Public Member Functions | Protected Slots | List of all members
pqTextureSelectorPropertyWidget Class Reference
#include <pqTextureSelectorPropertyWidget.h>
Inheritance diagram for pqTextureSelectorPropertyWidget:
Collaboration diagram for pqTextureSelectorPropertyWidget:
 pqTextureSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqTextureSelectorPropertyWidget () override=default
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void onTextureChanged (vtkSMProxy *texture)
void onPropertyChanged ()
void checkAttributes (bool tcoords, bool tangents)
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 22 of file pqTextureSelectorPropertyWidget.h.
◆ pqTextureSelectorPropertyWidget()
pqTextureSelectorPropertyWidget::pqTextureSelectorPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqTextureSelectorPropertyWidget()
pqTextureSelectorPropertyWidget::~pqTextureSelectorPropertyWidget ( )
overridedefault
◆ onTextureChanged
void pqTextureSelectorPropertyWidget::onTextureChanged ( vtkSMProxy *  texture)
protectedslot
◆ onPropertyChanged
void pqTextureSelectorPropertyWidget::onPropertyChanged ( )
protectedslot
◆ checkAttributes
void pqTextureSelectorPropertyWidget::checkAttributes ( bool  tcoords,
bool  tangents
protectedslot
