Public Member Functions | List of all members
pqViewResolutionPropertyWidget Class Reference
widget for view resolution. More...
#include <pqViewResolutionPropertyWidget.h>
Inheritance diagram for pqViewResolutionPropertyWidget:
Collaboration diagram for pqViewResolutionPropertyWidget:
Signals
void highlightResetButton ()
 internal signals used to highlight (or not) the "reset-to-domain" button. More...
void clearHighlight ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqViewResolutionPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqViewResolutionPropertyWidget () override
void apply () override
 Overridden to clear the state for the highlight state for "reset-to-domain" button. More...
void reset () override
 ~pqPropertyWidget () override
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqViewResolutionPropertyWidget is desined to be used with properties that allow users to set resolution for things like views, images, movies etc. It provides UI elements to lock aspect ratio, scale size up or down, and reset to default.
This widget works with any vtkSMIntVectorProperty with 2 elements interpreted as (width, height).
As specified in pqStandardPropertyWidgetInterface, to use this widget for a property you can use panel_widget="view_resolution" attribute in ServerManager XML.
Definition at line 27 of file pqViewResolutionPropertyWidget.h.
◆ pqViewResolutionPropertyWidget()
pqViewResolutionPropertyWidget::pqViewResolutionPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  smproperty,
QWidget *  parent = nullptr
◆ ~pqViewResolutionPropertyWidget()
pqViewResolutionPropertyWidget::~pqViewResolutionPropertyWidget ( )
override
◆ apply()
void pqViewResolutionPropertyWidget::apply ( )
The implementation simply fires clearHighlight signal.
Reimplemented from pqPropertyWidget.
◆ reset()
void pqViewResolutionPropertyWidget::reset ( )
◆ highlightResetButton
void pqViewResolutionPropertyWidget::highlightResetButton ( )
signal
◆ clearHighlight
void pqViewResolutionPropertyWidget::clearHighlight ( )
signal
