vtkSMProperty Class Reference
superclass for all SM properties More...
#include <vtkSMProperty.h>
Inheritance diagram for vtkSMProperty:
Collaboration diagram for vtkSMProperty:
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
virtual void Copy (vtkSMProperty *src)
 Copy all property values. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual void ResetToXMLDefaults ()
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
virtual bool ResetToDomainDefaults (bool use_unchecked_values=false)
 Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
virtual bool IsValueDefault ()
 Returns true if the property's value is different from the default value. More...
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
virtual void ClearUncheckedElements ()
 Use this method to clear unchecked values set of this property. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Use vtkSMObject::CreatePrettyLabel(const std::string& name) instead.") static const char *CreateNewPrettyLabel(const char *name)
 Given the string, this method will create and set a well-formated string as XMLLabel and returns it. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Sets whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
 Gets whether the property should ignore custom default settings. More...
virtual void SetPanelVisibility (const char *)
 Sets the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
 Returns the panel visibility for the property. More...
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Sets the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
 Returns which representation type the property will be shown by default for. More...
virtual void SetPanelWidget (const char *)
 Sets the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
 Returns name of the panel widget for the property. More...
virtual void SetDisableSubTrace (const char *)
 Sets the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
 Returns the tracing state of the properties of this property. More...
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void WriteTo (vtkSMMessage *msg)
 Let the property write its content into the stream. More...
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
 Let the property read and set its content from the stream. More...
virtual int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element)
virtual void UpdateAllInputs ()
 Update all proxies referred by this property (if any). More...
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveStateValues (vtkPVXMLElement *propertyElement)
 This method must be overridden by concrete class in order to save the real property data. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader)
 Updates state from an XML element. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
Friends
class vtkSMSessionProxyManager
class vtkSMProxy
class vtkSMSubPropertyIterator
class vtkSMDomainIterator
class vtkSMSourceProxy
class vtkSMDomain
class vtkSMPropertyModificationUndoElement
Each instance of vtkSMProperty or a sub-class represents a method and associated arguments (if any) of a VTK object stored on one or more client manager or server nodes. It may have a state and can push this state to the vtk object it refers to. vtkSMProperty only supports methods with no arguments. Sub-classes support methods with different arguments types and numbers.
vtkSMProperty is typically meant for pushing its values to a VTK object. However, a property may be marked as an InformationOnly property in which case its values are obtained from the server with the UpdateInformation() call.
Each non-information property can have one or more domains. A domain represents a set of acceptable values the property can have. Domains provide applications mechanisms to extract semantic information from a property.
A property has two kinds of values: regular (or checked) values and unchecked values. Regular values are the ones that are pushed to the VTK object when the property is updated. These are the ones that get saved in state, etc. Unchecked values are provided so that domains can update their conditions without having the change the property's value e.g. if the domain range for the IsoContour property changes based on the value of the ArrayName property which selects the array to contour with, the can set the unchecked value on the ArrayName property to each of the available arrays to determine what the domain would be without having to modify the property and update its VTK object. If a property has no unchecked-values explicitly set, then the "Get" methods that access the unchecked-values should simply return the checked values. If the checked values are changed, the unchecked values are reset to match the checked values.
A property fires the following events:
Properties are typically constructed from ServerManager XML configuration files. Attributes available on a Property XML are as follows:
Definition at line 144 of file vtkSMProperty.h.
Definition at line 148 of file vtkSMProperty.h.
◆ vtkSMProperty()
vtkSMProperty::vtkSMProperty ( )
◆ ~vtkSMProperty()
vtkSMProperty::~vtkSMProperty ( )
static vtkSMProperty* vtkSMProperty::New ( )
virtual const char* vtkSMProperty::GetClassName ( )
static int vtkSMProperty::IsTypeOf ( const char *  type)
virtual int vtkSMProperty::IsA ( const char *  type)
static vtkSMProperty* vtkSMProperty::SafeDownCast ( vtkObject *  o)
void vtkSMProperty::PrintSelf ( ostream &  os,
Reimplemented in vtkSMProxyProperty, vtkSMStringVectorProperty, and vtkSMVectorProperty.
◆ SetCommand()
virtual void vtkSMProperty::SetCommand ( const char *  )
For example: SetThetaResolution
◆ GetCommand()
virtual char* vtkSMProperty::GetCommand ( )
◆ SetImmediateUpdate()
virtual void vtkSMProperty::SetImmediateUpdate ( int  )
Properties that do not have values can be pushed by calling Modified().
