Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | List of all members
pqColorOpacityEditorWidget Class Reference
pqColorOpacityEditorWidget provides an in-line editor widget for editing the color and opacity transfer functions. More...
#include <pqColorOpacityEditorWidget.h>
Inheritance diagram for pqColorOpacityEditorWidget:
Collaboration diagram for pqColorOpacityEditorWidget:
Public Slots
void setXvmsPoints (const QList< QVariant > &)
 Sets the xvmsPoints that control the opacity transfer function. More...
void setXrgbPoints (const QList< QVariant > &)
 Sets the xrgbPoints that control the color transfer function. More...
void setUseLogScale (bool value)
 Set whether to use-log scale. More...
void setUseLogScaleOpacity (bool value)
void setUseOpacityControlPointsFreehandDrawing (bool value)
 Set whether to use freehand drawing for positioning opacity control points. More...
void setShowDataHistogram (bool value)
 Set whether to show data histogram. More...
void setAutomaticDataHistogramComputation (bool value)
 Set whether to automatically compute data histogram. More...
void setDataHistogramNumberOfBins (int value)
 Set the number of bins to use for the data histogram. More...
void setScalarOpacityFunctionProxy (pqSMProxy sofProxy)
 Set the scalar opacity function (or PiecewiseFunction) proxy to use. More...
void setTransferFunction2DProxy (pqSMProxy t2dProxy)
 Set the 2D transfer function (or vtkImageData) proxy to use. More...
void resetRangeToData ()
 Reset the transfer function ranges to active data source. More...
void resetRangeToCustom ()
 Reset the transfer function ranges to custom values. More...
void resetRangeToDataOverTime ()
 Reset the transfer function ranges to temporal range for active data source. More...
void resetRangeToVisibleData ()
 Reset the transfer function ranges to visible range for active data source. More...
void invertTransferFunctions ()
 Inverts the transfer functions. More...
void choosePreset (const char *presetName=nullptr)
 pick a preset. More...
void saveAsPreset ()
 save current transfer function as preset. More...
void computeDataHistogram ()
 Compute the data histogram 1D or 2D. More...
void onRangeHandlesRangeChanged (double rangeMin, double rangeMax)
void resetColorMapComboBox ()
 Resets the color map combo box by setting its index to -1 which sets its text to an empty string. More...
void setTransfer2DBoxes (const QList< QVariant > &)
 Sets the box items that control the 2D transfer function. More...
void chooseBoxColorAlpha ()
 Choose a color and alpha for the currently active 2D transfer function box. More...
Signals
void xrgbPointsChanged ()
 Signal fired when the xrgbPoints change. More...
void xvmsPointsChanged ()
 Signal fired when the xvmsPoints change. More...
void useLogScaleChanged ()
 Signal fired when useLogScale changes. More...
void useLogScaleOpacityChanged ()
 Signal fired when useLogScaleOpacity changes. More...
void useOpacityControlPointsFreehandDrawingChanged ()
 Signal fired when useOpacityControlPointsFreehandDrawing changes. More...
void showDataHistogramChanged ()
 Signal fired when showDataHistogram changes. More...
void automaticDataHistogramComputationChanged ()
 Signal fired when automaticDataHistogramComputation changes. More...
void dataHistogramNumberOfBinsEdited ()
 Signal fired when dataHistogramNumberOfBins changes. More...
void scalarOpacityFunctionProxyChanged ()
 This signal is never really fired since this widget doesn't have any UI to allow users to changes the ScalarOpacityFunction proxy used. More...
void transferFunction2DProxyChanged ()
 Signal fired when the transfer function 2D proxy is changed. More...
void transfer2DBoxesChanged ()
 Signal fired when the transfer function 2d boxes change. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqColorOpacityEditorWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqColorOpacityEditorWidget () override
void updateWidget (bool showing_advanced_properties) override
 updates the panel to show/hide advanced settings More...
QList< QVariant > xrgbPoints () const
 Returns the current list of control points for the color transfer function. More...
