vtkPVXMLElement Class Reference
#include <vtkPVXMLElement.h>
Inheritance diagram for vtkPVXMLElement:
Collaboration diagram for vtkPVXMLElement:
const char * GetAttribute (const char *name)
 Get the attribute with the given name. More...
const char * GetAttributeOrEmpty (const char *name)
const char * GetAttributeOrDefault (const char *name, const char *notFound)
const char * GetCharacterData ()
 Get the character data for the element. More...
vtkPVXMLElement * GetParent ()
 Get the parent of this element. More...
unsigned int GetNumberOfNestedElements ()
 Get the number of elements nested in this one. More...
vtkPVXMLElement * GetNestedElement (unsigned int index)
 Get the element nested in this one at the given index. More...
vtkPVXMLElement * FindNestedElement (const char *id)
 Find a nested element with the given id. More...
vtkPVXMLElement * FindNestedElementByName (const char *name)
 Locate a nested element with the given tag name. More...
void FindNestedElementByName (const char *name, vtkCollection *elements)
 Locate a set of nested elements with the given tag name. More...
void RemoveAllNestedElements ()
 Removes all nested elements. More...
void RemoveNestedElement (vtkPVXMLElement *)
 Remove a particular element. More...
void ReplaceNestedElement (vtkPVXMLElement *elementToReplace, vtkPVXMLElement *element)
 Replace a particular element with another. More...
vtkPVXMLElement * LookupElement (const char *id)
 Lookup the element with the given id, starting at this scope. More...
void RemoveAttribute (const char *attrName)
 Remove the attribute from the current element. More...
void SetAttribute (const char *attrName, const char *attrValue)
 Given it's name and value, set an attribute. More...
void Merge (vtkPVXMLElement *element, const char *attributeName)
 Merges another element with this one, both having the same name. More...
bool Equals (vtkPVXMLElement *other)
 Return true if the current object has the same content as the other. More...
void CopyTo (vtkPVXMLElement *other)
 Copy the current XML element content into the provided one. More...
void CopyAttributesTo (vtkPVXMLElement *other)
 Copy the attributes from current XML element content into the provided one. More...
 Set/Get the name of the element. More...
virtual char * GetName ()
virtual char * GetId ()
 Get the id of the element. More...
int GetScalarAttribute (const char *name, int *value)
 Get the attribute with the given name converted to a scalar value. More...
int GetScalarAttribute (const char *name, float *value)
int GetScalarAttribute (const char *name, double *value)
int GetVectorAttribute (const char *name, int length, int *value)
int GetVectorAttribute (const char *name, int length, float *value)
int GetVectorAttribute (const char *name, int length, double *value)
int GetCharacterDataAsVector (int length, int *value)
 Get the character data converted to a scalar value. More...
int GetCharacterDataAsVector (int length, float *value)
int GetCharacterDataAsVector (int length, double *value)
void AddAttribute (const char *attrName, const char *attrValue)
 Given it's name and value, add an attribute. More...
void AddAttribute (const char *attrName, unsigned int attrValue)
void AddAttribute (const char *attrName, double attrValue)
void AddAttribute (const char *attrName, double attrValue, int precision)
void AddAttribute (const char *attrName, int attrValue)
void AddNestedElement (vtkPVXMLElement *element, int setPrent)
 Add a sub-element. More...
void AddNestedElement (vtkPVXMLElement *element)
void PrintXML (ostream &os, vtkIndent indent)
 Serialize (as XML) in the given stream. More...
void PrintXML ()
void GetElementsByName (const char *name, vtkCollection *elements)
 Similar to DOM specific getElementsByTagName(). More...
void GetElementsByName (const char *name, vtkCollection *elements, bool recursively)
static vtkPVXMLElement * SafeDownCast (vtkObject *o)
static vtkPVXMLElement * New ()
static std::string Encode (const char *plaintext)
 Encode a string. More...
 vtkPVXMLElement ()
 ~vtkPVXMLElement () override
virtual void SetId (const char *)
void ReadXMLAttributes (const char **atts)
void AddCharacterData (const char *data, int length)
vtkPVXMLElement * LookupElementInScope (const char *id)
vtkPVXMLElement * LookupElementUpScope (const char *id)
void SetParent (vtkPVXMLElement *parent)
vtkPVXMLElementInternals * Internal
char * Name
char * Id
vtkPVXMLElement * Parent
Friends
class vtkPVXMLParser
Definition at line 23 of file vtkPVXMLElement.h.
