Public Member Functions | List of all members
pqDisplayRepresentationPropertyWidget Class Reference
A property widget for selecting the display representation. More...
#include <pqDisplayRepresentationWidget.h>
Inheritance diagram for pqDisplayRepresentationPropertyWidget:
Collaboration diagram for pqDisplayRepresentationPropertyWidget:
 pqDisplayRepresentationPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqDisplayRepresentationPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 79 of file pqDisplayRepresentationWidget.h.
◆ pqDisplayRepresentationPropertyWidget()
pqDisplayRepresentationPropertyWidget::pqDisplayRepresentationPropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqDisplayRepresentationPropertyWidget()
pqDisplayRepresentationPropertyWidget::~pqDisplayRepresentationPropertyWidget ( )
override
