Public Member Functions | List of all members
pqSessionTypeDecorator Class Reference
decorator to show/hide or enable/disable property widget based on the session. More...
#include <pqSessionTypeDecorator.h>
Inheritance diagram for pqSessionTypeDecorator:
Collaboration diagram for pqSessionTypeDecorator:
 pqSessionTypeDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
 ~pqSessionTypeDecorator () override
bool canShowWidget (bool show_advanced) const override
 Methods overridden from pqPropertyWidget. More...
bool enableWidget () const override
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
pqSessionTypeDecorator is a pqPropertyWidgetDecorator subclass that can be used to show/hide or enable/disable a pqPropertyWidget based on the current session.
The XML config for this decorate takes two attributes 'requires' and 'mode'. 'mode' can have values 'visibility' or 'enabled_state' which dictates whether the decorator shows/hides or enables/disables the widget respectively.
'requires' can have values 'remote', 'parallel', 'parallel_data_server', or 'parallel_render_server' indicating if the session must be remote, or parallel with either data server or render server having more than 1 rank, or parallel data-server, or parallel render-server respectively.
Definition at line 29 of file pqSessionTypeDecorator.h.
◆ pqSessionTypeDecorator()
pqSessionTypeDecorator::pqSessionTypeDecorator ( vtkPVXMLElement *  config,
◆ ~pqSessionTypeDecorator()
pqSessionTypeDecorator::~pqSessionTypeDecorator ( )
override
◆ canShowWidget()
bool pqSessionTypeDecorator::canShowWidget ( bool  show_advanced) const
Reimplemented from pqPropertyWidgetDecorator.
◆ enableWidget()
bool pqSessionTypeDecorator::enableWidget ( ) const
