Public Slots | Signals | Public Member Functions | Properties | List of all members
pqIntMaskPropertyWidget Class Reference
pqIntMaskPropertyWidget is designed to be used for an IntVectorProperty that can have a value that is set by or-ing together flags. More...
#include <pqIntMaskPropertyWidget.h>
Inheritance diagram for pqIntMaskPropertyWidget:
Collaboration diagram for pqIntMaskPropertyWidget:
Public Slots
void setMask (int mask)
 Set the mask. More...
Signals
void maskChanged ()
 Fired whenever the user changes the selection. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqIntMaskPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqIntMaskPropertyWidget () override
int mask () const
 Returns the current mask value. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
int mask
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
The user is presented with a button with menu from which they can select multiple items. The resulting property value is determined by or-ing together the flag values for each of the checked item.
The flag/mask labels and their values are specified as hints on the XML property. The following XML snippet demonstrates how to use this property widget.
<IntVectorProperty name="FacesToRender"
command="SetFaceMask"
number_of_elements="1"
default_values="63"
panel_widget="int_mask">
<IntRangeDomain name="range" min="0" />
<Hints>
<Mask>
<Item name="Min-YZ" value="1" />
<Item name="Min-ZX" value="2" />
<Item name="Min-XY" value="4" />
<Item name="Max-YZ" value="8" />
<Item name="Max-ZX" value="16" />
<Item name="Max-XY" value="32" />
</Mask>
</Hints>
</IntVectorProperty>
Definition at line 41 of file pqIntMaskPropertyWidget.h.
◆ pqIntMaskPropertyWidget()
pqIntMaskPropertyWidget::pqIntMaskPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqIntMaskPropertyWidget()
pqIntMaskPropertyWidget::~pqIntMaskPropertyWidget ( )
override
◆ mask()
int pqIntMaskPropertyWidget::mask ( ) const
◆ setMask
void pqIntMaskPropertyWidget::setMask ( int  mask)
slot
Set the mask.
◆ maskChanged
void pqIntMaskPropertyWidget::maskChanged ( )
signal
Property Documentation
◆ mask
readwrite
Definition at line 45 of file pqIntMaskPropertyWidget.h.
value
value
name
name