Definition at line 26 of file vtkPVXMLElement.h.
◆ vtkPVXMLElement()
vtkPVXMLElement::vtkPVXMLElement ( )
◆ ~vtkPVXMLElement()
vtkPVXMLElement::~vtkPVXMLElement ( )
virtual const char* vtkPVXMLElement::GetClassName ( )
static int vtkPVXMLElement::IsTypeOf ( const char *  type)
virtual int vtkPVXMLElement::IsA ( const char *  type)
static vtkPVXMLElement* vtkPVXMLElement::SafeDownCast ( vtkObject *  o)
void vtkPVXMLElement::PrintSelf ( ostream &  os,
static vtkPVXMLElement* vtkPVXMLElement::New ( )
◆ SetName()
virtual void vtkPVXMLElement::SetName ( const char *  )
This is its XML tag. (<Name/>).
◆ GetName()
virtual char* vtkPVXMLElement::GetName ( )
◆ GetId()
virtual char* vtkPVXMLElement::GetId ( )
This is assigned by the XML parser and can be used as an identifier to an element.
◆ GetAttribute()
const char* vtkPVXMLElement::GetAttribute ( const char *  name)
inline
If it doesn't exist, returns nullptr.
Definition at line 51 of file vtkPVXMLElement.h.
◆ GetAttributeOrEmpty()
const char* vtkPVXMLElement::GetAttributeOrEmpty ( const char *  name)
inline
If it doesn't exist, returns "".
Definition at line 57 of file vtkPVXMLElement.h.
◆ GetAttributeOrDefault()
const char* vtkPVXMLElement::GetAttributeOrDefault ( const char *  name,
const char *  notFound
If it doesn't exist, returns the provided notFound value.
◆ GetCharacterData()
const char* vtkPVXMLElement::GetCharacterData ( )
◆ GetScalarAttribute() [1/3]
int vtkPVXMLElement::GetScalarAttribute ( const char *  name,
int *  value
Returns 1 if a value was extracted.
◆ GetScalarAttribute() [2/3]
float *  value
◆ GetScalarAttribute() [3/3]
double *  value
◆ GetVectorAttribute() [1/3]
int vtkPVXMLElement::GetVectorAttribute ( const char *  name,
int  length,
int *  value
Returns length of vector read.
◆ GetVectorAttribute() [2/3]
int  length,
float *  value
◆ GetVectorAttribute() [3/3]
int  length,
double *  value
◆ GetCharacterDataAsVector() [1/3]
int vtkPVXMLElement::GetCharacterDataAsVector ( int  length,
int *  value
◆ GetCharacterDataAsVector() [2/3]
float *  value
◆ GetCharacterDataAsVector() [3/3]
double *  value
◆ GetParent()
vtkPVXMLElement* vtkPVXMLElement::GetParent ( )
◆ GetNumberOfNestedElements()
unsigned int vtkPVXMLElement::GetNumberOfNestedElements ( )
◆ GetNestedElement()
vtkPVXMLElement* vtkPVXMLElement::GetNestedElement ( unsigned int  index)
◆ FindNestedElement()
vtkPVXMLElement* vtkPVXMLElement::FindNestedElement ( const char *  id)
Not that this searches only the immediate children of this vtkPVXMLElement.
