Signals | Public Member Functions | Properties | List of all members
pqColorPaletteSelectorWidget Class Reference
widget to choose a color palette to load/select. More...
#include <pqColorPaletteSelectorWidget.h>
Inheritance diagram for pqColorPaletteSelectorWidget:
Collaboration diagram for pqColorPaletteSelectorWidget:
Signals
void paletteNameChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqColorPaletteSelectorWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqColorPaletteSelectorWidget () override
QString paletteName () const
void setPaletteName (const QString &name)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QString paletteName
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqColorPaletteSelectorWidget is a pqPropertyWidget intended to be used in two roles:
  1. To load a specific color palette.
  2. To select a specific color palette.
Mode (1) is used when the widget is used for a vtkSMProperty e.g. **'Load Palette'** property on the ColorPalette proxy. In that case, the user's action is expected to update the proxy with the chosen palette.
Mode (2) is used when the widget is used for a vtkSMStringVectorProperty e.g. OverrideColorPalette property on ImageOptions proxy. In that case, the selected palette name is simply set on the vtkSMStringVectorProperty.
Definition at line 31 of file pqColorPaletteSelectorWidget.h.
◆ pqColorPaletteSelectorWidget()
pqColorPaletteSelectorWidget::pqColorPaletteSelectorWidget ( vtkSMProxy *  smproxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqColorPaletteSelectorWidget()
pqColorPaletteSelectorWidget::~pqColorPaletteSelectorWidget ( )
override
◆ paletteName()
QString pqColorPaletteSelectorWidget::paletteName ( ) const
◆ setPaletteName()
void pqColorPaletteSelectorWidget::setPaletteName ( const QString &  name)
◆ paletteNameChanged
void pqColorPaletteSelectorWidget::paletteNameChanged ( )
signal
Property Documentation
◆ paletteName
readwrite
Definition at line 34 of file pqColorPaletteSelectorWidget.h.
