Signals | Public Member Functions | Properties | List of all members
pqDataAssemblyPropertyWidget Class Reference
pqPropertyWidget for properties with vtkDataAssembly More...
#include <pqDataAssemblyPropertyWidget.h>
Inheritance diagram for pqDataAssemblyPropertyWidget:
Collaboration diagram for pqDataAssemblyPropertyWidget:
Signals
void selectorsChanged ()
void colorsChanged ()
void opacitiesChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqDataAssemblyPropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 pqDataAssemblyPropertyWidget (vtkSMProxy *smproxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqDataAssemblyPropertyWidget () override
void updateWidget (bool showing_advanced_properties) override
void setSelectors (const QStringList &paths)
 API for getting/setting selected/chosen path strings. More...
const QStringList & selectors () const
void setSelectors (const QList< QVariant > &paths)
QList< QVariant > selectorsAsVariantList () const
void setCompositeIndices (const QList< QVariant > &values)
 API for getting/settings composite indices. More...
QList< QVariant > compositeIndicesAsVariantList () const
void setCompositeIndexColors (const QList< QVariant > &values)
 API to get/set colors. More...
QList< QVariant > compositeIndexColorsAsVariantList () const
void setSelectorColors (const QList< QVariant > &values)
QList< QVariant > selectorColorsAsVariantList () const
void setCompositeIndexOpacities (const QList< QVariant > &values)
 API to get/set opacities. More...
QList< QVariant > compositeIndexOpacitiesAsVariantList () const
void setSelectorOpacities (const QList< QVariant > &values)
QList< QVariant > selectorOpacitiesAsVariantList () const
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
 Property with selectors for checked nodes in the hierarchy. More...
 Property with selectors and associated colors (as RGB). More...
 Property with selectors and associated opacities. More...
 These are similar to the selector-based variants, except, instead of a selector, the composite index is used. More...
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqDataAssemblyPropertyWidget is intended for properties that rely on a vtkDataAssembly i.e. use a vtkSMDataAssemblyDomain. This supports getting/setting the list of selectors for checked nodes based on the chosen vtkDataAssembly. Further more, it supports editing color and opacity, if requested.
pqDataAssemblyPropertyWidget can be used on a single property with a vtkSMDataAssemblyDomain or for a group of properties. For a single property, it allows for editing on selectors for checked nodes. For a group, it can support opacity and color editing as well.
Here's an example proxy XML for a single property.
<Proxy ...>
<StringVectorProperty name="Selectors"
repeat_command="1"
number_of_elements_per_command="1"
default_values="/" >
<DataAssemblyDomain name="data_assembly">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyDomain>
</StringVectorProperty>
</Proxy>
The widget will use the assembly provided by vtkSMDataAssemblyDomain::GetDataAssembly to render a tree in UI.
A property-group for editing color and opacity, along with choosing which named-assembly to use is as follows. All properties in the group are optional and one may specify on subset that is relevant for their use-case. It is assumed, however, that all properties in the group use the same data assembly. If that's not the case, one should use separate property groups, hence separate widgets, for each.
<Proxy ...>
<StringVectorProperty name="Assembly"
command="SetAssemblyName"
number_of_elements="1">
<DataAssemblyListDomain name="data_assembly_list">
</DataAssemblyListDomain>
<Documentation>
Select which assembly is used when specify selectors
to choose blocks to show for composite datasets.
</Documentation>
command="AddSelector"
clean_command="ClearSelectors"
repeat_command="1"
number_of_elements_per_command="1">
<Property function="ActiveAssembly" name="Assembly" />
<Documentation>
For composite datasets, specify selectors to limit the view
to a chosen subset of blocks.
</Documentation>
<StringVectorProperty name="BlockColor"
element_types="2 1 1 1"
number_of_elements_per_command="4"
repeat_command="1">
<StringVectorProperty name="BlockOpacity"
element_types="2 1"
number_of_elements_per_command="2"
repeat_command="1">
<PropertyGroup label="Blocks" panel_widget="DataAssemblyEditor">
<Property name="Assembly" function="ActiveAssembly" />
<Property name="Selectors" function="Selectors" />
<Property name="BlockColor" function="Colors" />
<Property name="BlockOpacity" function="Opacities" />
</PropertyGroup>
</Proxy>
This widget is primarily intended for vtkSMDataAssemblyDomain. However, to support legacy code that uses vtkSMCompositeTreeDomain instead, we add support for vtkSMCompositeTreeDomain as well. It is required, however, that all properties in the group to consistently use vtkSMDataAssemblyDomain or vtkSMCompositeTreeDomain and mixing is not allowed.
