Signals | Public Member Functions | Public Attributes | Protected Slots | Protected Member Functions | List of all members
pqTransferFunctionWidgetPropertyWidget Class Reference
A property widget for editing a transfer function. More...
#include <pqTransferFunctionWidgetPropertyWidget.h>
Inheritance diagram for pqTransferFunctionWidgetPropertyWidget:
Collaboration diagram for pqTransferFunctionWidgetPropertyWidget:
Signals
void domainChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqTransferFunctionWidgetPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqTransferFunctionWidgetPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Public Attributes
friend pqTransferFunctionWidgetPropertyDialog
Protected Slots
void editButtonClicked ()
void propagateProxyPointsProperty ()
void resetRangeToDomainDefault ()
void updateRange ()
 Update widget with transfer function proxy value. More...
void onRangeEdited ()
 Update transfer function proxy from widgets. More...
void UpdateProperty ()
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
template<class T >
To use this widget for a property add the 'panel_widget="transfer_function_editor"' to the property's XML.
Definition at line 20 of file pqTransferFunctionWidgetPropertyWidget.h.
◆ pqTransferFunctionWidgetPropertyWidget()
pqTransferFunctionWidgetPropertyWidget::pqTransferFunctionWidgetPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
explicit
◆ ~pqTransferFunctionWidgetPropertyWidget()
pqTransferFunctionWidgetPropertyWidget::~pqTransferFunctionWidgetPropertyWidget ( )
override
◆ domainChanged
void pqTransferFunctionWidgetPropertyWidget::domainChanged ( )
signal
◆ UpdateProperty()
void pqTransferFunctionWidgetPropertyWidget::UpdateProperty ( )
◆ editButtonClicked
void pqTransferFunctionWidgetPropertyWidget::editButtonClicked ( )
protectedslot
◆ propagateProxyPointsProperty
void pqTransferFunctionWidgetPropertyWidget::propagateProxyPointsProperty ( )
protectedslot
◆ resetRangeToDomainDefault
void pqTransferFunctionWidgetPropertyWidget::resetRangeToDomainDefault ( )
protectedslot
◆ updateRange
void pqTransferFunctionWidgetPropertyWidget::updateRange ( )
protectedslot
◆ onRangeEdited
void pqTransferFunctionWidgetPropertyWidget::onRangeEdited ( )
protectedslot
◆ pqTransferFunctionWidgetPropertyDialog
friend pqTransferFunctionWidgetPropertyWidget::pqTransferFunctionWidgetPropertyDialog
Definition at line 30 of file pqTransferFunctionWidgetPropertyWidget.h.
