superclass for all SM properties More...
#include <vtkSMProperty.h>
| int | IsInDomains () |
| Returns true if all values are in all domains, false otherwise. More... | |
| int | IsInDomains (vtkSMDomain **domain) |
| Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More... | |
| void | UnRegister (vtkObjectBase *obj) override |
| Overloaded to break the reference loop caused by the internal domain iterator. More... | |
| vtkSMDomainIterator * | NewDomainIterator () |
| Creates, initializes and returns a new domain iterator. More... | |
| vtkSMDomain * | GetDomain (const char *name) |
| Returns a domain give a name. More... | |
| vtkSMDomain * | FindDomain (const char *classname) |
| Returns the first domain which is of the specified type. More... | |
| template<class DomainType > | |
| DomainType * | FindDomain () |
| Same as FindDomain(classname), except the classname is deduced from the type. More... | |
| unsigned int | GetNumberOfDomains () |
| Returns the number of domains this property has. More... | |
| void | AddDomain (const char *name, vtkSMDomain *dom) |
| Properties can have one or more domains. More... | |
| virtual void | AddLinkedProperty (vtkSMProperty *targetProperty) |
| Add a link to a property whose value should be synchronized with this property value. More... | |
| virtual void | RemoveLinkedProperty (vtkSMProperty *targetProperty) |
| Remove a link to a property added with AddLinkedProperty() More... | |
| virtual void | RemoveFromSourceLink () |
| Remove a link from the source property. More... | |
| virtual void | Copy (vtkSMProperty *src) |
| Copy all property values. More... | |
| void | ResetToDefault () |
| Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More... | |
| virtual void | ResetToXMLDefaults () |
| For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More... | |
| virtual bool | ResetToDomainDefaults (bool use_unchecked_values=false) |
| Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More... | |
| vtkSMProxy * | GetParent () |
| Get the proxy to which this property belongs. More... | |
| virtual bool | IsStateIgnored () |
| virtual bool | IsValueDefault () |
| Returns true if the property's value is different from the default value. More... | |
| bool | HasDomainsWithRequiredProperties () |
| Returns true if the property has a domain with required properties. More... | |
| virtual void | ClearUncheckedElements () |
| Use this method to clear unchecked values set of this property. More... | |
| virtual void | SetImmediateUpdate (int) |
| If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More... | |
| virtual int | GetImmediateUpdate () |
| virtual int | GetInformationOnly () |
| virtual int | GetIgnoreSynchronization () |
| If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More... | |
| virtual vtkSMProperty * | GetInformationProperty () |
| Get the associated information property. More... | |
| virtual void | SetAnimateable (int) |
| Get/Set if the property is animateable. More... | |
| virtual int | GetAnimateable () |
| virtual void | SetIsInternal (int) |
| Get/Set if the property is internal to server manager. More... | |
| virtual int | GetIsInternal () |
| virtual void | SetNoCustomDefault (int) |
| Sets whether the property should ignore custom default settings. More... | |
| virtual int | GetNoCustomDefault () |
| Gets whether the property should ignore custom default settings. More... | |
| virtual void | SetPanelVisibility (const char *) |
| Sets the panel visibility for the property. More... | |
| virtual char * | GetPanelVisibility () |
| Returns the panel visibility for the property. More... | |
| virtual void | SetPanelVisibilityDefaultForRepresentation (const char *) |
Sets the panel visibility to default if the current representation type matches representation. More... | |
| virtual char * | GetPanelVisibilityDefaultForRepresentation () |
| Returns which representation type the property will be shown by default for. More... | |
| virtual void | SetPanelWidget (const char *) |
| Sets the name of the custom panel widget to use for the property. More... | |
| virtual char * | GetPanelWidget () |
| Returns name of the panel widget for the property. More... | |
| virtual void | SetDisableSubTrace (const char *) |
| Sets the tracing of sub property of this property. More... | |
| virtual char * | GetDisableSubTrace () |
| Returns the tracing state of the properties of this property. More... | |
| The label assigned by the xml parser. More... | |
| virtual int | GetRepeatable () |
The server manager configuration XML may define <Hints/> element for a property. More... | |
| void | Modified () override |
| Overridden to support blocking of modified events. More... | |
| static vtkSMProperty * | New () |
| static vtkSMProperty * | SafeDownCast (vtkObject *o) |
