Signals | Public Member Functions | Properties | List of all members
pqSeriesEditorPropertyWidget Class Reference
pqSeriesEditorPropertyWidget is the pqPropertyWidget used to edit plot-options for a xy-series. More...
#include <pqSeriesEditorPropertyWidget.h>
Inheritance diagram for pqSeriesEditorPropertyWidget:
Collaboration diagram for pqSeriesEditorPropertyWidget:
Signals
void presetLabelChanged ()
void presetColorChanged ()
void seriesVisibilityChanged ()
 Fired when the series visibility changes. More...
void seriesLabelChanged ()
 Fired when the series labels change. More...
void seriesColorChanged ()
 Fired when the series colors change. More...
void seriesOpacityChanged ()
 Fired when the series opacity changes. More...
void seriesLineThicknessChanged ()
 Fired when the series line thickness changes. More...
void seriesLineStyleChanged ()
 Fired when the series line style changes. More...
void seriesMarkerStyleChanged ()
 Fired when the series marker style changes. More...
void seriesMarkerSizeChanged ()
 Fired when the series marker size changes. More...
void seriesPlotCornerChanged ()
 Fired when the series plot corners change. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqSeriesEditorPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqSeriesEditorPropertyWidget () override
QList< QVariant > presetColor () const
void setPresetColor (const QList< QVariant > &)
QList< QVariant > presetLabel () const
void setPresetLabel (const QList< QVariant > &)
QList< QVariant > seriesVisibility () const
 Get/Set the visibility for series. More...
void setSeriesVisibility (const QList< QVariant > &)
QList< QVariant > seriesColor () const
 Get/Set the color for each of the series. More...
void setSeriesColor (const QList< QVariant > &)
QList< QVariant > seriesOpacity () const
 Get/Set the opacity for each of the series. More...
void setSeriesOpacity (const QList< QVariant > &)
QList< QVariant > seriesLabel () const
 Get/Set the label for each of the series. More...
void setSeriesLabel (const QList< QVariant > &)
QList< QVariant > seriesLineThickness () const
 Get/Set the line-thickness for each of the series. More...
void setSeriesLineThickness (const QList< QVariant > &)
QList< QVariant > seriesLineStyle () const
 Get/Set the line-style for each of the series. More...
void setSeriesLineStyle (const QList< QVariant > &)
QList< QVariant > seriesMarkerStyle () const
 Get/Set the marker-style for each of the series. More...
void setSeriesMarkerStyle (const QList< QVariant > &)
QList< QVariant > seriesMarkerSize () const
 Get/Set the marker-size for each of the series. More...
void setSeriesMarkerSize (const QList< QVariant > &)
QList< QVariant > seriesPlotCorner () const
 Get/Set the plot-corner for each of the series. More...
void setSeriesPlotCorner (const QList< QVariant > &)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It works with a property-group with properties for various functions, including required properties (SeriesVisibility) and optional properties (SeriesLabel, SeriesColor, SeriesLineThickness, SeriesLineStyle, SeriesMarkerStyle, and SeriesPlotCorner). If any of optional property functions are missing from the group, the corresponding widgets will be hidden.
Definition at line 23 of file pqSeriesEditorPropertyWidget.h.