QList< QVariant > xvmsPoints () const
 Returns the current list of control points for the opacity function. More...
bool useLogScale () const
 Returns the value for use-log-scale. More...
bool useLogScaleOpacity () const
bool useOpacityControlPointsFreehandDrawing () const
 Returns the value for the use of freehand drawing when positioning opacity control points. More...
bool showDataHistogram () const
 Returns the value for showDataHistogram. More...
bool automaticDataHistogramComputation () const
 Returns the value for automaticDataHistogramComputation. More...
int dataHistogramNumberOfBins () const
 Returns the value for dataHistogramNumberOfBins. More...
pqSMProxy scalarOpacityFunctionProxy () const
 Returns the scalar opacity function (i.e. More...
pqSMProxy transferFunction2DProxy () const
 Returns the 2D transfer function (i.e. More...
bool using2DTransferFunction () const
 Returns the value for Using2DTransferFunction internal server-manager property. More...
QList< QVariant > transfer2DBoxes () const
 Returns the current list of boxes for the 2D transfer function. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void opacityCurrentChanged (vtkIdType)
 slots called when the current point changes on the two internal pqTransferFunctionWidget widgets. More...
void colorCurrentChanged (vtkIdType)
void updateCurrentData ()
 updates the text shown in the "current data" input. More...
void currentDataEdited ()
 update the transfer function with the text in CurrentDataValue text field. More...
void presetApplied ()
 called when a preset is applied. More...
void updateDefaultPresetsList ()
 Updates the default presets combo box when the list changes. More...
void multiComponentsMappingChanged (vtkObject *, unsigned long, void *, void *)
 called when "MultiComponentsMappingChanged" checkbox is modified. More...
void useLogScaleClicked (bool)
 called when the use-log-scale checkbox is clicked by the user. More...
void useLogScaleOpacityClicked (bool)
void useOpacityControlPointsFreehandDrawingClicked (bool)
 Called when UseOpacityControlPointsFreehandDrawing checkbox is clicked by the user. More...
void showDataHistogramClicked (bool show=true)
 Called when the showDataHistogram checkbox is clicked by the user. More...
void show2DHistogram (bool show=true)
 Called when the use2DTransferFunction checkbox is clicked by the user. More...
void automaticDataHistogramComputationClicked (bool val)
 Called when the automaticDataHistogramComputation checkbox is clicked by the user. More...
void dataHistogramNumberOfBinsEdited (int val)
 Called when the dataHistogramNumberOfBins is changed by the user. More...
void updateDataHistogramEnableState ()
 Update the enable state of different data histogram related widgets. More...
void representationOrViewChanged ()
 called when the active representation or view changes. More...
void setHistogramOutdated ()
 Called when the histogram should be considered outdated, which includes : When the range of the transfer function is changed, either from a custom range or from an updated range When the vector mode or vector component is changed When the visibility of a consumer is changed When the number of bins is changed When the 2D transfer function arrays are changed. More...
void realShowDataHistogram ()
 Slot called by a timer which is triggered in showDataHistogramClicked This method actually setup the histogram but should not be used directly. More...
void realShow2DHistogram ()
 Slot called by a timer which is triggered in show2DHistogram This method actually sets up the 2D histogram. More...
void transfer2DChanged ()
 Slot to update active representation when the 2D transfer function has changed with the internal pqTransferFunction2DWidget class. More...
void opacityFunctionModified ()
 Slot to update active representation when the piecewise function for opacity is modified. More...
void updateTransferFunction2DProxy ()
 Slot to update the 2D transfer function proxy when the Y axis scalar array is changed. More...
void prepareRangeForLogScaling ()
 Validate and adjust the current range before converting to a log range. More...
void initializeOpacityEditor (vtkPiecewiseFunction *pwf)
 Initialize the opacity editor. More...
void initializeTransfer2DEditor (vtkPVTransferFunction2D *tf2d)
 Initialize the 2D transfer function editor. More...
void observeRepresentationModified (vtkSMProxy *reprProxy, vtkPiecewiseFunction *pwf)
 When representation has changed, gotta reconnect some internal observers. More...
