Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | List of all members
pqYoungsMaterialPropertyWidget Class Reference
This is a custom widget for YoungsMaterialInterface filter. More...
#include <pqYoungsMaterialPropertyWidget.h>
Inheritance diagram for pqYoungsMaterialPropertyWidget:
Collaboration diagram for pqYoungsMaterialPropertyWidget:
Signals
void orderingArraysChanged ()
 Emitted when the ordering arrays change, linked ot the SMProperty. More...
void normalArraysChanged ()
 Emitted when the normal arrays change, linked ot the SMProperty. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqYoungsMaterialPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parent=nullptr)
 ~pqYoungsMaterialPropertyWidget () override
void setOrderingArrays (const QList< QVariant > &)
 Get/Set the ordering arrays, linked to the SMProperty. More...
QList< QVariant > orderingArrays () const
void setNormalArrays (const QList< QVariant > &)
 Get/Set the normal arrays, linked to the SMProperty. More...
QList< QVariant > normalArrays () const
- Public Member Functions inherited from pqStringVectorPropertyWidget
 pqStringVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqStringVectorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void onOrderingArraysChanged ()
 Called when the ordering array is changed. More...
void onNormalArraysChanged ()
 Called when the normal array is changed. More...
void updateComboBoxes ()
 Called to initialize/update the combobox according to the current item. More...
QStandardItem * currentItem ()
 Recover the currently selecticted item in the VolumeFractionArrays widget. More...
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Properties
- Static Public Member Functions inherited from pqStringVectorPropertyWidget
static pqPropertyWidget * createWidget (vtkSMStringVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr)
 Factory method to instantiate a hard-coded type of pqPropertyWidget subclass for t he vtkSMStringVectorProperty. More...
static void processFileChooserHints (vtkPVXMLElement *hints, bool &directoryMode, bool &anyFile, QString &filter, bool &browseLocalFileSystem)
 Method to process file-choice related hints. More...
template<class T >
We use a custom widget since this filter has unusual requirements when it comes to setting OrderingArrays and NormalArrays properties.
Definition at line 20 of file pqYoungsMaterialPropertyWidget.h.
◆ pqYoungsMaterialPropertyWidget()
pqYoungsMaterialPropertyWidget::pqYoungsMaterialPropertyWidget ( vtkSMProxy *  proxy,
vtkSMPropertyGroup *  group,
QWidget *  parent = nullptr
◆ ~pqYoungsMaterialPropertyWidget()
pqYoungsMaterialPropertyWidget::~pqYoungsMaterialPropertyWidget ( )
override
◆ setOrderingArrays()
void pqYoungsMaterialPropertyWidget::setOrderingArrays ( const QList< QVariant > &  )
◆ orderingArrays()
QList<QVariant> pqYoungsMaterialPropertyWidget::orderingArrays ( ) const
◆ setNormalArrays()
void pqYoungsMaterialPropertyWidget::setNormalArrays ( const QList< QVariant > &  )
◆ normalArrays()
QList<QVariant> pqYoungsMaterialPropertyWidget::normalArrays ( ) const
◆ orderingArraysChanged
void pqYoungsMaterialPropertyWidget::orderingArraysChanged ( )
signal
◆ normalArraysChanged
void pqYoungsMaterialPropertyWidget::normalArraysChanged ( )
signal
◆ currentItem()
QStandardItem* pqYoungsMaterialPropertyWidget::currentItem ( )
◆ onOrderingArraysChanged
void pqYoungsMaterialPropertyWidget::onOrderingArraysChanged ( )
protectedslot
◆ onNormalArraysChanged
void pqYoungsMaterialPropertyWidget::onNormalArraysChanged ( )
protectedslot
◆ updateComboBoxes
void pqYoungsMaterialPropertyWidget::updateComboBoxes ( )
protectedslot
Property Documentation
◆ orderingArrays
readwrite
Definition at line 26 of file pqYoungsMaterialPropertyWidget.h.
◆ normalArrays
readwrite