◆ FindNestedElementByName() [1/2]
vtkPVXMLElement* vtkPVXMLElement::FindNestedElementByName ( const char *  name)
◆ FindNestedElementByName() [2/2]
void vtkPVXMLElement::FindNestedElementByName ( const char *  name,
vtkCollection *  elements
◆ RemoveAllNestedElements()
void vtkPVXMLElement::RemoveAllNestedElements ( )
◆ RemoveNestedElement()
void vtkPVXMLElement::RemoveNestedElement ( vtkPVXMLElement *  )
◆ ReplaceNestedElement()
void vtkPVXMLElement::ReplaceNestedElement ( vtkPVXMLElement *  elementToReplace,
◆ LookupElement()
vtkPVXMLElement* vtkPVXMLElement::LookupElement ( const char *  id)
◆ AddAttribute() [1/5]
void vtkPVXMLElement::AddAttribute ( const char *  attrName,
const char *  attrValue
◆ AddAttribute() [2/5]
◆ AddAttribute() [3/5]
double  attrValue
◆ AddAttribute() [4/5]
double  attrValue,
int  precision
◆ AddAttribute() [5/5]
int  attrValue
◆ RemoveAttribute()
void vtkPVXMLElement::RemoveAttribute ( const char *  attrName)
◆ SetAttribute()
void vtkPVXMLElement::SetAttribute ( const char *  attrName,
If an attribute with the given name already exists, it replaces the old attribute. chars that need to be XML escaped will be done so internally for example " will be converted to "
◆ AddNestedElement() [1/2]
void vtkPVXMLElement::AddNestedElement ( vtkPVXMLElement *  element,
int  setPrent
Add a sub-element.
The parent element keeps a reference to sub-element. If setParent is true, the nested element's parent is set as this.
◆ AddNestedElement() [2/2]
void vtkPVXMLElement::AddNestedElement ( vtkPVXMLElement *  element)
Add a sub-element.
◆ PrintXML() [1/2]
void vtkPVXMLElement::PrintXML ( ostream &  os,
◆ PrintXML() [2/2]
void vtkPVXMLElement::PrintXML ( )
◆ Merge()
void vtkPVXMLElement::Merge ( vtkPVXMLElement *  element,
const char *  attributeName
If any attribute, character data or nested element exists in both, the passed in one will override this one's. If they don't exist, they'll be added. If nested elements have the same names, the optional attributeName maybe passed in as another criteria to determine what to merge in case of same names.
◆ GetElementsByName() [1/2]
void vtkPVXMLElement::GetElementsByName ( const char *  name,
Returns a list of vtkPVXMLElements with the given name in the order in which they will be encountered in a preorder traversal of the sub-tree under this node. The elements are populated in the vtkCollection passed as an argument.
◆ GetElementsByName() [2/2]
vtkCollection *  elements,
bool  recursively
◆ Encode()
static std::string vtkPVXMLElement::Encode ( const char *  plaintext)
Encode a string.
◆ Equals()
bool vtkPVXMLElement::Equals ( vtkPVXMLElement *  other)
The comparison implementation is pretty weak in the mean that we compare resulting XML string.
◆ CopyTo()
void vtkPVXMLElement::CopyTo ( vtkPVXMLElement *  other)
◆ CopyAttributesTo()
void vtkPVXMLElement::CopyAttributesTo ( vtkPVXMLElement *  other)
◆ SetId()
virtual void vtkPVXMLElement::SetId ( const char *  )
protectedvirtual
◆ ReadXMLAttributes()
void vtkPVXMLElement::ReadXMLAttributes ( const char **  atts)
◆ AddCharacterData()
void vtkPVXMLElement::AddCharacterData ( const char *  data,
int  length
◆ LookupElementInScope()
vtkPVXMLElement* vtkPVXMLElement::LookupElementInScope ( const char *  id)
◆ LookupElementUpScope()
vtkPVXMLElement* vtkPVXMLElement::LookupElementUpScope ( const char *  id)
◆ SetParent()
void vtkPVXMLElement::SetParent ( vtkPVXMLElement *  parent)
◆ vtkPVXMLParser
friend class vtkPVXMLParser
friend
Definition at line 276 of file vtkPVXMLElement.h.
◆ Internal
vtkPVXMLElementInternals* vtkPVXMLElement::Internal
Definition at line 258 of file vtkPVXMLElement.h.
◆ Name
char* vtkPVXMLElement::Name
Definition at line 260 of file vtkPVXMLElement.h.
◆ Id
char* vtkPVXMLElement::Id
Definition at line 261 of file vtkPVXMLElement.h.
◆ Parent
vtkPVXMLElement* vtkPVXMLElement::Parent
Definition at line 264 of file vtkPVXMLElement.h.
