Public Member Functions | Protected Slots | List of all members
pqGlyphScaleFactorPropertyWidget Class Reference
pqGlyphScaleFactorPropertyWidget is used for the "Scale Factor" property on the Glyph filter. More...
#include <pqGlyphScaleFactorPropertyWidget.h>
Inheritance diagram for pqGlyphScaleFactorPropertyWidget:
Collaboration diagram for pqGlyphScaleFactorPropertyWidget:
 pqGlyphScaleFactorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqGlyphScaleFactorPropertyWidget () override
- Public Member Functions inherited from pqDoubleVectorPropertyWidget
 pqDoubleVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqDoubleVectorPropertyWidget () override
void apply () override
void reset () override
 ~pqPropertyWidget () override
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void resetButtonClicked () override
 update the property's value using the domain. More...
- Protected Slots inherited from pqDoubleVectorPropertyWidget
virtual void resetButtonClicked ()
 called when the user clicks the "reset" button for a specific property. More...
void scaleHalf ()
void scaleTwice ()
void scale (double)
void resetToActiveDataBounds ()
 sets the value using active source's data bounds. More...
void resetToBounds (const double bds[6])
 sets the value to the specified bounds. More...
- Signals inherited from pqDoubleVectorPropertyWidget
void clearHighlight ()
 internal signal used to clear highlights from pqHighlightablePushButton. More...
void highlightResetButton ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It customizes the resetButtonClicked() logic since the Glyph filter's scale factor setup is custom.
Definition at line 15 of file pqGlyphScaleFactorPropertyWidget.h.
◆ pqGlyphScaleFactorPropertyWidget()
pqGlyphScaleFactorPropertyWidget::pqGlyphScaleFactorPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqGlyphScaleFactorPropertyWidget()
pqGlyphScaleFactorPropertyWidget::~pqGlyphScaleFactorPropertyWidget ( )
override
◆ resetButtonClicked
void pqGlyphScaleFactorPropertyWidget::resetButtonClicked ( )
overrideprotectedslot
