Public Types | Public Member Functions | List of all members
pqColorEditorPropertyWidget Class Reference
This is a pqPropertyWidget subclass that presents a widget to edit the color of a representation and other related functionality. More...
#include <pqColorEditorPropertyWidget.h>
Inheritance diagram for pqColorEditorPropertyWidget:
Collaboration diagram for pqColorEditorPropertyWidget:
typedef pqPropertyWidget Superclass
 pqColorEditorPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqColorEditorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It's used as the "widget" for ColorEditor property group.
Definition at line 14 of file pqColorEditorPropertyWidget.h.
Definition at line 18 of file pqColorEditorPropertyWidget.h.
◆ pqColorEditorPropertyWidget()
pqColorEditorPropertyWidget::pqColorEditorPropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqColorEditorPropertyWidget()
pqColorEditorPropertyWidget::~pqColorEditorPropertyWidget ( )
override
