Public Slots | Public Member Functions | Protected Slots | List of all members
pqCylinderPropertyWidget Class Reference
pqCylinderPropertyWidget is a custom property widget that uses "ImplicitCylinderWidgetRepresentation" to help users interactively set the center, radius and axis for a cylinder. More...
#include <pqCylinderPropertyWidget.h>
Inheritance diagram for pqCylinderPropertyWidget:
Collaboration diagram for pqCylinderPropertyWidget:
Public Slots
void useXAxis ()
 Set the cylinder axis to be along the X axis. More...
void useYAxis ()
 Set the cylinder axis to be along the Y axis. More...
void useZAxis ()
 Set the cylinder axis to be along the Z axis. More...
void resetCameraToAxis ()
 Reset the camera to be down the cylinder axis. More...
void useCameraAxis ()
 Set the cylinder axis to be along the camera view direction. More...
- Public Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
 pqCylinderPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqCylinderPropertyWidget () override
- Public Member Functions inherited from pqInteractivePropertyWidget
 pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidget () override
vtkSMNewWidgetRepresentationProxy * widgetProxy () const
 Returns the proxy for the 3D interactive widget. More...
- Public Member Functions inherited from pqInteractivePropertyWidgetAbstract
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
void reset () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
virtual void apply ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Protected Slots
void placeWidget () override
 Places the interactive widget using current data source information. More...
void resetBounds ()
- Protected Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void placeWidget ()=0
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
- Signals inherited from pqInteractivePropertyWidgetAbstract
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
- Protected Member Functions inherited from pqInteractivePropertyWidget
vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy () final
 Get the internal instance of the widget proxy. More...
- Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
- Protected Attributes inherited from pqInteractivePropertyWidgetAbstract
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
- Properties inherited from pqInteractivePropertyWidgetAbstract
pqSMProxy dataSource
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveCylinder" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Definition at line 27 of file pqCylinderPropertyWidget.h.
◆ pqCylinderPropertyWidget()
pqCylinderPropertyWidget::pqCylinderPropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqCylinderPropertyWidget()
pqCylinderPropertyWidget::~pqCylinderPropertyWidget ( )
override
◆ useXAxis
void pqCylinderPropertyWidget::useXAxis ( )
inlineslot
Definition at line 41 of file pqCylinderPropertyWidget.h.
◆ useYAxis
void pqCylinderPropertyWidget::useYAxis ( )
inlineslot
Definition at line 46 of file pqCylinderPropertyWidget.h.
◆ useZAxis
void pqCylinderPropertyWidget::useZAxis ( )
inlineslot
Definition at line 51 of file pqCylinderPropertyWidget.h.
◆ resetCameraToAxis
void pqCylinderPropertyWidget::resetCameraToAxis ( )
slot
◆ useCameraAxis
void pqCylinderPropertyWidget::useCameraAxis ( )
slot
◆ placeWidget
void pqCylinderPropertyWidget::placeWidget ( )
overrideprotectedslot
◆ resetBounds
void pqCylinderPropertyWidget::resetBounds ( )
protectedslot
