| void | Update () override |
| | Updates the data pipelines for all visible representations. More...
| void | GetViews (vtkCollection *collection) |
| | Get all the internal views. More...
| vtkSMViewProxy * | GetRootView () |
| | Returns the root view proxy. More...
| void | MarkDirty (vtkSMProxy *modifiedProxy) override |
| const char * | GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override |
| | Overridden to forward the call to the internal root view proxy. More...
| vtkRenderWindow * | GetRenderWindow () override |
| | Returns the render-window used by the root view, if any. More...
| vtkRenderWindowInteractor * | GetInteractor () override |
| | Returns the interactor. More...
| void | SetupInteractor (vtkRenderWindowInteractor *iren) override |
| | To avoid misuse of this method for comparative views, this method will raise an error. More...
| bool | MakeRenderWindowInteractor (bool quiet=false) override |
| | Overridden to call MakeRenderWindowInteractor() on each of the internal views. More...
| virtual void | StillRender () |
| | Renders the view using full resolution. More...
| virtual void | InteractiveRender () |
| | Renders the view using lower resolution is possible. More...
| virtual bool | CanDisplayData (vtkSMSourceProxy *producer, int outputPort) |
| | Returns true if the view can display the data produced by the producer's port. More...
| virtual vtkSMRepresentationProxy * | CreateDefaultRepresentation (vtkSMProxy *, int) |
| | Create a default representation for the given source proxy. More...
| virtual vtkSMRepresentationProxy * | FindRepresentation (vtkSMSourceProxy *producer, int outputPort) |
| | Finds the representation proxy showing the data produced by the provided producer, if any. More...
| vtkView * | GetClientSideView () |
| | Returns the client-side vtkView, if any. More...
| int | WriteImage (const char *filename, const char *writerName, int magnification=1) |
| | Saves a screenshot of the view to disk. More...
| int | WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY) |
| virtual bool | HasDirtyRepresentation () |
| | Return true any internal representation is dirty. More...
| virtual void | SetEnable (bool) |
| | Enable/Disable a view. More...
| virtual bool | GetEnable () |
| virtual void | EnableOn () |
| virtual void | EnableOff () |
| vtkImageData * | CaptureWindow (int magnification) |
| | Captures a image from this view. More...
| vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
| virtual bool | GetNeedsUpdate () |
| | Returns true if the subsequent call to Update() will result in an actual update. More...
| virtual bool | HideOtherRepresentationsIfNeeded (vtkSMProxy *repr) |
| | Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
| virtual void | RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) |
| | Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMComparativeViewProxy () |
| | ~vtkSMComparativeViewProxy () override |
| vtkImageData * | CaptureWindowInternal (int magX, int magY) override |
| | Overridden to do the capturing of images from each of the internal views and then stitching them together. More...
| void | InvokeConfigureEvent () |
| void | CreateVTKObjects () override |
| | vtkSMViewProxy () |
| | ~vtkSMViewProxy () override |
| virtual void | RenderForImageCapture () |
| | This method is called whenever the view wants to render to during image capture. More...
| virtual vtkTypeUInt32 | PreRender (bool vtkNotUsed(interactive)) |
| | This method is called before executing code that could cause a render on the underlying vtkPVView. More...
| virtual void | PostRender (bool vtkNotUsed(interactive)) |
| virtual bool | IsContextReadyForRendering () |
| | Subclasses should override this method and return false if the rendering context is not ready for rendering at this moment. More...
| | Called at the end of CreateVTKObjects(). More...
| int | ReadXMLAttributes (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override |
| bool | GetLocalProcessSupportsInteraction () |
| | Convenience method to call vtkPVView::SafeDownCast(this->GetClientSideObject())->GetLocalProcessSupportsInteraction();. More...
| virtual vtkSMDataDeliveryManagerProxy * | GetDeliveryManager () |
| | Provides access to the delivery manager proxy, if any. More...
| virtual void | SetDefaultRepresentationName (const char *) |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
