Public Slots | Signals | Public Member Functions | Properties | List of all members
pqCameraManipulatorWidget Class Reference
pqCameraManipulatorWidget used on "Camera2DManipulators" and "Camera3DManipulators" property on a RenderView proxy. More...
#include <pqCameraManipulatorWidget.h>
Inheritance diagram for pqCameraManipulatorWidget:
Collaboration diagram for pqCameraManipulatorWidget:
Public Slots
void setManipulatorTypes (const QList< QVariant > &value)
 Set the manipulator types selection. More...
Signals
void manipulatorTypesChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqCameraManipulatorWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqCameraManipulatorWidget () override
QList< QVariant > manipulatorTypes () const
 returns a list for the selected manipulator types. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 14 of file pqCameraManipulatorWidget.h.
◆ pqCameraManipulatorWidget()
pqCameraManipulatorWidget::pqCameraManipulatorWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqCameraManipulatorWidget()
pqCameraManipulatorWidget::~pqCameraManipulatorWidget ( )
override
◆ manipulatorTypes()
QList<QVariant> pqCameraManipulatorWidget::manipulatorTypes ( ) const
This has exactly 9 items always.
◆ setManipulatorTypes
void pqCameraManipulatorWidget::setManipulatorTypes ( const QList< QVariant > &  value)
slot
This must have exactly 9 items or less. Any missing items are treated as "None".
◆ manipulatorTypesChanged
void pqCameraManipulatorWidget::manipulatorTypesChanged ( )
signal
Property Documentation
◆ manipulatorTypes
readwrite
Definition at line 18 of file pqCameraManipulatorWidget.h.