◆ pqSeriesEditorPropertyWidget()
pqSeriesEditorPropertyWidget::pqSeriesEditorPropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqSeriesEditorPropertyWidget()
pqSeriesEditorPropertyWidget::~pqSeriesEditorPropertyWidget ( )
override
◆ seriesVisibility()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesVisibility ( ) const
◆ setSeriesVisibility()
void pqSeriesEditorPropertyWidget::setSeriesVisibility ( const QList< QVariant > &  )
◆ seriesColor()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesColor ( ) const
◆ setSeriesColor()
void pqSeriesEditorPropertyWidget::setSeriesColor ( const QList< QVariant > &  )
◆ presetColor()
QList<QVariant> pqSeriesEditorPropertyWidget::presetColor ( ) const
◆ setPresetColor()
void pqSeriesEditorPropertyWidget::setPresetColor ( const QList< QVariant > &  )
◆ seriesOpacity()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesOpacity ( ) const
◆ setSeriesOpacity()
void pqSeriesEditorPropertyWidget::setSeriesOpacity ( const QList< QVariant > &  )
◆ seriesLabel()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesLabel ( ) const
◆ setSeriesLabel()
void pqSeriesEditorPropertyWidget::setSeriesLabel ( const QList< QVariant > &  )
◆ presetLabel()
QList<QVariant> pqSeriesEditorPropertyWidget::presetLabel ( ) const
◆ setPresetLabel()
void pqSeriesEditorPropertyWidget::setPresetLabel ( const QList< QVariant > &  )
◆ seriesLineThickness()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesLineThickness ( ) const
◆ setSeriesLineThickness()
void pqSeriesEditorPropertyWidget::setSeriesLineThickness ( const QList< QVariant > &  )
◆ seriesLineStyle()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesLineStyle ( ) const
◆ setSeriesLineStyle()
void pqSeriesEditorPropertyWidget::setSeriesLineStyle ( const QList< QVariant > &  )
◆ seriesMarkerStyle()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesMarkerStyle ( ) const
◆ setSeriesMarkerStyle()
void pqSeriesEditorPropertyWidget::setSeriesMarkerStyle ( const QList< QVariant > &  )
◆ seriesMarkerSize()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesMarkerSize ( ) const
◆ setSeriesMarkerSize()
void pqSeriesEditorPropertyWidget::setSeriesMarkerSize ( const QList< QVariant > &  )
◆ seriesPlotCorner()
QList<QVariant> pqSeriesEditorPropertyWidget::seriesPlotCorner ( ) const
◆ setSeriesPlotCorner()
void pqSeriesEditorPropertyWidget::setSeriesPlotCorner ( const QList< QVariant > &  )
◆ seriesVisibilityChanged
void pqSeriesEditorPropertyWidget::seriesVisibilityChanged ( )
signal
◆ seriesLabelChanged
void pqSeriesEditorPropertyWidget::seriesLabelChanged ( )
signal
◆ presetLabelChanged
void pqSeriesEditorPropertyWidget::presetLabelChanged ( )
signal
◆ seriesColorChanged
void pqSeriesEditorPropertyWidget::seriesColorChanged ( )
signal
◆ presetColorChanged
void pqSeriesEditorPropertyWidget::presetColorChanged ( )
signal
◆ seriesOpacityChanged
void pqSeriesEditorPropertyWidget::seriesOpacityChanged ( )
signal
◆ seriesLineThicknessChanged
void pqSeriesEditorPropertyWidget::seriesLineThicknessChanged ( )
signal
◆ seriesLineStyleChanged
void pqSeriesEditorPropertyWidget::seriesLineStyleChanged ( )
signal
◆ seriesMarkerStyleChanged
void pqSeriesEditorPropertyWidget::seriesMarkerStyleChanged ( )
signal
◆ seriesMarkerSizeChanged
void pqSeriesEditorPropertyWidget::seriesMarkerSizeChanged ( )
signal
◆ seriesPlotCornerChanged
void pqSeriesEditorPropertyWidget::seriesPlotCornerChanged ( )
signal
Property Documentation
◆ seriesVisibility
readwrite
Definition at line 27 of file pqSeriesEditorPropertyWidget.h.
◆ presetLabel
readwrite
Definition at line 30 of file pqSeriesEditorPropertyWidget.h.
◆ seriesLabel
readwrite
Definition at line 33 of file pqSeriesEditorPropertyWidget.h.
◆ seriesColor
readwrite
Definition at line 36 of file pqSeriesEditorPropertyWidget.h.
◆ seriesOpacity
readwrite
Definition at line 39 of file pqSeriesEditorPropertyWidget.h.
◆ presetColor
readwrite
Definition at line 42 of file pqSeriesEditorPropertyWidget.h.
readwrite
Definition at line 45 of file pqSeriesEditorPropertyWidget.h.
◆ seriesLineStyle
readwrite
Definition at line 48 of file pqSeriesEditorPropertyWidget.h.
◆ seriesMarkerStyle
readwrite
Definition at line 51 of file pqSeriesEditorPropertyWidget.h.
◆ seriesMarkerSize
readwrite
Definition at line 54 of file pqSeriesEditorPropertyWidget.h.
◆ seriesPlotCorner
readwrite
Definition at line 57 of file pqSeriesEditorPropertyWidget.h.
