Public Slots | Signals | Public Member Functions | Properties | List of all members
pqLanguageChooserWidget Class Reference
pqLanguageChooserWidget is a property widget that shows a combo-box with values equal to the currently available translation languages. More...
#include <pqLanguageChooserWidget.h>
Inheritance diagram for pqLanguageChooserWidget:
Collaboration diagram for pqLanguageChooserWidget:
Public Slots
void setValue (QString &value)
 set the default value for the widget among the current items. More...
Signals
void valueChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqLanguageChooserWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqLanguageChooserWidget () override
QString value () const
 get the current selected locale. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QString value
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 17 of file pqLanguageChooserWidget.h.
◆ pqLanguageChooserWidget()
pqLanguageChooserWidget::pqLanguageChooserWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqLanguageChooserWidget()
pqLanguageChooserWidget::~pqLanguageChooserWidget ( )
override
◆ value()
QString pqLanguageChooserWidget::value ( ) const
◆ setValue
void pqLanguageChooserWidget::setValue ( QString &  value)
slot
If the value is not in the items, add it, make it default and re-sort the list alphabetically.
◆ valueChanged
void pqLanguageChooserWidget::valueChanged ( )
signal
Property Documentation
◆ value
readwrite
Definition at line 21 of file pqLanguageChooserWidget.h.
