Signals | Public Member Functions | Properties | Friends | List of all members
pqSelectionQueryPropertyWidget Class Reference
property-widget for creating selection queries. More...
#include <pqSelectionQueryPropertyWidget.h>
Inheritance diagram for pqSelectionQueryPropertyWidget:
Collaboration diagram for pqSelectionQueryPropertyWidget:
Signals
void queryChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqSelectionQueryPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqSelectionQueryPropertyWidget () override
void setQuery (const QString &)
 Get/Set the query string. More...
const QString & query () const
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QString query
Friends
class pqInternals
class pqValueWidget
class pqQueryWidget
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqSelectionQueryPropertyWidget is a pqPropertyWidget subclass that can be used for a property accepting a string representing a selection query. The widget allows users to build selection queries easily.
To use this widget on a property with vtkSMSelectionQueryDomain, set the panel_widget to selection_query (
See also
pqStandardPropertyWidgetInterface).
Caveats
Currently, this widget can faithfully present GUI for query strings that follow a specific form that is generated by this property itself. Any other forms, though valid queries, will not be represented properly in the GUI.
Definition at line 30 of file pqSelectionQueryPropertyWidget.h.
◆ pqSelectionQueryPropertyWidget()
pqSelectionQueryPropertyWidget::pqSelectionQueryPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqSelectionQueryPropertyWidget()
pqSelectionQueryPropertyWidget::~pqSelectionQueryPropertyWidget ( )
override
◆ setQuery()
void pqSelectionQueryPropertyWidget::setQuery ( const QString &  )
◆ query()
const QString& pqSelectionQueryPropertyWidget::query ( ) const
◆ queryChanged
void pqSelectionQueryPropertyWidget::queryChanged ( )
signal
◆ pqInternals
friend class pqInternals
friend
Definition at line 60 of file pqSelectionQueryPropertyWidget.h.
◆ pqValueWidget
friend class pqValueWidget
friend
Definition at line 63 of file pqSelectionQueryPropertyWidget.h.
◆ pqQueryWidget
friend class pqQueryWidget
friend
Definition at line 64 of file pqSelectionQueryPropertyWidget.h.
Property Documentation
◆ query
QString pqSelectionQueryPropertyWidget::query
readwrite
Definition at line 35 of file pqSelectionQueryPropertyWidget.h.
