proxy for a VTK object(s) on a server More...
#include <vtkSMProxy.h>
| enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
| enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
| Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
| Retrieve an annotation with a given key. More... | |
| Remove a given annotation based on its key to the proxy. More... | |
| Remove all proxy annotations. More... | |
| Return true if a given annotation exists. More... | |
| Return the number of available annotations. More... | |
| Return the nth key of the available annotations. More... | |
| Return the property with the given name. More... | |
| Return a property of the given name from self or one of the sub-proxies. More... | |
| Given a property pointer, returns the name that was used to add it to the proxy. More... | |
| Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
| Recreate the VTK object for this proxy. More... | |
| Convenience method equivalent to UpdateProperty(name, 1). More... | |
| Returns a new (initialized) iterator of the properties. More... | |
| Returns the number of consumers. More... | |
| Returns the consumer of given index. More... | |
| Returns the corresponding property of the consumer of given index. More... | |
| Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
| Returns a proxy this proxy depends on, given index. More... | |
| Returns the property holding a producer proxy given an index. More... | |
| Updates all property information by calling UpdateInformation() and populating the values. More... | |
| Similar to UpdatePropertyInformation() but updates only the given property. More... | |
| Marks all properties as modified. More... | |
| Use this method to set all properties on this proxy to their default values. More... | |
| Use this method to set all properties on this proxy to their default domains. More... | |
| Use this method to set all properties on this proxy to their default domain or values. More... | |
| Calls MarkDirty() and invokes ModifiedEvent. More... | |
| Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
| Dirty means this algorithm will execute during next update. More... | |
| Returns the client side object associated with the VTKObjectID (if any). More... | |
| Saves the state of the proxy. More... | |
| The iterator is use to filter the property available on the given proxy. More... | |
| Loads the proxy state from the XML element. More... | |
| This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
| bool | GetIsSubProxy () |
| A proxy instance can be a sub-proxy for some other proxy. More... | |
| If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
| Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| Returns the number of property groups that the proxy contains. More... | |
| Update the value of one property (pushed to the server) if it is modified. More... | |
| Returns the type of object managed by the proxy. More... | |
| the type of object created by the proxy. More... | |
| Copies values of all the properties and sub-proxies from src. More... | |
| Returns if the VTK objects for this proxy have been created. More... | |
| Gathers information about this proxy. More... | |
| Log name is a name for this proxy that will be used when logging status messages. More... | |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
| vtkSMProxy () | |
| ~vtkSMProxy () override | |
| Invoke that takes a vtkClientServerStream as the argument. More... | |
| Add a property with the given key (name). More... | |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
| Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
| Cleanup code. More... | |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
| Add a sub-proxy. More... | |
| Remove a sub-proxy. More... | |
| Returns a sub-proxy. More... | |
| Returns the name used to store sub-proxy. More... | |
| Returns the number of sub-proxies. More... | |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
| Remove the property,proxy pair from the list of consumers. More... | |
| Remove all consumers. More... | |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
| Remove the property,proxy pair from the list of producers. More... | |
| This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
| Parses the XML to create a new property group. More... | |
| Adds a property groups. More... | |
| Expose a subproxy property from the base proxy. More... | |
| Handle events fired by subproxies. More... | |
| Called to update the property information on the property. More... | |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
Internal method used by SetLogName More... | |
| Indicates if any properties are modified. More... | |
| vtkSMProxy (const vtkSMProxy &)=delete | |
| Get the last result. More... | |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
| Read attributes from an XML element. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Friends | |
| class | vtkSMProxyInfo |
| class | vtkSMCameraLink |
| These classes have been declared as friends to minimize the public interface exposed by vtkSMProxy. More... | |
| class | vtkSMCompoundProxy |
| class | vtkSMCompoundSourceProxy |
| class | vtkSMInputProperty |
| class | vtkSMOrderedPropertyIterator |
| class | vtkSMPart |
| class | vtkSMProperty |
| class | vtkSMPropertyIterator |
| class | vtkSMNamedPropertyIterator |
| class | vtkSMSessionProxyManager |
| class | vtkSMProxyObserver |
| class | vtkSMProxyProperty |
| class | vtkSMProxyRegisterUndoElement |
| class | vtkSMProxyUnRegisterUndoElement |
| class | vtkSMSourceProxy |
| class | vtkSMUndoRedoStateLoader |
| class | vtkSMDeserializerProtobuf |
| class | vtkSMStateLocator |
| class | vtkSMMultiServerSourceProxy |
| class | vtkSMStateLoader |
| char * | SIClassName |
| SIClassName identifies the classname for the helper on the server side. More... | |
vtkSMProxy manages VTK object(s) that are created on a server using the proxy pattern. The managed object is manipulated through properties. The type of object created and managed by vtkSMProxy is determined by the VTKClassName variable. The object is managed by getting the desired property from the proxy, changing it's value and updating the server with UpdateVTKObjects(). A proxy can be composite. Sub-proxies can be added by the proxy manager. This is transparent to the user who sees all properties as if they belong to the root proxy.
