Public Member Functions | List of all members
pqShowWidgetDecorator Class Reference
pqShowWidgetDecorator can be used to show/hide a widget based on the status of another property not directly controlled by the widget. More...
#include <pqShowWidgetDecorator.h>
Inheritance diagram for pqShowWidgetDecorator:
Collaboration diagram for pqShowWidgetDecorator:
 pqShowWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
bool canShowWidget (bool show_advanced) const override
 Override this method to override the visibility of the widget in the panel. More...
- Public Member Functions inherited from pqBoolPropertyWidgetDecorator
 pqBoolPropertyWidgetDecorator (vtkPVXMLElement *config, pqPropertyWidget *parent)
 ~pqBoolPropertyWidgetDecorator () override
bool isBoolProperty () const
- Public Member Functions inherited from pqPropertyWidgetDecorator
 pqPropertyWidgetDecorator (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Constructor. More...
 ~pqPropertyWidgetDecorator () override
pqPropertyWidget * parentWidget () const
 Returns the pqPropertyWidget parent. More...
virtual bool enableWidget () const
 Override this method to override the enable state of the widget in the panel. More...
- Signals inherited from pqBoolPropertyWidgetDecorator
void boolPropertyChanged ()
- Signals inherited from pqPropertyWidgetDecorator
void visibilityChanged ()
 This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
void enableStateChanged ()
- Static Public Member Functions inherited from pqPropertyWidgetDecorator
static pqPropertyWidgetDecorator * create (vtkPVXMLElement *xml, pqPropertyWidget *parent)
 Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator. More...
- Protected Member Functions inherited from pqPropertyWidgetDecorator
vtkPVXMLElement * xml () const
- Protected Attributes inherited from pqBoolPropertyWidgetDecorator
vtkWeakPointer< vtkSMProperty > Property
QString Function
int Index
unsigned long ObserverId
bool BoolProperty
QString Value
Definition at line 15 of file pqShowWidgetDecorator.h.
◆ pqShowWidgetDecorator()
pqShowWidgetDecorator::pqShowWidgetDecorator ( vtkPVXMLElement *  config,
◆ canShowWidget()
bool pqShowWidgetDecorator::canShowWidget ( bool  show_advanced) const
inlineoverridevirtual
This is called after the generic tests for advanced and text filtering are passed. Since there can be multiple decorators, the first decorator that returns 'false' wins. Default implementation returns true. Thus subclasses typically override this method only to force the widget invisible given the current state.
Reimplemented from pqPropertyWidgetDecorator.
Definition at line 23 of file pqShowWidgetDecorator.h.
