Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqIndexSelectionWidget Class Reference
pqIndexSelectionWidget displays a list of labels and slider widgets, intended to be used for selecting an index into a zero-based enumeration. More...
#include <pqIndexSelectionWidget.h>
Inheritance diagram for pqIndexSelectionWidget:
Collaboration diagram for pqIndexSelectionWidget:
Public Slots
void setHeaderLabel (const QString &str)
void setPushPropertyName (const QByteArray &pName)
Signals
void widgetModified ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqIndexSelectionWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqIndexSelectionWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void currentChanged (const QString &current)
void currentChanged (int current)
void currentChanged ()
void updateProperty ()
 Start a timer that calls updatePropertyImpl. More...
void updatePropertyImpl ()
 Update the Qt property with current widget state. More...
bool eventFilter (QObject *obj, QEvent *e) override
void propertyChanged ()
 Update the widget state from the PropertyLink Qt property. More...
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
template<class T >
Definition at line 22 of file pqIndexSelectionWidget.h.
◆ pqIndexSelectionWidget()
pqIndexSelectionWidget::pqIndexSelectionWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
◆ ~pqIndexSelectionWidget()
pqIndexSelectionWidget::~pqIndexSelectionWidget ( )
override
◆ setHeaderLabel
void pqIndexSelectionWidget::setHeaderLabel ( const QString &  str)
slot
◆ setPushPropertyName
void pqIndexSelectionWidget::setPushPropertyName ( const QByteArray &  pName)
slot
◆ widgetModified
void pqIndexSelectionWidget::widgetModified ( )
signal
◆ currentChanged [1/3]
void pqIndexSelectionWidget::currentChanged ( const QString &  current)
protectedslot
◆ currentChanged [2/3]
void pqIndexSelectionWidget::currentChanged ( int  current)
protectedslot
◆ currentChanged [3/3]
void pqIndexSelectionWidget::currentChanged ( )
protectedslot
◆ updateProperty
void pqIndexSelectionWidget::updateProperty ( )
protectedslot
This slot is triggered when a widget is modified.
◆ updatePropertyImpl
void pqIndexSelectionWidget::updatePropertyImpl ( )
protectedslot
Emits widgetModified.
◆ eventFilter()
bool pqIndexSelectionWidget::eventFilter ( QObject *  obj,
QEvent *  e
◆ propertyChanged()
void pqIndexSelectionWidget::propertyChanged ( )