◆ GetImmediateUpdate()
virtual int vtkSMProperty::GetImmediateUpdate ( )
◆ IsInDomains() [1/2]
int vtkSMProperty::IsInDomains ( )
The domains will check the unchecked values (SetUncheckedXXX()) instead of the actual values.
Domains that return vtkSMDomain::NOT_APPLICABLE for vtkSMDomain::IsInDomain are skipped.
◆ IsInDomains() [2/2]
int vtkSMProperty::IsInDomains ( vtkSMDomain **  domain)
domain is set to nullptr when all domain checks pass.
◆ UnRegister()
void vtkSMProperty::UnRegister ( vtkObjectBase *  obj)
◆ NewDomainIterator()
vtkSMDomainIterator* vtkSMProperty::NewDomainIterator ( )
The user has to delete the iterator.
◆ GetDomain()
vtkSMDomain* vtkSMProperty::GetDomain ( const char *  name)
Avoids using this method and use FindDomain instead.
◆ FindDomain() [1/2]
vtkSMDomain* vtkSMProperty::FindDomain ( const char *  classname)
◆ FindDomain() [2/2]
DomainType * vtkSMProperty::FindDomain
inline
vtkSMProperty* prop = ...
auto enumDomain = prop->FindDomain<vtkSMEnumerationDomain>();
Definition at line 735 of file vtkSMProperty.h.
◆ GetNumberOfDomains()
unsigned int vtkSMProperty::GetNumberOfDomains ( )
One can use a domain iterator to access domains then.
◆ GetInformationOnly()
virtual int vtkSMProperty::GetInformationOnly ( )
◆ GetIgnoreSynchronization()
virtual int vtkSMProperty::GetIgnoreSynchronization ( )
◆ GetInformationProperty()
virtual vtkSMProperty* vtkSMProperty::GetInformationProperty ( )
This allows applications to have access to both the in and out properties. The information property has to be specified in the xml configuration file.
◆ AddDomain()
void vtkSMProperty::AddDomain ( const char *  name,
vtkSMDomain *  dom
These are assigned by the proxy manager and can be used to obtain information other than given by the type of the property and its values.
◆ AddLinkedProperty()
virtual void vtkSMProperty::AddLinkedProperty ( vtkSMProperty *  targetProperty)
◆ RemoveLinkedProperty()
virtual void vtkSMProperty::RemoveLinkedProperty ( vtkSMProperty *  targetProperty)
◆ RemoveFromSourceLink()
virtual void vtkSMProperty::RemoveFromSourceLink ( )
This is a useful way for target properties to unlink themselves from a source property prior to, for instance, the deletion of the target property instance. This method only does any work if this instance was passed as the argument to AddLinkedProperty() on a different property instance at some point. Otherwise, it is a no-op.
◆ SetAnimateable()
virtual void vtkSMProperty::SetAnimateable ( int  )
Non-animateable properties are shown in the GUI only in advanced mode.
◆ GetAnimateable()
virtual int vtkSMProperty::GetAnimateable ( )
◆ SetIsInternal()
virtual void vtkSMProperty::SetIsInternal ( int  )
Internal properties are not saved in state and should not be displayed in the user interface.
◆ GetIsInternal()
virtual int vtkSMProperty::GetIsInternal ( )
◆ SetNoCustomDefault()
virtual void vtkSMProperty::SetNoCustomDefault ( int  )
◆ GetNoCustomDefault()
virtual int vtkSMProperty::GetNoCustomDefault ( )
◆ SetPanelVisibility()
virtual void vtkSMProperty::SetPanelVisibility ( const char *  )
The value can be one of:
  • "default": Show the property by default.
  • "advanced": Only show the property in the advanced view.
  • "never": Never show the property on the panel.
By default, standard properties have "default" visibility, while information_only properties have "never" visibility.
◆ GetPanelVisibility()
virtual char* vtkSMProperty::GetPanelVisibility ( )
◆ SetPanelVisibilityDefaultForRepresentation()
virtual void vtkSMProperty::SetPanelVisibilityDefaultForRepresentation ( const char *  )
◆ GetPanelVisibilityDefaultForRepresentation()
virtual char* vtkSMProperty::GetPanelVisibilityDefaultForRepresentation ( )
◆ SetPanelWidget()
virtual void vtkSMProperty::SetPanelWidget ( const char *  )
◆ GetPanelWidget()
virtual char* vtkSMProperty::GetPanelWidget ( )
◆ SetDisableSubTrace()
virtual void vtkSMProperty::SetDisableSubTrace ( const char *  )
◆ GetDisableSubTrace()
virtual char* vtkSMProperty::GetDisableSubTrace ( )
◆ Copy()
virtual void vtkSMProperty::Copy ( vtkSMProperty *  src)
This will copy both checked and unchecked values, if applicable.
