Public Slots | Signals | Public Member Functions | Properties | List of all members
pqViewTypePropertyWidget Class Reference
pqViewTypePropertyWidget is a property widget that shows a combo-box with values equal to the currently available types of views. More...
#include <pqViewTypePropertyWidget.h>
Inheritance diagram for pqViewTypePropertyWidget:
Collaboration diagram for pqViewTypePropertyWidget:
Public Slots
void setValue (const QString &value)
 set the value for the widget. More...
Signals
void valueChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqViewTypePropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqViewTypePropertyWidget () override
QString value () const
 get the current value in the widget More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QString value
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
This could have been implemented as a domain, but I was being lazy :).
Definition at line 18 of file pqViewTypePropertyWidget.h.
◆ pqViewTypePropertyWidget()
pqViewTypePropertyWidget::pqViewTypePropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqViewTypePropertyWidget()
pqViewTypePropertyWidget::~pqViewTypePropertyWidget ( )
override
◆ value()
QString pqViewTypePropertyWidget::value ( ) const
◆ setValue
void pqViewTypePropertyWidget::setValue ( const QString &  value)
slot
◆ valueChanged
void pqViewTypePropertyWidget::valueChanged ( )
signal
Property Documentation
◆ value
readwrite
Definition at line 22 of file pqViewTypePropertyWidget.h.
