Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqXYChartViewBoundsPropertyWidget Class Reference
Extract bottom left axis range into a property. More...
#include <pqXYChartViewBoundsPropertyWidget.h>
Inheritance diagram for pqXYChartViewBoundsPropertyWidget:
Collaboration diagram for pqXYChartViewBoundsPropertyWidget:
Signals
void boundsChanged ()
 Signal fired whenever the bounds are changed. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqXYChartViewBoundsPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqXYChartViewBoundsPropertyWidget () override
QList< QVariant > bounds ()
 Get/Set the chart bounds. More...
void setBounds (const QList< QVariant > &bounds)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void resetBounds ()
 Extract bounds from the current pqXYChartView if any. More...
void onTextChanged ()
 Called when the text is changed in order to update the internally stored bounds. More...
void updateTextFromBounds ()
 Called when the bounds are changed externally to update the texts. More...
void showEvent (QShowEvent *event) override
 Initialize the bounds on the first show. More...
void connectToView (pqView *view)
 Called whenever the active view change Keep track of the active view and connect to pqXYChartView axis range property to manage the reset button. More...
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
A property widget that extract bottom and left axis range from a pqXYChartView if it is the current active view into a 4 component double vector property.
A reset button is added in order to actually perform the extraction.
Definition at line 23 of file pqXYChartViewBoundsPropertyWidget.h.
◆ pqXYChartViewBoundsPropertyWidget()
pqXYChartViewBoundsPropertyWidget::pqXYChartViewBoundsPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
explicit
◆ ~pqXYChartViewBoundsPropertyWidget()
pqXYChartViewBoundsPropertyWidget::~pqXYChartViewBoundsPropertyWidget ( )
override
◆ bounds()
QList<QVariant> pqXYChartViewBoundsPropertyWidget::bounds ( )
Size should always be 4.
◆ setBounds()
void pqXYChartViewBoundsPropertyWidget::setBounds ( const QList< QVariant > &  bounds)
◆ boundsChanged
void pqXYChartViewBoundsPropertyWidget::boundsChanged ( )
signal
◆ resetBounds
void pqXYChartViewBoundsPropertyWidget::resetBounds ( )
protectedslot
◆ onTextChanged
void pqXYChartViewBoundsPropertyWidget::onTextChanged ( )
protectedslot
◆ updateTextFromBounds
void pqXYChartViewBoundsPropertyWidget::updateTextFromBounds ( )
protectedslot
◆ showEvent
void pqXYChartViewBoundsPropertyWidget::showEvent ( QShowEvent *  event)
overrideprotectedslot
◆ connectToView
void pqXYChartViewBoundsPropertyWidget::connectToView ( pqView *  view)
protectedslot
Property Documentation
◆ bounds
readwrite
Definition at line 26 of file pqXYChartViewBoundsPropertyWidget.h.
