Signals | Public Member Functions | Protected Slots | List of all members
pqFileNamePropertyWidget Class Reference
pqFileNamePropertyWidget is used for the "File Name" property on the Environment annotation filter. More...
#include <pqFileNamePropertyWidget.h>
Inheritance diagram for pqFileNamePropertyWidget:
Collaboration diagram for pqFileNamePropertyWidget:
Signals
void clearHighlight ()
 internal signal used to clear highlights from pqHighlightablePushButton. More...
void highlightResetButton ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqFileNamePropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqFileNamePropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
virtual void resetButtonClicked ()
 update the property's value using the domain. More...
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It customizes the resetButtonClicked() logic since the Environment filter's filename setup is custom.
Definition at line 15 of file pqFileNamePropertyWidget.h.
◆ pqFileNamePropertyWidget()
pqFileNamePropertyWidget::pqFileNamePropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqFileNamePropertyWidget()
pqFileNamePropertyWidget::~pqFileNamePropertyWidget ( )
override
◆ clearHighlight
void pqFileNamePropertyWidget::clearHighlight ( )
signal
◆ highlightResetButton
void pqFileNamePropertyWidget::highlightResetButton ( )
signal
◆ resetButtonClicked
virtual void pqFileNamePropertyWidget::resetButtonClicked ( )
protectedvirtualslot
