEditorPropertyWidget::proxyToEdit ( ) const
◆ setProxyToEdit
void pqProxyEditorPropertyWidget::setProxyToEdit ( pqSMProxy  )
slot
◆ buttonClicked
void pqProxyEditorPropertyWidget::buttonClicked ( )
protectedslot
◆ dummySignal
void pqProxyEditorPropertyWidget::dummySignal ( )
signal
Property Documentation
◆ proxyToEdit
readwrite
Definition at line 44 of file pqProxyEditorPropertyWidget.h.
name
name