| static const char * | CreateNewPrettyLabel (const char *name) |
| Given the string, this method will create and set a well-formated string as XMLLabel and returns it. More... | |
| vtkSMProperty () | |
| ~vtkSMProperty () override | |
| virtual void | WriteTo (vtkSMMessage *msg) |
| Let the property write its content into the stream. More... | |
| virtual void | ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *) |
| Let the property read and set its content from the stream. More... | |
| virtual int | ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) |
| virtual void | UpdateAllInputs () |
| Update all proxies referred by this property (if any). More... | |
| Internal. More... | |
| void | AddDependent (vtkSMDomain *dom) |
| void | RemoveAllDependents () |
| Removes all dependents. More... | |
| void | UpdateDomains () |
| Calls Update() on all domains contained by the property as well as all dependent domains. More... | |
| virtual void | SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1) |
| Save the property state in XML. More... | |
| virtual void | SaveStateValues (vtkPVXMLElement *propertyElement) |
| This method must be overridden by concrete class in order to save the real property data. More... | |
| virtual void | SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid) |
| Save property domain. More... | |
| virtual int | LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) |
| Updates state from an XML element. More... | |
| virtual void | SetInformationOnly (int) |
| virtual void | SetIgnoreSynchronization (int) |
| void | SetInformationProperty (vtkSMProperty *ip) |
| void | SetDocumentation (vtkSMDocumentation *) |
| void | SetParent (vtkSMProxy *proxy) |
| virtual void | SetStateIgnored (bool) |
| virtual void | StateIgnoredOn () |
| virtual void | StateIgnoredOff () |
| bool | SetBlockModifiedEvents (bool block) |
| Block/unblock modified events, returns the current state of the block flag. More... | |
| virtual bool | GetPendingModifiedEvents () |
| Returns if any modified evetns are pending. More... | |
| vtkSMObject () | |
Protected Attributes | |
| vtkPVXMLElement * | Hints |
| char * | Command |
| vtkSMPropertyInternals * | PInternals |
| int | ImmediateUpdate |
| int | Animateable |
| int | IsInternal |
| int | NoCustomDefault |
| char * | XMLName |
| char * | XMLLabel |
| char * | PanelVisibility |
| char * | PanelVisibilityDefaultForRepresentation |
| char * | PanelWidget |
| char * | DisableSubTrace |
| vtkSMDomainIterator * | DomainIterator |
| int | InformationOnly |
| int | IgnoreSynchronization |
| vtkSMInformationHelper * | InformationHelper |
| vtkSMProperty * | InformationProperty |
| vtkSMDocumentation * | Documentation |
| int | Repeatable |
| vtkWeakPointer< vtkSMProxy > | Proxy |
| bool | StateIgnored |
| vtkSMPropertyLink * | Links |
Friends | |
| class | vtkSMSessionProxyManager |
| class | vtkSMProxy |
| class | vtkSMSubPropertyIterator |
| class | vtkSMDomainIterator |
| class | vtkSMSourceProxy |
| class | vtkSMDomain |
| class | vtkSMPropertyModificationUndoElement |
Each instance of vtkSMProperty or a sub-class represents a method and associated arguments (if any) of a VTK object stored on one or more client manager or server nodes. It may have a state and can push this state to the vtk object it refers to. vtkSMProperty only supports methods with no arguments. Sub-classes support methods with different arguments types and numbers.
vtkSMProperty is typically meant for pushing its values to a VTK object. However, a property may be marked as an InformationOnly property in which case its values are obtained from the server with the UpdateInformation() call.
Each non-information property can have one or more domains. A domain represents a set of acceptable values the property can have. Domains provide applications mechanisms to extract semantic information from a property.
A property has two kinds of values: regular (or checked) values and unchecked values. Regular values are the ones that are pushed to the VTK object when the property is updated. These are the ones that get saved in state, etc. Unchecked values are provided so that domains can update their conditions without having the change the property's value e.g. if the domain range for the IsoContour property changes based on the value of the ArrayName property which selects the array to contour with, the can set the unchecked value on the ArrayName property to each of the available arrays to determine what the domain would be without having to modify the property and update its VTK object. If a property has no unchecked-values explicitly set, then the "Get" methods that access the unchecked-values should simply return the checked values. If the checked values are changed, the unchecked values are reset to match the checked values.
