Signals | Public Member Functions | List of all members
pqOMETransferFunctionsPropertyWidget Class Reference
#include <pqOMETransferFunctionsPropertyWidget.h>
Inheritance diagram for pqOMETransferFunctionsPropertyWidget:
Collaboration diagram for pqOMETransferFunctionsPropertyWidget:
Signals
void xrgbPointsChanged ()
void xvmsPointsChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqOMETransferFunctionsPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqOMETransferFunctionsPropertyWidget () override
bool event (QEvent *evt) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 13 of file pqOMETransferFunctionsPropertyWidget.h.
◆ pqOMETransferFunctionsPropertyWidget()
pqOMETransferFunctionsPropertyWidget::pqOMETransferFunctionsPropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqOMETransferFunctionsPropertyWidget()
pqOMETransferFunctionsPropertyWidget::~pqOMETransferFunctionsPropertyWidget ( )
override
◆ event()
bool pqOMETransferFunctionsPropertyWidget::event ( QEvent *  evt)
override
◆ xrgbPointsChanged
void pqOMETransferFunctionsPropertyWidget::xrgbPointsChanged ( )
signal
◆ xvmsPointsChanged
void pqOMETransferFunctionsPropertyWidget::xvmsPointsChanged ( )
signal