A proxy keeps an iVar ConnectionID. This is the connection ID for the connection on which this proxy exists. Currently, since a ParaView client is connected to 1 and only 1 server. This ID is insignificant. However, it provides the ground work to enable a client to connect with multiple servers. ConnectionID must be set immediately after instantiating the proxy (if at all). Changing the ConnectionID after that can be dangerous.
Once a proxy has been defined, it can be listed in another secondary group
When defining a proxy in the XML configuration file, to derive the property interface from another proxy definition, we can use attributes "base_proxygroup" and "base_proxyname" which identify the proxy group and proxy name of another proxy. Base interfaces can be defined recursively, however care must be taken to avoid cycles.
There are several special XML features available for subproxies.
Definition at line 152 of file vtkSMProxy.h.
Definition at line 156 of file vtkSMProxy.h.
| Enumerator | |
| DEFAULT | |
| ONLY_XML | |
| ONLY_DOMAIN | |
Definition at line 381 of file vtkSMProxy.h.
| anonymous enum |
| Enumerator | |
| COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE | |
| COPY_PROXY_PROPERTY_VALUES_BY_CLONING | |
Definition at line 402 of file vtkSMProxy.h.
protecteddelete |
Reimplemented from vtkSMRemoteObject.
Reimplemented in vtkSMMultiplexerSourceProxy, vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMOutputPort, vtkSMLoadStateOptionsProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMCompoundSourceProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMDataDeliveryManagerProxy, vtkSMPVRepresentationProxy, vtkSMNewWidgetRepresentationProxy, vtkSMRenderViewProxy, vtkSMSaveAnimationProxy, vtkSMContextViewProxy, vtkSMSaveAnimationExtractsProxy, vtkSMLiveInsituLinkProxy, vtkSMComparativeViewProxy, vtkSMTransferFunctionProxy, vtkSMPythonViewProxy, vtkSMComparativeAnimationCueProxy, vtkPVRepresentationAnimationHelper, vtkSMCSVExporterProxy, vtkSMExporterProxy, vtkSMDataSourceProxy, vtkSMImageExtractWriterProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMMultiServerSourceProxy, vtkSMExtractTriggerProxy, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMDirectoryProxy, vtkSMPWriterProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMRenderViewExporterProxy, vtkSMExtractWriterProxy, vtkSMPluginLoaderProxy, vtkSMPSWriterProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMaterialLibraryProxy, vtkSMMultiSliceViewProxy, vtkSMAnimationSceneProxy, vtkSMDataExtractWriterProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMGL2PSExporterProxy, vtkSMEnsembleDataReaderProxy, vtkSMNullProxy, vtkSMTimeKeeperProxy, and vtkSMOrthographicSliceViewProxy.