Reimplemented in vtkSMStringVectorProperty, vtkSMIdTypeVectorProperty, vtkSMDoubleVectorProperty, vtkSMProxyProperty, vtkSMIntVectorProperty, vtkSMVectorProperty, vtkSMDoubleMapProperty, and vtkSMMapProperty.
◆ GetDocumentation()
virtual vtkSMDocumentation* vtkSMProperty::GetDocumentation ( )
Returns the documentation for this proxy.
The return value may be nullptr if no documentation is defined in the XML for this property.
◆ ResetToDefault()
void vtkSMProperty::ResetToDefault ( )
◆ ResetToXMLDefaults()
virtual void vtkSMProperty::ResetToXMLDefaults ( )
inlinevirtual
Default implementation does nothing.
Reimplemented in vtkSMStringVectorProperty, vtkSMProxyProperty, vtkSMDoubleVectorProperty, vtkSMIdTypeVectorProperty, vtkSMIntVectorProperty, and vtkSMDoubleMapProperty.
Definition at line 415 of file vtkSMProperty.h.
◆ ResetToDomainDefaults()
virtual bool vtkSMProperty::ResetToDomainDefaults ( bool  use_unchecked_values = false)
indicate that it can set a default value and did so. Returns true if any domain can setup a default value for this property. Otherwise false.
vtkSMVectorProperty overrides this method to add support for setting default values using information_property.
In symmetric MPI mode (i.e. when vtkProcessModule::GetSymmetricMPIMode() == true), domains need not have correct values since data information is not collected by doing any reduction in parallel. To avoid setting incorrect values, or worse, different values on different ranks, this method does nothing in the case. Except for vtkSMProxyProperty. For vtkSMProxyProperty, we don't have any domain that is runtime data dependent and hence we let the property reset itself. This ensures that properties with vtkSMProxyListDomain, for example, are initialized correctly.
Reimplemented in vtkSMVectorProperty.
◆ GetXMLLabel()
virtual char* vtkSMProperty::GetXMLLabel ( )
◆ GetXMLName()
virtual char* vtkSMProperty::GetXMLName ( )
Used to get the property from a proxy. Note that the name used to obtain a property that is on a subproxy may be different from the XMLName of the property, see the note on ExposedProperties for vtkSMProxy.
◆ GetRepeatable()
virtual int vtkSMProperty::GetRepeatable ( )
This ivar is configured when the xml file is read and is mainly useful for information (for example from python).
◆ GetHints()
virtual vtkPVXMLElement* vtkSMProperty::GetHints ( )
Hints are metadata associated with the property. The Server Manager does not (and should not) interpret the hints. Hints provide a mechanism to add GUI pertinant information to the server manager XML. Returns the XML element for the hints associated with this property, if any, otherwise returns nullptr.
◆ SetHints()
void vtkSMProperty::SetHints ( vtkPVXMLElement *  hints)
◆ Modified()
void vtkSMProperty::Modified ( )
inlineoverridevirtual
Definition at line 480 of file vtkSMProperty.h.
◆ GetParent()
vtkSMProxy* vtkSMProperty::GetParent ( )
Note that is this property is belong to a sub-proxy of a proxy, the returned value will indeed be that sub-proxy (and not the outer container proxy).
◆ IsStateIgnored()
virtual bool vtkSMProperty::IsStateIgnored ( )
inlinevirtual
Definition at line 503 of file vtkSMProperty.h.
◆ IsValueDefault()
virtual bool vtkSMProperty::IsValueDefault ( )
inlinevirtual
Reimplemented in vtkSMStringVectorProperty, vtkSMProxyProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, and vtkSMMapProperty.
Definition at line 510 of file vtkSMProperty.h.
◆ HasDomainsWithRequiredProperties()
bool vtkSMProperty::HasDomainsWithRequiredProperties ( )
This typically indicates that the property has a domain whose values change at runtime based on input dataset or file being processed.
◆ ClearUncheckedElements()
virtual void vtkSMProperty::ClearUncheckedElements ( )
inlinevirtual
Reimplemented in vtkSMVectorProperty, vtkSMStringVectorProperty, vtkSMIdTypeVectorProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, and vtkSMProxyProperty.
Definition at line 522 of file vtkSMProperty.h.
