Public Slots | Public Member Functions | Properties | List of all members
pqCheckableProperty Class Reference
property widget for properties representing a checkable property. More...
#include <pqCheckableProperty.h>
Inheritance diagram for pqCheckableProperty:
Collaboration diagram for pqCheckableProperty:
Public Slots
void setEnableCheckbox (bool enableCheckbox)
 pqCheckableProperty (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqCheckableProperty () override
void apply () override
void reset () override
void select () override
void deselect () override
void updateWidget (bool showing_advanced_properties) override
void setPanelVisibility (const char *vis) override
void setView (pqView *) override
bool isSingleRowItem () const override
bool enableCheckbox () const
 ~pqPropertyWidget () override
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Properties
bool enableCheckbox
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqCheckableProperty is designed for a specific use-case: a property that can be enabled or disabled by a checkbox. This is useful for optional properties since it restrains the user to use the property unless it is really needed.
Example proxy definition(s) that use this widget is as follows:
<ServerManagerConfiguration>
<ProxyGroup name="sources">
<SourceProxy name="CustomSource" class="vtkSphereSource">
<DoubleVectorProperty name="PropertyA"
number_of_elements="1"
default_values="0">
<DoubleRangeDomain name="range" min="0" max="10" />
</DoubleVectorProperty>
<IntVectorProperty name="EnablePropertyA"
default_values="0">
<BooleanDomain name="bool" />
</IntVectorProperty>
<PropertyGroup label="Property A" panel_widget="CheckableProperty">
<Property name="PropertyA" function="Property" />
<Property name="EnablePropertyA" function="PropertyCheckBox" />
</PropertyGroup>
</SourceProxy>
</ProxyGroup>
</ServerManagerConfiguration>
Definition at line 47 of file pqCheckableProperty.h.
◆ pqCheckableProperty()
pqCheckableProperty::pqCheckableProperty ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqCheckableProperty()
pqCheckableProperty::~pqCheckableProperty ( )
override
◆ apply()
void pqCheckableProperty::apply ( )
Reimplemented from pqPropertyWidget.
◆ reset()
void pqCheckableProperty::reset ( )
◆ select()
void pqCheckableProperty::select ( )
Only widgets that have interactive widgets need to override these methods to select/deselect the interactive widgets. selectPort(int) allows to specify an output port index and conditionnaly select the interactive widget if the XML hint WidgetVisibilityLink has been set. Default implementation does nothing.
◆ deselect()
void pqCheckableProperty::deselect ( )
◆ updateWidget()
void pqCheckableProperty::updateWidget ( bool  showing_advanced_properties)
◆ setPanelVisibility()
void pqCheckableProperty::setPanelVisibility ( const char *  vis)
◆ setView()
void pqCheckableProperty::setView ( pqView *  )
This will fire the viewChanged() signal.
◆ isSingleRowItem()
bool pqCheckableProperty::isSingleRowItem ( ) const
Originally intended for PropertyWidgets which are a group of other Propertywidgets, such as pqCheckableProperty. This mandates that when the widget is rendered, its label to be placed in the same row as the widget group.
See also
pqProxyWidgetItem::newGroupItem
◆ enableCheckbox()
bool pqCheckableProperty::enableCheckbox ( ) const
◆ setEnableCheckbox
void pqCheckableProperty::setEnableCheckbox ( bool  enableCheckbox)
slot
Property Documentation
◆ enableCheckbox
readwrite
Definition at line 71 of file pqCheckableProperty.h.
