Public Member Functions | Protected Slots | List of all members
pqCalculatorWidget Class Reference
pqCalculatorWidget is a property-widget that can shows a calculator-like UI for the property. More...
#include <pqCalculatorWidget.h>
Inheritance diagram for pqCalculatorWidget:
Collaboration diagram for pqCalculatorWidget:
 pqCalculatorWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqCalculatorWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void variableChosen (QAction *action)
 called when the user selects a variable from the scalars/vectors menus. More...
void buttonPressed (const QString &)
 called when user clicks one of the function buttons More...
void updateVariableNames ()
 updates the variables in the menus. More...
void updateVariables (const QString &mode)
void updateButtons ()
 Update button labels based on which function parser is active. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It is designed to be used with vtkPVArrayCalculator (or similar) filters. It allows users to enter expressions to compute derived quantities. To determine the list of input arrays available.
CAVEATS: Currently, this widget expects two additional properties on the proxy: "Input", that provides the input and "AttributeMode", which corresponds to the chosen attribute type. This code can be revised to use RequiredProperties on the domain to make it reuseable, if needed.
Definition at line 20 of file pqCalculatorWidget.h.
◆ pqCalculatorWidget()
pqCalculatorWidget::pqCalculatorWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqCalculatorWidget()
pqCalculatorWidget::~pqCalculatorWidget ( )
override
◆ variableChosen
void pqCalculatorWidget::variableChosen ( QAction *  action)
protectedslot
◆ buttonPressed
void pqCalculatorWidget::buttonPressed ( const QString &  )
protectedslot
◆ updateVariableNames
void pqCalculatorWidget::updateVariableNames ( )
protectedslot
◆ updateVariables
void pqCalculatorWidget::updateVariables ( const QString &  mode)
protectedslot
◆ updateButtons
void pqCalculatorWidget::updateButtons ( )
protectedslot