Reimplemented in vtkSMRepresentationProxy, vtkSMSettingsProxy, vtkSMViewProxy, vtkSMViewLayoutProxy, vtkSMSourceProxy, vtkSMPVMoleculeRepresentationProxy, vtkSMSelfGeneratingSourceProxy, vtkSMSaveScreenshotProxy, vtkSMDataDeliveryManagerProxy, vtkSMPVRepresentationProxy, vtkSMNewWidgetRepresentationProxy, vtkSMRenderViewProxy, vtkSMContextViewProxy, vtkSMComparativeViewProxy, vtkSMTransferFunctionProxy, vtkSMPythonViewProxy, vtkSMComparativeAnimationCueProxy, vtkSMImageExtractWriterProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMWriterProxy, vtkSMBoxRepresentationProxy, vtkSMCinemaVolumetricImageExtractWriterProxy, vtkSMPWriterProxy, vtkSMSpreadSheetViewProxy, vtkSMWidgetRepresentationProxy, vtkSMPSWriterProxy, vtkSMImplicitPlaneRepresentationProxy, vtkSMLightProxy, vtkSMMaterialLibraryProxy, vtkSMMultiSliceViewProxy, vtkSMCameraProxy, vtkSMChartRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMSpreadSheetRepresentationProxy, vtkSMTextWidgetRepresentationProxy, vtkSMTimeKeeperProxy, and vtkSMOrthographicSliceViewProxy.
If not found, this will return NULL.
| void vtkSMProxy::RemoveAnnotation | ( | const char * | key | ) |
| void vtkSMProxy::RemoveAllAnnotations | ( | ) |
| bool vtkSMProxy::HasAnnotation | ( | const char * | key | ) |
| int vtkSMProxy::GetNumberOfAnnotations | ( | ) |
Get/Set the location where the underlying VTK-objects are created.
The value can be constructed by or-ing vtkSMSession::ServerFlags
inlinevirtual |
If no property is found NULL is returned.
Definition at line 205 of file vtkSMProxy.h.
If selfOnly is set, the sub-proxies are not checked.
| const char* vtkSMProxy::GetPropertyName | ( | vtkSMProperty * | prop | ) |
Returns NULL if the property is not in the proxy. If the property belongs to a sub-proxy, it returns the exposed name or NULL if the property is not exposed.
If the object has not been created, it will be created first.
Reimplemented in vtkSMCompoundSourceProxy, vtkSMMaterialLibraryProxy, vtkSMBoxRepresentationProxy, and vtkSMEnsembleDataReaderProxy.
This is a convenient mechanism to create a new VTK object with the same state as an existing one in its stead.
If the object has not been created, it will be created first. If force is true, the property is pushed even if it not modified. Return true if UpdateProperty pushes the property value.
Definition at line 247 of file vtkSMProxy.h.
Definition at line 254 of file vtkSMProxy.h.
This is used only when creating the server objects. Once the server object(s) have been created, changing this has no effect.
| unsigned int vtkSMProxy::GetNumberOfConsumers | ( | ) |
Consumers are proxies that point to this proxy through a property (usually vtkSMProxyProperty)
| vtkSMProxy* vtkSMProxy::GetConsumerProxy | ( | unsigned int | idx | ) |
| vtkSMProperty* vtkSMProxy::GetConsumerProperty | ( | unsigned int | idx | ) |
| unsigned int vtkSMProxy::GetNumberOfProducers | ( | ) |
| vtkSMProxy* vtkSMProxy::GetProducerProxy | ( | unsigned int | idx | ) |
| vtkSMProperty* vtkSMProxy::GetProducerProperty | ( | unsigned int | idx | ) |
Note that this is a property of this proxy and it points to the producer proxy.
Assigned by the XML parser.
The name assigned in the XML configuration. Can be used to figure out the origin of the proxy.
The group in the XML configuration that this proxy belongs to. Can be used to figure out the origin of the proxy.
The label assigned in the XML configuration. This is a more user-friendly name for the proxy, although it's cannot be used to locate the proxy.
Reimplemented in vtkSMCameraProxy, and vtkSMBoxRepresentationProxy.
If the property does not belong to the proxy, the call is ignored.
This will cause them all to be sent to be sent on the next call to UpdateVTKObjects. This method is useful when the proxy is first created to make sure that the default property values in the properties is synced with the values in the actual objects.
This iterates over all properties on this proxy, thus if this proxy had subproxies, this method will iterate over only the exposed properties and call vtkSMProperty::ResetToXMLDefaults().
This iterates over all properties on this proxy, thus if this proxy had subproxies, this method will iterate over only the exposed properties and call vtkSMProperty::ResetToDomainDefaults().
