Public Member Functions | Protected Member Functions | List of all members
pqInputDataTypeDecorator Class Reference
pqInputDataTypeDecorator is a pqPropertyWidgetDecorator subclass. More...
#include <pqInputDataTypeDecorator.h>
Inheritance diagram for pqInputDataTypeDecorator:
Collaboration diagram for pqInputDataTypeDecorator:
 pqInputDataTypeDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
 ~pqInputDataTypeDecorator () override
bool enableWidget () const override
 Overridden to enable/disable the widget based on input data type. More...
bool canShowWidget (bool show_advanced) const override
 Overriden to show or not the widget based on input data type. More...
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
virtual bool processState () const
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
For certain properties, they should update the enable state based on input data types. For example, "Computer Gradients" in Contour filter should only be enabled when an input data type is a StructuredData. Please see vtkPVDataInformation::IsDataStructured() for structured types.
Definition at line 21 of file pqInputDataTypeDecorator.h.
◆ pqInputDataTypeDecorator()
pqInputDataTypeDecorator::pqInputDataTypeDecorator ( vtkPVXMLElement *  config,
◆ ~pqInputDataTypeDecorator()
pqInputDataTypeDecorator::~pqInputDataTypeDecorator ( )
override
◆ enableWidget()
bool pqInputDataTypeDecorator::enableWidget ( ) const
Reimplemented from pqPropertyWidgetDecorator.
◆ canShowWidget()
bool pqInputDataTypeDecorator::canShowWidget ( bool  show_advanced) const
◆ processState()
virtual bool pqInputDataTypeDecorator::processState ( ) const
protectedvirtual
