Public Types | Public Slots | Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqSplinePropertyWidget Class Reference
pqSplinePropertyWidget is a custom property widget that uses "SplineWidgetRepresentation" to help users interactively set points that form a spline. More...
#include <pqSplinePropertyWidget.h>
Inheritance diagram for pqSplinePropertyWidget:
Collaboration diagram for pqSplinePropertyWidget:
enum  ModeTypes { SPLINE = 0, POLYLINE = 1 }
Public Slots
void setLineColor (const QColor &)
 Set the color to use for the spline. More...
- Public Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
Signals
void pointsChanged ()
 Signal fired whenever the points are changed. More...
void currentRowChanged ()
 Signal fired when the current row selected in the widget is changed. More...
- Signals inherited from pqInteractivePropertyWidgetAbstract
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqSplinePropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, ModeTypes mode=SPLINE, QWidget *parent=nullptr)
 ~pqSplinePropertyWidget () override
QList< QVariant > points () const
 Get/Set the points that form the spline. More...
void setPoints (const QList< QVariant > &points)
int currentRow () const
void setCurrentRow (int idx)
- Public Member Functions inherited from pqInteractivePropertyWidget
 pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidget () override
vtkSMNewWidgetRepresentationProxy * widgetProxy () const
 Returns the proxy for the 3D interactive widget. More...
- Public Member Functions inherited from pqInteractivePropertyWidgetAbstract
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
void reset () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
virtual void apply ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Protected Slots
void placeWidget () override
- Protected Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void placeWidget ()=0
 Places the interactive widget using current data source information. More...
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
Properties
int currentRow
- Properties inherited from pqInteractivePropertyWidgetAbstract
pqSMProxy dataSource
template<class T >
- Protected Member Functions inherited from pqInteractivePropertyWidget
vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy () final
 Get the internal instance of the widget proxy. More...
- Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
- Protected Attributes inherited from pqInteractivePropertyWidgetAbstract
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveSpline" as the "panel_widget" in the XML configuration. The property group can have properties for following functions:
Definition at line 28 of file pqSplinePropertyWidget.h.
◆ ModeTypes
Enumerator
SPLINE
POLYLINE
Definition at line 36 of file pqSplinePropertyWidget.h.
◆ pqSplinePropertyWidget()
pqSplinePropertyWidget::pqSplinePropertyWidget ( vtkSMProxy *  proxy,
ModeTypes  mode = SPLINE,
QWidget *  parent = nullptr
◆ ~pqSplinePropertyWidget()
pqSplinePropertyWidget::~pqSplinePropertyWidget ( )
override
◆ points()
QList<QVariant> pqSplinePropertyWidget::points ( ) const
◆ setPoints()
void pqSplinePropertyWidget::setPoints ( const QList< QVariant > &  points)
◆ currentRow()
int pqSplinePropertyWidget::currentRow ( ) const
◆ setCurrentRow()
void pqSplinePropertyWidget::setCurrentRow ( int  idx)
◆ pointsChanged
void pqSplinePropertyWidget::pointsChanged ( )
signal
◆ currentRowChanged
void pqSplinePropertyWidget::currentRowChanged ( )
signal
◆ setLineColor
void pqSplinePropertyWidget::setLineColor ( const QColor &  )
slot
◆ placeWidget
void pqSplinePropertyWidget::placeWidget ( )
overrideprotectedslot
Property Documentation
◆ points
readwrite
Definition at line 30 of file pqSplinePropertyWidget.h.
◆ currentRow
readwrite
Definition at line 31 of file pqSplinePropertyWidget.h.
