Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
pqPropertyWidgetDecorator Class Reference
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to the widget to add additional control logic. More...
#include <pqPropertyWidgetDecorator.h>
Inheritance diagram for pqPropertyWidgetDecorator:
Signals
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
virtual bool canShowWidget (bool show_advanced) const
 Override this method to override the visibility of the widget in the panel. More...
virtual bool enableWidget () const
 Override this method to override the enable state of the widget in the panel. More...
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
vtkPVXMLElement * xml () const
Subclasses can be used to logic to control when the widget is enabled/disabled, hidden/visible, etc. based on values of other properties of UI elements.
Definition at line 19 of file pqPropertyWidgetDecorator.h.
◆ pqPropertyWidgetDecorator()
pqPropertyWidgetDecorator::pqPropertyWidgetDecorator ( vtkPVXMLElement *  xml,
Constructor.
Parameters
xmlThe XML element from the <Hints/> section for the proxy/property that resulted in the creation of the decorator. Decorators can be provided configuration parameters from the XML.
parentParent widget
◆ ~pqPropertyWidgetDecorator()
pqPropertyWidgetDecorator::~pqPropertyWidgetDecorator ( )
override
◆ parentWidget()
pqPropertyWidget* pqPropertyWidgetDecorator::parentWidget ( ) const
◆ canShowWidget()
virtual bool pqPropertyWidgetDecorator::canShowWidget ( bool  show_advanced) const
inlinevirtual
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget invisible given the current state.
Reimplemented in pqCompositePropertyWidgetDecorator, pqSessionTypeDecorator, pqGenericPropertyWidgetDecorator, pqInputDataTypeDecorator, pqMultiComponentsDecorator, pqOSPRayHidingDecorator, pqShowWidgetDecorator, and pqOpenVRHidingDecorator.
Definition at line 49 of file pqPropertyWidgetDecorator.h.
◆ enableWidget()
virtual bool pqPropertyWidgetDecorator::enableWidget ( ) const
inlinevirtual
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget disabled given the current state.
Reimplemented in pqCompositePropertyWidgetDecorator, pqSessionTypeDecorator, pqGenericPropertyWidgetDecorator, pqInputDataTypeDecorator, and pqEnableWidgetDecorator.
Definition at line 63 of file pqPropertyWidgetDecorator.h.
◆ create()
static pqPropertyWidgetDecorator* pqPropertyWidgetDecorator::create ( vtkPVXMLElement *  xml,
◆ visibilityChanged
void pqPropertyWidgetDecorator::visibilityChanged ( )
signal
◆ enableStateChanged
void pqPropertyWidgetDecorator::enableStateChanged ( )
signal
◆ xml()
vtkPVXMLElement* pqPropertyWidgetDecorator::xml ( ) const
