Public Slots | Signals | Public Member Functions | Properties | List of all members
pqImageCompressorWidget Class Reference
pqImageCompressorWidget is a pqPropertyWidget designed to be used for "CompressorConfig" property on "RenderView" or "RenderViewSettings" proxy. More...
#include <pqImageCompressorWidget.h>
Inheritance diagram for pqImageCompressorWidget:
Collaboration diagram for pqImageCompressorWidget:
Public Slots
void setCompressorConfig (const QString &)
Signals
void compressorConfigChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqImageCompressorWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqImageCompressorWidget () override
QString compressorConfig () const
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It works with a string property that expects the config in a predetermined format (refer to the code for details on the format).
Definition at line 16 of file pqImageCompressorWidget.h.
◆ pqImageCompressorWidget()
pqImageCompressorWidget::pqImageCompressorWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqImageCompressorWidget()
pqImageCompressorWidget::~pqImageCompressorWidget ( )
override
◆ compressorConfig()
QString pqImageCompressorWidget::compressorConfig ( ) const
◆ setCompressorConfig
void pqImageCompressorWidget::setCompressorConfig ( const QString &  )
slot
◆ compressorConfigChanged
void pqImageCompressorWidget::compressorConfigChanged ( )
signal
Property Documentation
◆ compressorConfig
readwrite
Definition at line 20 of file pqImageCompressorWidget.h.