◆ PARAVIEW_DEPRECATED_IN_5_12_0()
vtkSMProperty::PARAVIEW_DEPRECATED_IN_5_12_0 ( "Use vtkSMObject::CreatePrettyLabel(const std::string& name) instead."  ) const
Need to be deleted after use. Add space: (1) - before every uppercase letter succeded by a lowercase letter (2) - after every lowercase letter succeded by an uppercase letter
◆ WriteTo()
virtual void vtkSMProperty::WriteTo ( vtkSMMessage *  msg)
protectedvirtual
◆ ReadFrom()
virtual void vtkSMProperty::ReadFrom ( const vtkSMMessage *  ,
int   vtkNotUsedmessage_offset,
vtkSMProxyLocator *
inlineprotectedvirtual
Definition at line 555 of file vtkSMProperty.h.
◆ ReadXMLAttributes()
virtual int vtkSMProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
vtkPVXMLElement *  element
protectedvirtual
Reimplemented in vtkSMStringVectorProperty, vtkSMProxyProperty, vtkSMDoubleVectorProperty, vtkSMIdTypeVectorProperty, vtkSMIntVectorProperty, vtkSMVectorProperty, vtkSMDoubleMapProperty, vtkSMInputProperty, and vtkSMMapProperty.
◆ UpdateAllInputs()
virtual void vtkSMProperty::UpdateAllInputs ( )
Overwritten by vtkSMProxyProperty and sub-classes.
Reimplemented in vtkSMProxyProperty.
Definition at line 567 of file vtkSMProperty.h.
◆ SetXMLName()
virtual void vtkSMProperty::SetXMLName ( const char *  )
protectedvirtual
◆ NewProperty()
vtkSMProperty* vtkSMProperty::NewProperty ( const char *  name)
Internal.
Used during XML parsing to get a property with given name. Used by the domains when setting required properties.
◆ AddDependent()
void vtkSMProperty::AddDependent ( vtkSMDomain *  dom)
Internal.
Used by the domains that require this property. They add themselves as dependents.
◆ RemoveAllDependents()
void vtkSMProperty::RemoveAllDependents ( )
◆ UpdateDomains()
void vtkSMProperty::UpdateDomains ( )
This is automatically called after SetUncheckedXXX() to tell all dependent domains to update themselves according to the new value. Note that when calling Update() on domains contained by this property, a nullptr is passed as the argument. This is because the domain does not really "depend" on the property. When calling Update() on dependent domains, the property passes itself as the argument.
Note
as of ParaView 5.10, this method skips updating domains for prototype proxies. See description in .cxx for details behind this change.
◆ SaveState()
virtual void vtkSMProperty::SaveState ( vtkPVXMLElement *  parent,
const char *  property_name,
const char *  uid,
int  saveDomains = 1
protectedvirtual
This method create the property definition and rely on SaveStateValues to fill this definition with the concrete property values
◆ SaveStateValues()
virtual void vtkSMProperty::SaveStateValues ( vtkPVXMLElement *  propertyElement)
protectedvirtual
Reimplemented in vtkSMProxyProperty, vtkSMDoubleMapProperty, vtkSMStringVectorProperty, vtkSMIntVectorProperty, vtkSMDoubleVectorProperty, and vtkSMIdTypeVectorProperty.
◆ SaveDomainState()
virtual void vtkSMProperty::SaveDomainState ( vtkPVXMLElement *  propertyElement,
const char *  uid
protectedvirtual
◆ LoadState()
virtual int vtkSMProperty::LoadState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  loader
protectedvirtual
◆ SetXMLLabel()
virtual void vtkSMProperty::SetXMLLabel ( const char *  )
protectedvirtual
◆ SetInformationOnly()
virtual void vtkSMProperty::SetInformationOnly ( int  )
protectedvirtual
◆ SetIgnoreSynchronization()
virtual void vtkSMProperty::SetIgnoreSynchronization ( int  )
protectedvirtual
◆ SetInformationProperty()
void vtkSMProperty::SetInformationProperty ( vtkSMProperty *  ip)
◆ SetDocumentation()
void vtkSMProperty::SetDocumentation ( vtkSMDocumentation *  )
◆ SetBlockModifiedEvents()
bool vtkSMProperty::SetBlockModifiedEvents ( bool  block)
inlineprotected
Definition at line 677 of file vtkSMProperty.h.
◆ GetPendingModifiedEvents()
virtual bool vtkSMProperty::GetPendingModifiedEvents ( )
protectedvirtual
This gets cleared when Modified() is called.
