Signals | Public Member Functions | List of all members
pqPropertyCollectionWidget Class Reference
property widget for properties representing collection of parameters. More...
#include <pqPropertyCollectionWidget.h>
Inheritance diagram for pqPropertyCollectionWidget:
Collaboration diagram for pqPropertyCollectionWidget:
Signals
void widgetModified ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqPropertyCollectionWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqPropertyCollectionWidget () override
bool event (QEvent *e) override
 Overridden to handle QDynamicPropertyChangeEvent events. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqPropertyCollectionWidget is designed for a specific use-case: a group of properties on a proxy all of which are repeatable vector properties (i.e. vtkSMVectorProperty subclasses) where each repeatable item in the collection is to be edited together. Another way of describing the same is that each vector property in the group defines a column in a table with user having the ability to add and remove rows to this table. However, instead of showing a literal tabular widget to edit values in each row, a prototype proxy definition is provided using hints.
Example proxy definition(s) that use this widget is as follows:
<SourceProxy class="vtkSteeringDataGenerator" name="Oscillators">
<DoubleVectorProperty name="Center"
command="SetTuple3Double"
use_index="1"
clean_command="Clear"
initial_string="coords"
number_of_elements_per_command="3"
repeat_command="1">
</DoubleVectorProperty>
<IntVectorProperty name="Type"
command="SetTuple1Int"
use_index="1"
initial_string="type"
number_of_elements_per_command="1"
repeat_command="1">
</IntVectorProperty>
<PropertyGroup label="Oscillators" panel_widget="PropertyCollection">
<Property name="Center" function="PrototypeCenter" />
<Property name="Type" function="PrototypeType" />
<!-- here, "name" identifies the property on this proxy, while
"function" identifies the property on the prototype proxy. If
"function" is not specified, same value as "name" is assumed. -->
<Hints>
<PropertyCollectionWidgetPrototype group="misc" name="OscillatorPrototype" />
</Hints>
</PropertyGroup>
</SourceProxy>
The prototype proxy to use to build the UI for each row in this table that has two columns for "Center" and "Type" is identified using the PropertyCollectionWidgetPrototype hint added to the PropertyGroup element. Following is an example definition:
<ProxyGroup name="misc">
<Proxy name="OscillatorPrototype" label="Oscillator" >
<DoubleVectorProperty name="PrototypeCenter"
label="Center"
number_of_elements="3"
default_values="0 0 0">
<DoubleRangeDomain name="range" />
<Documentation>
Specify center for the oscillator.
</Documentation>
<IntVectorProperty name="PrototypeType"
label="Type"
number_of_elements="1"
default_values="0">
<EnumerationDomain name="enum">
<Entry text="damped" value="0" />
<Entry text="decaying" value="1" />
<Entry text="periodic" value="2" />
</EnumerationDomain>
</Proxy>
</ProxyGroup>
A few things to note:
Definition at line 100 of file pqPropertyCollectionWidget.h.
◆ pqPropertyCollectionWidget()
pqPropertyCollectionWidget::pqPropertyCollectionWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqPropertyCollectionWidget()
pqPropertyCollectionWidget::~pqPropertyCollectionWidget ( )
override
◆ event()
bool pqPropertyCollectionWidget::event ( QEvent *  e)
override
◆ widgetModified
void pqPropertyCollectionWidget::widgetModified ( )
signal