Hints
This widget supports hints that can be added to the group (or property). For example:
<PropertyGroup label="AssemblyOnly" panel_widget="DataAssemblyEditor">
<Hints>
<DataAssemblyPropertyWidget
is_checkable="0"
use_inputname_as_header="1"
link_active_selection="1"
</Hints>
</PropertyGroup>
is_checkable can be set to 0 to avoid showing checkboxes for items in the tree.
use_inputname_as_header, when set to 1 causes the widget to use the input's registration name as the header for the tree widget rather than the XML label for the group (or property) attached to the widget.
link_active_selection, when set to 1 causes the widget to track the active block-selection and vice-versa.
Definition at line 158 of file pqDataAssemblyPropertyWidget.h.
◆ pqDataAssemblyPropertyWidget() [1/2]
pqDataAssemblyPropertyWidget::pqDataAssemblyPropertyWidget ( vtkSMProxy *  smproxy,
QWidget *  parent = nullptr
◆ pqDataAssemblyPropertyWidget() [2/2]
vtkSMProperty *  smproperty,
◆ ~pqDataAssemblyPropertyWidget()
pqDataAssemblyPropertyWidget::~pqDataAssemblyPropertyWidget ( )
override
◆ setSelectors() [1/2]
void pqDataAssemblyPropertyWidget::setSelectors ( const QStringList &  paths)
◆ selectors()
const QStringList& pqDataAssemblyPropertyWidget::selectors ( ) const
◆ setSelectors() [2/2]
void pqDataAssemblyPropertyWidget::setSelectors ( const QList< QVariant > &  paths)
◆ selectorsAsVariantList()
QList<QVariant> pqDataAssemblyPropertyWidget::selectorsAsVariantList ( ) const
◆ setCompositeIndices()
void pqDataAssemblyPropertyWidget::setCompositeIndices ( const QList< QVariant > &  values)
◆ compositeIndicesAsVariantList()
QList<QVariant> pqDataAssemblyPropertyWidget::compositeIndicesAsVariantList ( ) const
◆ setCompositeIndexColors()
void pqDataAssemblyPropertyWidget::setCompositeIndexColors ( const QList< QVariant > &  values)
Colors are specified either as a list of selectors followed by corresponding RGB color or list of composite indices followed by the color.
◆ compositeIndexColorsAsVariantList()
QList<QVariant> pqDataAssemblyPropertyWidget::compositeIndexColorsAsVariantList ( ) const
◆ setSelectorColors()
void pqDataAssemblyPropertyWidget::setSelectorColors ( const QList< QVariant > &  values)
◆ selectorColorsAsVariantList()
QList<QVariant> pqDataAssemblyPropertyWidget::selectorColorsAsVariantList ( ) const
◆ setCompositeIndexOpacities()
void pqDataAssemblyPropertyWidget::setCompositeIndexOpacities ( const QList< QVariant > &  values)
Opacities are specified either as a list of selectors followed by corresponding opacity or list of composite indices followed by the opacity.
◆ compositeIndexOpacitiesAsVariantList()
QList<QVariant> pqDataAssemblyPropertyWidget::compositeIndexOpacitiesAsVariantList ( ) const
◆ setSelectorOpacities()
void pqDataAssemblyPropertyWidget::setSelectorOpacities ( const QList< QVariant > &  values)
◆ selectorOpacitiesAsVariantList()
QList<QVariant> pqDataAssemblyPropertyWidget::selectorOpacitiesAsVariantList ( ) const
◆ updateWidget()
void pqDataAssemblyPropertyWidget::updateWidget ( bool  showing_advanced_properties)
Reimplemented from pqPropertyWidget.
◆ selectorsChanged
void pqDataAssemblyPropertyWidget::selectorsChanged ( )
signal
◆ colorsChanged
void pqDataAssemblyPropertyWidget::colorsChanged ( )
signal
◆ opacitiesChanged
void pqDataAssemblyPropertyWidget::opacitiesChanged ( )
signal
Property Documentation
◆ selectors
readwrite
Definition at line 167 of file pqDataAssemblyPropertyWidget.h.
◆ selectorColors
readwrite
◆ selectorOpacities
readwrite
Definition at line 173 of file pqDataAssemblyPropertyWidget.h.
◆ compositeIndices
readwrite
This is used when supported vtkSMCompositeTreeDomain-based properties.
Definition at line 179 of file pqDataAssemblyPropertyWidget.h.
readwrite
Definition at line 188 of file pqDataAssemblyPropertyWidget.h.
readwrite
Definition at line 190 of file pqDataAssemblyPropertyWidget.h.