◆ SetParent()
void vtkSMProperty::SetParent ( vtkSMProxy *  proxy)
◆ SetStateIgnored()
virtual void vtkSMProperty::SetStateIgnored ( bool  )
protectedvirtual
◆ StateIgnoredOn()
virtual void vtkSMProperty::StateIgnoredOn ( )
protectedvirtual
◆ StateIgnoredOff()
virtual void vtkSMProperty::StateIgnoredOff ( )
protectedvirtual
◆ vtkSMSessionProxyManager
friend class vtkSMSessionProxyManager
friend
Definition at line 539 of file vtkSMProperty.h.
◆ vtkSMProxy
friend class vtkSMProxy
friend
Definition at line 540 of file vtkSMProperty.h.
◆ vtkSMSubPropertyIterator
friend class vtkSMSubPropertyIterator
friend
Definition at line 541 of file vtkSMProperty.h.
◆ vtkSMDomainIterator
friend class vtkSMDomainIterator
friend
Definition at line 542 of file vtkSMProperty.h.
◆ vtkSMSourceProxy
friend class vtkSMSourceProxy
friend
Definition at line 543 of file vtkSMProperty.h.
◆ vtkSMDomain
friend
Definition at line 544 of file vtkSMProperty.h.
◆ vtkSMPropertyModificationUndoElement
Definition at line 545 of file vtkSMProperty.h.
◆ Hints
vtkPVXMLElement* vtkSMProperty::Hints
Definition at line 635 of file vtkSMProperty.h.
◆ Command
char* vtkSMProperty::Command
Definition at line 637 of file vtkSMProperty.h.
◆ PInternals
vtkSMPropertyInternals* vtkSMProperty::PInternals
Definition at line 639 of file vtkSMProperty.h.
◆ ImmediateUpdate
int vtkSMProperty::ImmediateUpdate
Definition at line 641 of file vtkSMProperty.h.
◆ Animateable
int vtkSMProperty::Animateable
Definition at line 642 of file vtkSMProperty.h.
◆ IsInternal
int vtkSMProperty::IsInternal
Definition at line 643 of file vtkSMProperty.h.
◆ NoCustomDefault
int vtkSMProperty::NoCustomDefault
Definition at line 644 of file vtkSMProperty.h.
◆ XMLName
char* vtkSMProperty::XMLName
Definition at line 646 of file vtkSMProperty.h.
◆ XMLLabel
char* vtkSMProperty::XMLLabel
Definition at line 647 of file vtkSMProperty.h.
◆ PanelVisibility
char* vtkSMProperty::PanelVisibility
Definition at line 648 of file vtkSMProperty.h.
◆ PanelVisibilityDefaultForRepresentation
char* vtkSMProperty::PanelVisibilityDefaultForRepresentation
Definition at line 651 of file vtkSMProperty.h.
◆ PanelWidget
char* vtkSMProperty::PanelWidget
Definition at line 652 of file vtkSMProperty.h.
◆ DisableSubTrace
char* vtkSMProperty::DisableSubTrace
Definition at line 653 of file vtkSMProperty.h.
◆ DomainIterator
vtkSMDomainIterator* vtkSMProperty::DomainIterator
Definition at line 655 of file vtkSMProperty.h.
◆ InformationOnly
int vtkSMProperty::InformationOnly
Definition at line 657 of file vtkSMProperty.h.
◆ IgnoreSynchronization
int vtkSMProperty::IgnoreSynchronization
Definition at line 660 of file vtkSMProperty.h.
◆ InformationHelper
vtkSMInformationHelper* vtkSMProperty::InformationHelper
Definition at line 663 of file vtkSMProperty.h.
◆ InformationProperty
vtkSMProperty* vtkSMProperty::InformationProperty
Definition at line 666 of file vtkSMProperty.h.
◆ Documentation
vtkSMDocumentation* vtkSMProperty::Documentation
Definition at line 668 of file vtkSMProperty.h.
◆ Repeatable
int vtkSMProperty::Repeatable
Definition at line 671 of file vtkSMProperty.h.
◆ Proxy
vtkWeakPointer<vtkSMProxy> vtkSMProperty::Proxy
Definition at line 696 of file vtkSMProperty.h.
◆ StateIgnored
bool vtkSMProperty::StateIgnored
Definition at line 700 of file vtkSMProperty.h.
◆ Links
vtkSMPropertyLink* vtkSMProperty::Links
Definition at line 702 of file vtkSMProperty.h.
vtkSMEnumerationDomain.h
list of integers with associated strings
Definition: vtkSMEnumerationDomain.h:67
