Signals | Public Member Functions | Properties | List of all members
pqListPropertyWidget Class Reference
pqListPropertyWidget is a pqPropertyWidget that is used to show an editable list of elements. More...
#include <pqListPropertyWidget.h>
Inheritance diagram for pqListPropertyWidget:
Collaboration diagram for pqListPropertyWidget:
Signals
void valueChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqListPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqListPropertyWidget () override
QList< QVariant > value () const
 Methods used to set/get the value for the widget. More...
void setValue (const QList< QVariant > &value)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
This is suitable for int/idtype/double/string vector properties with multiple elements, useful for allowing the user to change a range of values without adding or removing entries from it.
Definition at line 20 of file pqListPropertyWidget.h.
◆ pqListPropertyWidget()
pqListPropertyWidget::pqListPropertyWidget ( vtkSMProxy *  smproxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
explicit
◆ ~pqListPropertyWidget()
pqListPropertyWidget::~pqListPropertyWidget ( )
override
◆ value()
QList<QVariant> pqListPropertyWidget::value ( ) const
◆ setValue()
void pqListPropertyWidget::setValue ( const QList< QVariant > &  value)
◆ valueChanged
void pqListPropertyWidget::valueChanged ( )
signal
Property Documentation
◆ value
readwrite
Definition at line 24 of file pqListPropertyWidget.h.
