Signals | Public Member Functions | Properties | List of all members
pqFileListPropertyWidget Class Reference
list widget for file selection More...
#include <pqFileListPropertyWidget.h>
Inheritance diagram for pqFileListPropertyWidget:
Collaboration diagram for pqFileListPropertyWidget:
Signals
void fileNamesChanged ()
 Signal fired when filenames are changed. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqFileListPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqFileListPropertyWidget () override
const QStringList & fileNames () const
 Get/Set the filenames. More...
void setFileNames (const QStringList &filenames)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QStringList fileNames
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqFileListPropertyWidget is intended to be used with properties that allow users to select files (or directories). Instead of showing a single input widget, which is the case by default (see pqStringVectorPropertyWidget), this custom widget shows a list (rather a table) with all the selected filenames. Users can add/remove files.
To use this widget on your string-vector property, set the panel widget to "file_list".
For example:
<SourceProxy name="TestSource" >
<StringVectorProperty name="Files"
command="..."
default_values="/tmp/test.txt"
number_of_elements="1"
repeatable="1"
number_of_elements_per_command="1"
panel_widget="file_list">
<FileListDomain name="files"/>
</StringVectorProperty>
</SourceProxy>
Definition at line 43 of file pqFileListPropertyWidget.h.
◆ pqFileListPropertyWidget()
pqFileListPropertyWidget::pqFileListPropertyWidget ( vtkSMProxy *  smproxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
explicit
◆ ~pqFileListPropertyWidget()
pqFileListPropertyWidget::~pqFileListPropertyWidget ( )
override
◆ fileNames()
const QStringList& pqFileListPropertyWidget::fileNames ( ) const
◆ setFileNames()
void pqFileListPropertyWidget::setFileNames ( const QStringList &  filenames)
◆ fileNamesChanged
void pqFileListPropertyWidget::fileNamesChanged ( )
signal
Property Documentation
◆ fileNames
QStringList pqFileListPropertyWidget::fileNames
readwrite
Definition at line 47 of file pqFileListPropertyWidget.h.
