Public Slots | Public Member Functions | Protected Slots | List of all members
pqDisplaySizedImplicitPlanePropertyWidget Class Reference
pqDisplaySizedImplicitPlanePropertyWidget is a custom property widget that uses "DisplaySizedImplicitPlaneWidgetRepresentation" to help users interactively set the origin and normal for a plane. More...
#include <pqDisplaySizedImplicitPlanePropertyWidget.h>
Inheritance diagram for pqDisplaySizedImplicitPlanePropertyWidget:
Collaboration diagram for pqDisplaySizedImplicitPlanePropertyWidget:
Public Slots
void showPlane ()
 Slots used to toggle the visibility of the translucent plane. More...
void hidePlane ()
void setDrawPlane (bool val)
void setDrawOutlineAndIntersectionEdges (bool val)
 Set draw outline and intersection edges. More...
void useXNormal ()
 Set the widget normal to be along the X axis. More...
void useYNormal ()
 Set the widget normal to be along the Y axis. More...
void useZNormal ()
 Set the widget normal to be along the Z axis. More...
void resetRadiusSize ()
 Reset the disk-radius size to the default size. More...
void resetToDataBounds ()
 Update the widget's origin and bounds using current data bounds. More...
void resetCameraToNormal ()
 Reset the camera to be down the plane normal. More...
void useCameraNormal ()
 Set the widget normal to be along the camera view direction. More...
- Public Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
 pqDisplaySizedImplicitPlanePropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqDisplaySizedImplicitPlanePropertyWidget () override
void apply () override
 Overridden to update the DrawPlane state. More...
void reset () override
- Public Member Functions inherited from pqInteractivePropertyWidget
 pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidget () override
vtkSMNewWidgetRepresentationProxy * widgetProxy () const
 Returns the proxy for the 3D interactive widget. More...
- Public Member Functions inherited from pqInteractivePropertyWidgetAbstract
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Protected Slots
void placeWidget () override
 Places the interactive widget using current data source information. More...
- Protected Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void placeWidget ()=0
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
- Signals inherited from pqInteractivePropertyWidgetAbstract
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
- Protected Member Functions inherited from pqInteractivePropertyWidget
vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy () final
 Get the internal instance of the widget proxy. More...
- Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
- Protected Attributes inherited from pqInteractivePropertyWidgetAbstract
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
- Properties inherited from pqInteractivePropertyWidgetAbstract
pqSMProxy dataSource
To use this widget for a property group (vtkSMPropertyGroup), use "InteractivePlane" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Definition at line 23 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
◆ pqDisplaySizedImplicitPlanePropertyWidget()
pqDisplaySizedImplicitPlanePropertyWidget::pqDisplaySizedImplicitPlanePropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqDisplaySizedImplicitPlanePropertyWidget()
pqDisplaySizedImplicitPlanePropertyWidget::~pqDisplaySizedImplicitPlanePropertyWidget ( )
override
◆ apply()
void pqDisplaySizedImplicitPlanePropertyWidget::apply ( )
Reimplemented from pqPropertyWidget.
◆ reset()
void pqDisplaySizedImplicitPlanePropertyWidget::reset ( )
◆ showPlane
void pqDisplaySizedImplicitPlanePropertyWidget::showPlane ( )
inlineslot
Definition at line 44 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
◆ hidePlane
void pqDisplaySizedImplicitPlanePropertyWidget::hidePlane ( )
inlineslot
Definition at line 45 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
◆ setDrawPlane
void pqDisplaySizedImplicitPlanePropertyWidget::setDrawPlane ( bool  val)
slot
◆ setDrawOutlineAndIntersectionEdges
void pqDisplaySizedImplicitPlanePropertyWidget::setDrawOutlineAndIntersectionEdges ( bool  val)
slot
◆ useXNormal
void pqDisplaySizedImplicitPlanePropertyWidget::useXNormal ( )
inlineslot
Definition at line 56 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
◆ useYNormal
void pqDisplaySizedImplicitPlanePropertyWidget::useYNormal ( )
inlineslot
Definition at line 61 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
◆ useZNormal
void pqDisplaySizedImplicitPlanePropertyWidget::useZNormal ( )
inlineslot
Definition at line 66 of file pqDisplaySizedImplicitPlanePropertyWidget.h.
◆ resetRadiusSize
void pqDisplaySizedImplicitPlanePropertyWidget::resetRadiusSize ( )
slot
◆ resetToDataBounds
void pqDisplaySizedImplicitPlanePropertyWidget::resetToDataBounds ( )
slot
◆ resetCameraToNormal
void pqDisplaySizedImplicitPlanePropertyWidget::resetCameraToNormal ( )
slot
◆ useCameraNormal
void pqDisplaySizedImplicitPlanePropertyWidget::useCameraNormal ( )
slot
◆ placeWidget
void pqDisplaySizedImplicitPlanePropertyWidget::placeWidget ( )
overrideprotectedslot
