Public Member Functions | List of all members
pqGenericPropertyWidgetDecorator Class Reference
pqGenericPropertyWidgetDecorator is a pqPropertyWidgetDecorator that supports multiple common use cases from a pqPropertyWidgetDecorator. More...
#include <pqGenericPropertyWidgetDecorator.h>
Inheritance diagram for pqGenericPropertyWidgetDecorator:
Collaboration diagram for pqGenericPropertyWidgetDecorator:
 pqGenericPropertyWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
 ~pqGenericPropertyWidgetDecorator () override
bool canShowWidget (bool show_advanced) const override
 Methods overridden from pqPropertyWidget. More...
bool enableWidget () const override
 Override this method to override the enable state of the widget in the panel. More...
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
The use cases supported are as follows:
Definition at line 27 of file pqGenericPropertyWidgetDecorator.h.
◆ pqGenericPropertyWidgetDecorator()
pqGenericPropertyWidgetDecorator::pqGenericPropertyWidgetDecorator ( vtkPVXMLElement *  config,
◆ ~pqGenericPropertyWidgetDecorator()
pqGenericPropertyWidgetDecorator::~pqGenericPropertyWidgetDecorator ( )
override
◆ canShowWidget()
bool pqGenericPropertyWidgetDecorator::canShowWidget ( bool  show_advanced) const
Reimplemented from pqPropertyWidgetDecorator.
◆ enableWidget()
bool pqGenericPropertyWidgetDecorator::enableWidget ( ) const
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget disabled given the current state.