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Properties
bool useLogScale
template<class T >
The property group is expected to have properties with the following functions. If any of the optional properties are missing, then the corresponding widgets are hidden.
Definition at line 50 of file pqColorOpacityEditorWidget.h.
◆ pqColorOpacityEditorWidget()
pqColorOpacityEditorWidget::pqColorOpacityEditorWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqColorOpacityEditorWidget()
pqColorOpacityEditorWidget::~pqColorOpacityEditorWidget ( )
override
◆ updateWidget()
void pqColorOpacityEditorWidget::updateWidget ( bool  showing_advanced_properties)
Reimplemented from pqPropertyWidget.
◆ xrgbPoints()
QList<QVariant> pqColorOpacityEditorWidget::xrgbPoints ( ) const
This a list of 4-tuples.
◆ xvmsPoints()
QList<QVariant> pqColorOpacityEditorWidget::xvmsPoints ( ) const
◆ useLogScale()
bool pqColorOpacityEditorWidget::useLogScale ( ) const
◆ useLogScaleOpacity()
bool pqColorOpacityEditorWidget::useLogScaleOpacity ( ) const
◆ useOpacityControlPointsFreehandDrawing()
bool pqColorOpacityEditorWidget::useOpacityControlPointsFreehandDrawing ( ) const
◆ showDataHistogram()
bool pqColorOpacityEditorWidget::showDataHistogram ( ) const
◆ automaticDataHistogramComputation()
bool pqColorOpacityEditorWidget::automaticDataHistogramComputation ( ) const
◆ dataHistogramNumberOfBins()
int pqColorOpacityEditorWidget::dataHistogramNumberOfBins ( ) const
◆ scalarOpacityFunctionProxy()
pqSMProxy pqColorOpacityEditorWidget::scalarOpacityFunctionProxy ( ) const
PiecewiseFunction) proxy used, if any.
◆ transferFunction2DProxy()
pqSMProxy pqColorOpacityEditorWidget::transferFunction2DProxy ( ) const
vtkImageData) proxy used, if any.
◆ using2DTransferFunction()
bool pqColorOpacityEditorWidget::using2DTransferFunction ( ) const
◆ transfer2DBoxes()
QList<QVariant> pqColorOpacityEditorWidget::transfer2DBoxes ( ) const
This a list of 8-tuples - [x0, y0, width, height, r, g, b, opacity].
◆ setXvmsPoints
void pqColorOpacityEditorWidget::setXvmsPoints ( const QList< QVariant > &  )
slot
◆ setXrgbPoints
void pqColorOpacityEditorWidget::setXrgbPoints ( const QList< QVariant > &  )
slot
◆ setUseLogScale
void pqColorOpacityEditorWidget::setUseLogScale ( bool  value)
slot
◆ setUseLogScaleOpacity
void pqColorOpacityEditorWidget::setUseLogScaleOpacity ( bool  value)
slot
◆ setUseOpacityControlPointsFreehandDrawing
void pqColorOpacityEditorWidget::setUseOpacityControlPointsFreehandDrawing ( bool  value)
slot
◆ setShowDataHistogram
void pqColorOpacityEditorWidget::setShowDataHistogram ( bool  value)
slot
◆ setAutomaticDataHistogramComputation
void pqColorOpacityEditorWidget::setAutomaticDataHistogramComputation ( bool  value)
slot
◆ setDataHistogramNumberOfBins
void pqColorOpacityEditorWidget::setDataHistogramNumberOfBins ( int  value)
slot
◆ setScalarOpacityFunctionProxy
void pqColorOpacityEditorWidget::setScalarOpacityFunctionProxy ( pqSMProxy  sofProxy)
slot
◆ setTransferFunction2DProxy
void pqColorOpacityEditorWidget::setTransferFunction2DProxy ( pqSMProxy  t2dProxy)
slot
◆ resetRangeToData
void pqColorOpacityEditorWidget::resetRangeToData ( )
slot
◆ resetRangeToCustom
void pqColorOpacityEditorWidget::resetRangeToCustom ( )
slot
◆ resetRangeToDataOverTime
void pqColorOpacityEditorWidget::resetRangeToDataOverTime ( )
slot
◆ resetRangeToVisibleData
void pqColorOpacityEditorWidget::resetRangeToVisibleData ( )
slot
◆ invertTransferFunctions
void pqColorOpacityEditorWidget::invertTransferFunctions ( )
slot
◆ choosePreset
void pqColorOpacityEditorWidget::choosePreset ( const char *  presetName = nullptr)
slot
pick a preset.
