Public Member Functions | Friends | List of all members
pqCompositePropertyWidgetDecorator Class Reference
pqPropertyWidgetDecorator subclass that can combine multiple decorators using boolean operations. More...
#include <pqCompositePropertyWidgetDecorator.h>
Inheritance diagram for pqCompositePropertyWidgetDecorator:
Collaboration diagram for pqCompositePropertyWidgetDecorator:
 pqCompositePropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 ~pqCompositePropertyWidgetDecorator () override
bool canShowWidget (bool show_advanced) const override
 Override this method to override the visibility of the widget in the panel. More...
bool enableWidget () const override
 Override this method to override the enable state of the widget in the panel. More...
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
Friends
class pqInternals
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
pqCompositePropertyWidgetDecorator helps combine multiple decorators using boolean operators as indicated in the example below.
<IntVectorProperty name="Expression1"
number_of_elements="1"
default_values="0">
<BooleanDomain name="bool" />
<Hints>
<!-- Expression === { A and [B or (C and D)] } or E -->
<PropertyWidgetDecorator type="CompositeDecorator">
<Expression type="or">
<Expression type="and">
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="A"
value="1" />
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="B"
value="1" />
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="C"
value="1" />
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="D"
value="1" />
</Expression>
</Expression>
</Expression>
<PropertyWidgetDecorator type="GenericDecorator" mode="enabled_state" property="E"
value="1" />
</Expression>
</PropertyWidgetDecorator>
</Hints>
</IntVectorProperty>
Definition at line 50 of file pqCompositePropertyWidgetDecorator.h.
◆ pqCompositePropertyWidgetDecorator()
pqCompositePropertyWidgetDecorator::pqCompositePropertyWidgetDecorator ( vtkPVXMLElement *  xml,
◆ ~pqCompositePropertyWidgetDecorator()
pqCompositePropertyWidgetDecorator::~pqCompositePropertyWidgetDecorator ( )
override
◆ canShowWidget()
bool pqCompositePropertyWidgetDecorator::canShowWidget ( bool  show_advanced) const
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget invisible given the current state.
Reimplemented from pqPropertyWidgetDecorator.
◆ enableWidget()
bool pqCompositePropertyWidgetDecorator::enableWidget ( ) const
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget disabled given the current state.
◆ pqInternals
friend class pqInternals
friend
Definition at line 67 of file pqCompositePropertyWidgetDecorator.h.
