Public Member Functions | List of all members
pqColorSelectorPropertyWidget Class Reference
A property widget with a tool button for selecting a single color. More...
#include <pqColorSelectorPropertyWidget.h>
Inheritance diagram for pqColorSelectorPropertyWidget:
Collaboration diagram for pqColorSelectorPropertyWidget:
 pqColorSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, bool withPalette, QWidget *parent=nullptr)
 ~pqColorSelectorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
To use this widget for a property add the 'panel_widget="color_selector"' attribute to the property's XML. To use this widget for a property whose color might possibly come from the global color palette, add the 'panel_widget="color_selector_with_palette"' attribute to the property's XML.
Definition at line 19 of file pqColorSelectorPropertyWidget.h.
◆ pqColorSelectorPropertyWidget()
pqColorSelectorPropertyWidget::pqColorSelectorPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
bool  withPalette,
QWidget *  parent = nullptr
◆ ~pqColorSelectorPropertyWidget()
pqColorSelectorPropertyWidget::~pqColorSelectorPropertyWidget ( )
override
