Public Member Functions | List of all members
pqEnableWidgetDecorator Class Reference
pqEnableWidgetDecorator can be used to enable/disable a widget based on the status of another property not directly controlled by the widget. More...
#include <pqEnableWidgetDecorator.h>
Inheritance diagram for pqEnableWidgetDecorator:
Collaboration diagram for pqEnableWidgetDecorator:
 pqEnableWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
bool enableWidget () const override
 overridden from pqPropertyWidget. More...
- Public Member Functions inherited from pqBoolPropertyWidgetDecorator
 pqBoolPropertyWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
 ~pqBoolPropertyWidgetDecorator () override
bool isBoolProperty () const
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
virtual bool canShowWidget (bool show_advanced) const
 Override this method to override the visibility of the widget in the panel. More...
- Signals inherited from pqBoolPropertyWidgetDecorator
void boolPropertyChanged ()
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
- Protected Attributes inherited from pqBoolPropertyWidgetDecorator
vtkWeakPointer< vtkSMProperty > Property
QString Function
int Index
unsigned long ObserverId
bool BoolProperty
QString Value
Definition at line 15 of file pqEnableWidgetDecorator.h.
◆ pqEnableWidgetDecorator()
pqEnableWidgetDecorator::pqEnableWidgetDecorator ( vtkPVXMLElement *  config,
◆ enableWidget()
bool pqEnableWidgetDecorator::enableWidget ( ) const
inlineoverridevirtual
Reimplemented from pqPropertyWidgetDecorator.
Definition at line 26 of file pqEnableWidgetDecorator.h.