This iterates over all properties on this proxy, thus if this proxy had subproxies, this method will iterate over only the exposed properties and call correct reset methods. The parameter allows to choose between resetting ONLY_XML, ONLY_DOMAIN or DEFAULT, ie. reset to domain if available, if not reset to xml. default value is DEFAULT.
| void vtkSMProxy::Copy | ( | vtkSMProxy * | src | ) |
NOTE: This does NOT create properties and sub-proxies. Only copies values. Mismatched property and sub-proxy pairs are ignored. Properties of type exceptionClass are not copied. This is usually vtkSMInputProperty. proxyPropertyCopyFlag specifies how the values for vtkSMProxyProperty and its subclasses are copied over: by reference or by cloning (ie. creating new instances of the value proxies and synchronizing their values). This is no longer relevant since we don't support COPY_PROXY_PROPERTY_VALUES_BY_CLONING anymore.
| void vtkSMProxy::Copy | ( | vtkSMProxy * | src, |
| const char * | exceptionClass | ||
Returns the documentation for this proxy.
Hints are metadata associated with the proxy. The Server Manager does not (and should not) interpret the hints. Hints provide a mechanism to add GUI pertinant information to the server manager XML. Returns the XML element for the hints associated with this proxy, if any, otherwise returns NULL.
| void vtkSMProxy::InitializeAndCopyFromProxy | ( | vtkSMProxy * | source | ) |
This method copies connection id as well as server ids. This method can be called only once on an uninitialized proxy (CreateVTKObjects() also initialized a proxy) This is useful to make two (or more) proxies represent the same VTK object. This method does not copy IDs for any subproxies.
This all marks all consumers as dirty.
Reimplemented in vtkSMRenderViewProxy, vtkSMSourceProxy, vtkSMRepresentationProxy, vtkSMComparativeViewProxy, and vtkSMMultiServerSourceProxy.
| vtkObjectBase* vtkSMProxy::GetClientSideObject | ( | ) |
Returns 0 otherwise.
| bool vtkSMProxy::GatherInformation | ( | vtkPVInformation * | information | ) |
On success, the information object is filled up with details about the VTK object.
| bool vtkSMProxy::GatherInformation | ( | vtkPVInformation * | information, |
| vtkTypeUInt32 | location | ||
This state can be reloaded to create a new proxy that is identical the present state of this proxy. The resulting proxy's XML hieratchy is returned, in addition if the root argument is not NULL then it's also inserted as a nested element. This call saves all a proxy's properties, including exposed properties and sub-proxies. More control is provided by the following overload.
Reimplemented in vtkSMViewLayoutProxy, and vtkSMComparativeAnimationCueProxy.
Reimplemented in vtkSMViewLayoutProxy, vtkSMMultiplexerSourceProxy, vtkSMComparativeAnimationCueProxy, and vtkSMSelfGeneratingSourceProxy.
Returns 0 on failure. locator is used to locate other proxies that may be referred to in the state XML (which happens in case of properties of type vtkSMProxyProperty or subclasses). If locator is NULL, then such properties are left unchanged.
Reimplemented in vtkSMViewLayoutProxy, vtkSMRepresentationProxy, vtkSMMultiplexerSourceProxy, vtkSMComparativeAnimationCueProxy, vtkSMAnimationSceneProxy, and vtkSMSelfGeneratingSourceProxy.
Allow user to set the remote object to be discard for Undo/Redo action.
By default, any remote object is Undoable. This override the RemoteObject ones to propagate the flag to the sub-proxy
| void vtkSMProxy::UpdateSelfAndAllInputs | ( | ) |
The sources are found by getting the Input of all the filter along the pipeline.
| bool vtkSMProxy::GetIsSubProxy | ( | ) |
In that case, this method returns true.
| vtkSMProxy* vtkSMProxy::GetParentProxy | ( | ) |
| vtkSMProxy* vtkSMProxy::GetTrueParentProxy | ( | ) |
May return this instance, if this is not a subproxy of any other proxy.
Allow to switch off any push of state change to the server for that particular object.
This is used when we load a state based on a server notification. In that particular case, the server is already aware of that new state, so we keep those changes local.