◆ saveAsPreset
void pqColorOpacityEditorWidget::saveAsPreset ( )
slot
◆ computeDataHistogram
void pqColorOpacityEditorWidget::computeDataHistogram ( )
slot
Depends on the "Using2DTransferFunction" internal property.
◆ onRangeHandlesRangeChanged
void pqColorOpacityEditorWidget::onRangeHandlesRangeChanged ( double  rangeMin,
double  rangeMax
slot
◆ resetColorMapComboBox
void pqColorOpacityEditorWidget::resetColorMapComboBox ( )
slot
◆ setTransfer2DBoxes
void pqColorOpacityEditorWidget::setTransfer2DBoxes ( const QList< QVariant > &  )
slot
◆ chooseBoxColorAlpha
void pqColorOpacityEditorWidget::chooseBoxColorAlpha ( )
slot
◆ xrgbPointsChanged
void pqColorOpacityEditorWidget::xrgbPointsChanged ( )
signal
◆ xvmsPointsChanged
void pqColorOpacityEditorWidget::xvmsPointsChanged ( )
signal
◆ useLogScaleChanged
void pqColorOpacityEditorWidget::useLogScaleChanged ( )
signal
◆ useLogScaleOpacityChanged
void pqColorOpacityEditorWidget::useLogScaleOpacityChanged ( )
signal
◆ useOpacityControlPointsFreehandDrawingChanged
void pqColorOpacityEditorWidget::useOpacityControlPointsFreehandDrawingChanged ( )
signal
◆ showDataHistogramChanged
void pqColorOpacityEditorWidget::showDataHistogramChanged ( )
signal
◆ automaticDataHistogramComputationChanged
void pqColorOpacityEditorWidget::automaticDataHistogramComputationChanged ( )
signal
◆ dataHistogramNumberOfBinsEdited [1/2]
void pqColorOpacityEditorWidget::dataHistogramNumberOfBinsEdited ( )
signal
◆ scalarOpacityFunctionProxyChanged
void pqColorOpacityEditorWidget::scalarOpacityFunctionProxyChanged ( )
signal
◆ transferFunction2DProxyChanged
void pqColorOpacityEditorWidget::transferFunction2DProxyChanged ( )
signal
◆ transfer2DBoxesChanged
void pqColorOpacityEditorWidget::transfer2DBoxesChanged ( )
signal
◆ opacityCurrentChanged
void pqColorOpacityEditorWidget::opacityCurrentChanged ( vtkIdType  )
protectedslot
◆ colorCurrentChanged
void pqColorOpacityEditorWidget::colorCurrentChanged ( vtkIdType  )
protectedslot
◆ updateCurrentData
void pqColorOpacityEditorWidget::updateCurrentData ( )
protectedslot
◆ currentDataEdited
void pqColorOpacityEditorWidget::currentDataEdited ( )
protectedslot
◆ presetApplied
void pqColorOpacityEditorWidget::presetApplied ( )
protectedslot
◆ updateDefaultPresetsList
void pqColorOpacityEditorWidget::updateDefaultPresetsList ( )
protectedslot
◆ multiComponentsMappingChanged
void pqColorOpacityEditorWidget::multiComponentsMappingChanged ( vtkObject *  ,
unsigned long  ,
void *  ,
void *
protectedslot
◆ useLogScaleClicked
void pqColorOpacityEditorWidget::useLogScaleClicked ( bool  )
protectedslot
We then add extra logic to valid ranges convert the color map to log/linear space.
