Public Member Functions | Protected Slots | List of all members
pqCommandButtonPropertyWidget Class Reference
A property widget with a push button for invoking a command on a proxy. More...
#include <pqCommandButtonPropertyWidget.h>
Inheritance diagram for pqCommandButtonPropertyWidget:
Collaboration diagram for pqCommandButtonPropertyWidget:
 pqCommandButtonPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqCommandButtonPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
virtual void buttonClicked ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
To use this widget for a property add the 'panel_widget="command_button"' to the property's XML.
If the property has a "command" attribute set, then the command will be invoked immediately. If the property has no command set, then clicking the button will call vtkSMProxy::RecreateVTKObjects().
Definition at line 20 of file pqCommandButtonPropertyWidget.h.
◆ pqCommandButtonPropertyWidget()
pqCommandButtonPropertyWidget::pqCommandButtonPropertyWidget ( vtkSMProxy *  proxy,
vtkSMProperty *  property,
QWidget *  parent = nullptr
explicit
◆ ~pqCommandButtonPropertyWidget()
pqCommandButtonPropertyWidget::~pqCommandButtonPropertyWidget ( )
override
◆ buttonClicked
virtual void pqCommandButtonPropertyWidget::buttonClicked ( )
protectedvirtualslot