Enable the given remote object to communicate its state normally to the server location.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMViewLayoutProxy.
| vtkSMPropertyGroup* vtkSMProxy::GetPropertyGroup | ( | size_t | index | ) | const |
| size_t vtkSMProxy::GetNumberOfPropertyGroups | ( | ) | const |
| void vtkSMProxy::SetLogName | ( | const char * | name | ) |
This helps make the log more user friendly by making sure it uses names that the user can easily map to objects shown in the user interface.
This method will set the log name for this proxy and iterate over all subproxies and set log name for each using the provided name as prefix.
Furthermore, for all properties with vtkSMProxyListDomain, it will set log name for proxies in those domains to use the provided name as prefix as well.
| const char* vtkSMProxy::GetLogNameOrDefault | ( | ) |
A helper that makes up an default name if none is provided.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
The name can then be used to retrieve the property with GetProperty(). If a property with the given name has been added before, it will be replaced. This includes properties in sub-proxies.
protectedvirtual |
protectedvirtual |
This provides the consumer with potentially useful insight about which producer the modification is coming from which can be useful e.g. vtkSMRepresentationProxy.
Default implementation simply calls this->MarkDirty(modifiedProxy).
Reimplemented in vtkSMRepresentationProxy.
While this does not mean that the pipeline will re-execute, it does indicate that the pipeline could execute and hence to ensure we update data information (and other state) correctly when PostUpdateData gets called, need to ensure the upstream pipeline on the proxy side realizes it may need update. This method simply toggles NeedsUpdate flag and propagate up the producer chain through input properties.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
It is used to figure out the origin of the definition of that proxy. By default, it stay NULL, only in-line subProxy do specify this field so when the definition is sent to the server, it can retrieve the in-line definition of that proxy.
protectedvirtual |
Reimplemented in vtkSMPVRepresentationProxy, vtkSMViewProxy, vtkSMRenderViewProxy, vtkSMSourceProxy, vtkSMRepresentationProxy, vtkSMMultiplexerSourceProxy, vtkSMCompoundSourceProxy, vtkSMTimeKeeperProxy, vtkSMSettingsProxy, vtkSMComparativeViewProxy, vtkSMContextViewProxy, vtkSMComparativeAnimationCueProxy, vtkSMLiveInsituLinkProxy, vtkSMNewWidgetRepresentationProxy, vtkSMAnimationSceneProxy, vtkSMScalarBarWidgetRepresentationProxy, vtkSMSelfGeneratingSourceProxy, vtkSMImageExtractWriterProxy, vtkSMOrthographicSliceViewProxy, vtkSMBoxRepresentationProxy, vtkSMPlotMatrixViewProxy, vtkSMLightProxy, vtkSMSpreadSheetViewProxy, vtkSMTextWidgetRepresentationProxy, and vtkSMNullProxy.
Cleanup code.
Remove all observers from all properties assigned to this proxy. Called before deleting properties. This also removes observers on subproxies.
Here is a brief explanation of how modified flags are used:
The reason why the modified flag is stored in the proxy instead of property is in item 2 above. If multiple proxies were sharing the same property, the first one would reset the modified flag in UpdateVTKObjects() and then others would not call AppendCommandToStream() in their turn. Therefore, each proxy has to keep track of all properties it updated. This is done by adding observers to the properties. When a property is modified, it invokes all observers and the observers set the appropriate flags in the proxies. Changes the modified flag of a property. Used by the observers
Reimplemented in vtkSMPVRepresentationProxy, vtkSMSettingsProxy, vtkSMChartRepresentationProxy, vtkSMSpreadSheetRepresentationProxy, and vtkSMEnsembleDataReaderProxy.
Add a sub-proxy.
If the overrideOK flag is set, then no warning is printed when a new subproxy replaces a preexisting one.
Remove a sub-proxy.
Returns 0 if sub-proxy does not exist.
Returns 0 is the sub-proxy does not exist.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Subclasses overwrite this method to add necessary functionality.
using_cache is set to true when the pipeline update was requested but skipped because the result was previously generated. This happens when using playing animations with cache enabled.
Reimplemented in vtkSMSourceProxy, and vtkSMRepresentationProxy.
If a proxy is deprecated, prints a warning.
protectedvirtual |
vtkSMSourceProxy overrides this method (makes it public) and updates the pipeline information.
Reimplemented in vtkSMSourceProxy.