◆ useLogScaleOpacityClicked
void pqColorOpacityEditorWidget::useLogScaleOpacityClicked ( bool  )
protectedslot
◆ useOpacityControlPointsFreehandDrawingClicked
void pqColorOpacityEditorWidget::useOpacityControlPointsFreehandDrawingClicked ( bool  )
protectedslot
We transfer the call to the pqTransferFunctionEditor.
◆ showDataHistogramClicked
void pqColorOpacityEditorWidget::showDataHistogramClicked ( bool  show = true)
protectedslot
We then add extra logic to compute and update the histogram and enable to update histogram button. This uses the histogram table cache if it is up to date. This can be called manually to show/hide the histogram
◆ show2DHistogram
void pqColorOpacityEditorWidget::show2DHistogram ( bool  show = true)
protectedslot
◆ automaticDataHistogramComputationClicked
void pqColorOpacityEditorWidget::automaticDataHistogramComputationClicked ( bool  val)
protectedslot
We then add extra logic to show the histogram and update the UI.
◆ dataHistogramNumberOfBinsEdited [2/2]
void pqColorOpacityEditorWidget::dataHistogramNumberOfBinsEdited ( int  val)
protectedslot
We then add extra logic to set the histogram outdated
◆ updateDataHistogramEnableState
void pqColorOpacityEditorWidget::updateDataHistogramEnableState ( )
protectedslot
◆ representationOrViewChanged
void pqColorOpacityEditorWidget::representationOrViewChanged ( )
protectedslot
We then change the enabled/disabled state of the buttons. Some actions require a valid representation or view, so disable them if there isn't one. We also update the opacity editor.
◆ setHistogramOutdated
void pqColorOpacityEditorWidget::setHistogramOutdated ( )
protectedslot
◆ realShowDataHistogram
void pqColorOpacityEditorWidget::realShowDataHistogram ( )
protectedslot
◆ realShow2DHistogram
void pqColorOpacityEditorWidget::realShow2DHistogram ( )
protectedslot
◆ transfer2DChanged
void pqColorOpacityEditorWidget::transfer2DChanged ( )
protectedslot
◆ opacityFunctionModified
void pqColorOpacityEditorWidget::opacityFunctionModified ( )
protectedslot
For ex, editing the midpoint, sharpness around a piecewise control point modifies the function.
◆ updateTransferFunction2DProxy
void pqColorOpacityEditorWidget::updateTransferFunction2DProxy ( )
protectedslot
◆ prepareRangeForLogScaling()
void pqColorOpacityEditorWidget::prepareRangeForLogScaling ( )
◆ initializeOpacityEditor()
void pqColorOpacityEditorWidget::initializeOpacityEditor ( vtkPiecewiseFunction *  pwf)
◆ initializeTransfer2DEditor()
void pqColorOpacityEditorWidget::initializeTransfer2DEditor ( vtkPVTransferFunction2D *  tf2d)
◆ observeRepresentationModified()
void pqColorOpacityEditorWidget::observeRepresentationModified ( vtkSMProxy *  reprProxy,
Property Documentation
◆ xrgbPoints
readwrite
Definition at line 53 of file pqColorOpacityEditorWidget.h.
◆ xvmsPoints
readwrite
Definition at line 54 of file pqColorOpacityEditorWidget.h.
◆ showDataHistogram
readwrite
Definition at line 55 of file pqColorOpacityEditorWidget.h.
readwrite
Definition at line 57 of file pqColorOpacityEditorWidget.h.
readwrite
Definition at line 59 of file pqColorOpacityEditorWidget.h.
◆ useLogScale
readwrite
Definition at line 60 of file pqColorOpacityEditorWidget.h.
readwrite
Definition at line 61 of file pqColorOpacityEditorWidget.h.
readwrite
Definition at line 63 of file pqColorOpacityEditorWidget.h.
readwrite
Definition at line 65 of file pqColorOpacityEditorWidget.h.
readwrite
Definition at line 67 of file pqColorOpacityEditorWidget.h.
◆ transfer2DBoxes
readwrite
Definition at line 68 of file pqColorOpacityEditorWidget.h.
