Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
pqPropertyWidget Class Reference
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (for the proxy's properties or display properties). More...
#include <pqPropertyWidget.h>
Inheritance diagram for pqPropertyWidget:
Public Slots
Signals
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Friends
class pqCompositePropertyWidgetDecorator
class pqPropertyWidgetDecorator
class pqProxyWidget
Definition at line 25 of file pqPropertyWidget.h.
◆ pqPropertyWidget()
pqPropertyWidget::pqPropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqPropertyWidget()
pqPropertyWidget::~pqPropertyWidget ( )
override
◆ apply()
virtual void pqPropertyWidget::apply ( )
◆ reset()
virtual void pqPropertyWidget::reset ( )
◆ select()
virtual void pqPropertyWidget::select ( )
inlinevirtual
Only widgets that have interactive widgets need to override these methods to select/deselect the interactive widgets. selectPort(int) allows to specify an output port index and conditionnaly select the interactive widget if the XML hint WidgetVisibilityLink has been set. Default implementation does nothing.
Reimplemented in pqInteractivePropertyWidgetAbstract, pqCheckableProperty, pqProxySelectionWidget, and pqProxyPropertyWidget.
Definition at line 48 of file pqPropertyWidget.h.
◆ selectPort()
virtual void pqPropertyWidget::selectPort ( int  portIndex)
inlinevirtual
Reimplemented in pqInteractivePropertyWidgetAbstract.
Definition at line 49 of file pqPropertyWidget.h.
◆ deselect()
virtual void pqPropertyWidget::deselect ( )
inlinevirtual
Definition at line 50 of file pqPropertyWidget.h.
◆ isSelected()
bool pqPropertyWidget::isSelected ( ) const
inline
Definition at line 51 of file pqPropertyWidget.h.
◆ updateWidget()
virtual void pqPropertyWidget::updateWidget ( bool  showing_advanced_properties)
inlinevirtual
◆ view()
pqView* pqPropertyWidget::view ( ) const
◆ proxy()
vtkSMProxy* pqPropertyWidget::proxy ( ) const
◆ property()
vtkSMProperty* pqPropertyWidget::property ( ) const
◆ panelVisibility()
virtual char* pqPropertyWidget::panelVisibility ( ) const
Are overwritten by pqPropertyGroupWidget to forward calls to vtkSMPropertyGroup
Reimplemented in pqPropertyGroupWidget.
◆ setPanelVisibility()
virtual void pqPropertyWidget::setPanelVisibility ( const char *  vis)
◆ isSingleRowItem()
virtual bool pqPropertyWidget::isSingleRowItem ( ) const
Originally intended for PropertyWidgets which are a group of other Propertywidgets, such as pqCheckableProperty. This mandates that when the widget is rendered, its label to be placed in the same row as the widget group.
See also
pqProxyWidgetItem::newGroupItem
Reimplemented in pqCheckableProperty.
◆ showLabel()
bool pqPropertyWidget::showLabel ( ) const
◆ getXMLName()
template<class T >
static QString pqPropertyWidget::getXMLName ( T *  object)
inlinestatic
This allows for code to get the XML name of an object without having to explicitly check for a possibly nullptr char* pointer.
This is templated so that it will work with a variety of objects such as vtkSMProperty's and vtkSMDomain's. It can be called with anything that has a "char* GetXMLName()" method.
For example, to get the XML name of a vtkSMIntRangeDomain: QString name = pqPropertyWidget::getXMLName(domain);
Definition at line 104 of file pqPropertyWidget.h.
◆ decorators()
const QList<QPointer<pqPropertyWidgetDecorator> >& pqPropertyWidget::decorators ( ) const
inline
Definition at line 112 of file pqPropertyWidget.h.
◆ getTooltip()
static QString pqPropertyWidget::getTooltip ( vtkSMProperty *  property)
May return an empty string.
◆ hintsWidgetHeightNumberOfRows()
static int pqPropertyWidget::hintsWidgetHeightNumberOfRows ( vtkPVXMLElement *  hints,
int  defaultValue = 10
<WidgetHeight number_of_rows="val">,
◆ parseComponentLabels()
static std::vector<std::string> pqPropertyWidget::parseComponentLabels ( vtkPVXMLElement *  hints,
unsigned int  elemCount = 0
This is usually the XML node named ShowComponentLabels in the hints of a proxy. elemCount is a hint of the number of labels to use. Set to 0 to use the number of labels existing in the XML.
◆ viewChanged
void pqPropertyWidget::viewChanged ( pqView *  view)
signal
◆ changeAvailable
void pqPropertyWidget::changeAvailable ( )
signal
The editing may not be complete.
◆ changeFinished
void pqPropertyWidget::changeFinished ( )
signal
changeAvailable() is always fired before changeFinished().
◆ restartRequired
void pqPropertyWidget::restartRequired ( )
signal
◆ setView
virtual void pqPropertyWidget::setView ( pqView *  )
virtualslot
This will fire the viewChanged() signal.
Reimplemented in pqInteractivePropertyWidgetAbstract, pqCheckableProperty, and pqProxySelectionWidget.
◆ addPropertyLink() [1/2]
void pqPropertyWidget::addPropertyLink ( QObject *  qobject,
const char *  qproperty,
const char *  qsignal,
vtkSMProperty *  smproperty,
int  smindex = -1
◆ addPropertyLink() [2/2]
vtkSMProxy *  smproxy,
int  smindex = -1
◆ removePropertyLink() [1/2]
void pqPropertyWidget::removePropertyLink ( QObject *  qobject,
int  smindex = -1
◆ removePropertyLink() [2/2]
int  smindex = -1
◆ setShowLabel()
void pqPropertyWidget::setShowLabel ( bool  show)
◆ setChangeAvailableAsChangeFinished()
void pqPropertyWidget::setChangeAvailableAsChangeFinished ( bool  status)
inlineprotected
Hence by default we connect the two together. For subclasses that don't follow this pattern should call this method with 'false' to disconnect changeAvailable() and changeFinished() signals. In that case, the subclass must explicitly fire changeFinished() signal.
Definition at line 189 of file pqPropertyWidget.h.
◆ addDecorator()
void pqPropertyWidget::addDecorator ( pqPropertyWidgetDecorator *  )
The pqPropertyWidget takes over the ownership of the decorator. The decorator will be deleted when the pqPropertyWidget is destroyed.
◆ removeDecorator()
void pqPropertyWidget::removeDecorator ( pqPropertyWidgetDecorator *  )
◆ links()
pqPropertyLinks& pqPropertyWidget::links ( )
inlineprotected
Definition at line 209 of file pqPropertyWidget.h.
◆ setProperty()
void pqPropertyWidget::setProperty ( vtkSMProperty *  property)
◆ pqCompositePropertyWidgetDecorator
Definition at line 215 of file pqPropertyWidget.h.
◆ pqPropertyWidgetDecorator
friend class pqPropertyWidgetDecorator
friend
Definition at line 216 of file pqPropertyWidget.h.
◆ pqProxyWidget
friend class pqProxyWidget
friend
Definition at line 217 of file pqPropertyWidget.h.