This can handle <PropertyGroup/> elements defined in both regular Proxy section or when exposing properties from sub-proxies.
protectedvirtual |
Reimplemented in vtkSMPVRepresentationProxy, vtkSMViewProxy, vtkSMSourceProxy, vtkSMCompoundSourceProxy, vtkSMContextViewProxy, vtkSMSettingsProxy, vtkSMWriterProxy, vtkSMExporterProxy, vtkSMGL2PSExporterProxy, and vtkSMChartRepresentationProxy.
The property with the name "property_name" on the subproxy with the name "subproxy_name" is exposed with the name "exposed_name". If the overrideOK flag is set, then no warning is printed when a new exposed property replaces a preexisting one.
protectedvirtual |
protectedvirtual |
Reimplemented in vtkSMMultiplexerSourceProxy.
protectedvirtual |
It is assured that the property passed in as an argument is a self property. Both the overloads of UpdatePropertyInformation() call this method, so subclass can override this method to perform special tasks.
Since it tracks all the properties by index, if there's a potential for the properties order to have changed, then this method must be called after the changes have happened so that vtkSMProxy can rebuild this->State. Currently, this is only relevant for vtkSMSelfGeneratingSourceProxy and similar that add new properties at run time.
protectedvirtual |
protectedvirtual |
protectedvirtual |
protecteddelete |
friend |
Each of these classes use a small subset of protected methods. This should be kept as such.
Definition at line 682 of file vtkSMProxy.h.
friend |
Definition at line 683 of file vtkSMProxy.h.
friend |
Definition at line 684 of file vtkSMProxy.h.
friend |
Definition at line 685 of file vtkSMProxy.h.
friend |
Definition at line 686 of file vtkSMProxy.h.
friend |
Definition at line 687 of file vtkSMProxy.h.
friend |
Definition at line 688 of file vtkSMProxy.h.
friend |
Definition at line 689 of file vtkSMProxy.h.
friend |
Definition at line 690 of file vtkSMProxy.h.
friend |
Definition at line 691 of file vtkSMProxy.h.
friend |
Definition at line 692 of file vtkSMProxy.h.
friend |
Definition at line 693 of file vtkSMProxy.h.
friend |
Definition at line 694 of file vtkSMProxy.h.
friend |
Definition at line 695 of file vtkSMProxy.h.
friend |
Definition at line 696 of file vtkSMProxy.h.
friend |
Definition at line 697 of file vtkSMProxy.h.
friend |
Definition at line 698 of file vtkSMProxy.h.
friend |
Definition at line 699 of file vtkSMProxy.h.
friend |
Definition at line 700 of file vtkSMProxy.h.
friend |
Definition at line 701 of file vtkSMProxy.h.
friend |
Definition at line 1014 of file vtkSMProxy.h.
Definition at line 872 of file vtkSMProxy.h.
Definition at line 956 of file vtkSMProxy.h.
Definition at line 960 of file vtkSMProxy.h.
Definition at line 961 of file vtkSMProxy.h.
Definition at line 962 of file vtkSMProxy.h.
Definition at line 963 of file vtkSMProxy.h.
Definition at line 964 of file vtkSMProxy.h.
Definition at line 965 of file vtkSMProxy.h.
Definition at line 966 of file vtkSMProxy.h.
Definition at line 967 of file vtkSMProxy.h.
Avoids calls to UpdateVTKObjects in UpdateVTKObjects.
UpdateVTKObjects call it self recursively until no properties are modified.
Definition at line 974 of file vtkSMProxy.h.
Flag used to help speed up UpdateVTKObjects and ArePropertiesModified calls.
Definition at line 980 of file vtkSMProxy.h.
Definition at line 991 of file vtkSMProxy.h.
Definition at line 993 of file vtkSMProxy.h.
Definition at line 994 of file vtkSMProxy.h.
Definition at line 995 of file vtkSMProxy.h.
Definition at line 998 of file vtkSMProxy.h.
Definition at line 1001 of file vtkSMProxy.h.
Definition at line 1003 of file vtkSMProxy.h.
Definition at line 1006 of file vtkSMProxy.h.
Definition at line 1007 of file vtkSMProxy.h.