A property fires the following events:
Properties are typically constructed from ServerManager XML configuration files. Attributes available on a Property XML are as follows:
string: This is the name for the property. This typically ends up being the name used by the Proxy to refer to this property. It must be unique for all properties on a Proxy.string:This is the user-friendly label. Ideally, the label should be same as the name, however traditionally that hasn't been the case.string: This is the name of the method to call on the VTK update for the property.{0,1}: This used to indicate that the command can be called repeatedly to update the VTK object. e.g. for multiple inputs, one must call AddInput(..) repeatedly. It also implies that the number of elements/items in the property can change.{0,1}: When set, it implies that this property is used to obtain values from the VTK object, rather than the default behavior which is to set values on the VTK object.string: Value is the name of the property on the proxy to which this property belongs that can is information_only property corresponding to this. This is useful when the variable that this property sets can be changed by other means besides this property e.g. through interaction. Applications can use this information to update the value of this property to reflect the VTK-side state.{0,1}: When set, the Proxy will attempt to push the value for this property to the VTK object as soon as the property is changed. It is no longer common and should be avoided. It may be deprecated in near future.{0,1}: When set, changes to this property are not captured in undo-redo stacks. Unlike is_internal, the value for this property is saved in state files.{0,1}: When set, changes to this property are not synchronized among client-processes in collaborative mode.{0,1}: When set, the property is treated as internal which implies that it will not be shown in the UI; its value will not be pushed when the proxy is created, nor saved in state files or undo-redo stacks.{0,1}: When set, the property is considered as animatable which the UI can use to build the animation interface.{default,advanced,never}: Indicates to the UI that the widget corresponding to this property should be shown in the default or advanced mode, or never at all.string: provides a hint to the UI to determine which widget to create to edit this property.{0,1}: When set, vtkSMSettings will neither change the value of a property upon creation nor save the property value as a default.{0,1}: When set on a ProxyProperty, the python trace generated by smtrace.py will not contain the properties of the proxy pointed by the proxy property. Definition at line 155 of file vtkSMProperty.h.
| typedef vtkSMObject vtkSMProperty::Superclass |
Definition at line 159 of file vtkSMProperty.h.
Reimplemented in vtkSMProxyProperty, vtkSMStringVectorProperty, vtkSMInputProperty, vtkSMDoubleVectorProperty, vtkSMIdTypeVectorProperty, vtkSMIntVectorProperty, vtkSMDoubleMapProperty, vtkSMVectorProperty, and vtkSMMapProperty.
Reimplemented in vtkSMProxyProperty, vtkSMStringVectorProperty, and vtkSMVectorProperty.
The command name used to set the value on the server object.
For example: SetThetaResolution
Properties that do not have values can be pushed by calling Modified().
| int vtkSMProperty::IsInDomains | ( | ) |
The domains will check the unchecked values (SetUncheckedXXX()) instead of the actual values.
Domains that return vtkSMDomain::NOT_APPLICABLE for vtkSMDomain::IsInDomain are skipped.
| int vtkSMProperty::IsInDomains | ( | vtkSMDomain ** | domain | ) |
domain is set to NULL when all domain checks pass.
| vtkSMDomainIterator* vtkSMProperty::NewDomainIterator | ( | ) |
The user has to delete the iterator.
| vtkSMDomain* vtkSMProperty::GetDomain | ( | const char * | name | ) |
Avoids using this method and use FindDomain instead.
| vtkSMDomain* vtkSMProperty::FindDomain | ( | const char * | classname | ) |
Definition at line 744 of file vtkSMProperty.h.
| unsigned int vtkSMProperty::GetNumberOfDomains | ( | ) |
One can use a domain iterator to access domains then.
Is InformationOnly is set to true, this property is used to get information from server instead of setting values.
This allows applications to have access to both the in and out properties. The information property has to be specified in the xml configuration file.
| void vtkSMProperty::AddDomain | ( | const char * | name, |
| vtkSMDomain * | dom | ||
These are assigned by the proxy manager and can be used to obtain information other than given by the type of the property and its values.
This is a useful way for target properties to unlink themselves from a source property prior to, for instance, the deletion of the target property instance. This method only does any work if this instance was passed as the argument to AddLinkedProperty() on a different property instance at some point. Otherwise, it is a no-op.
Non-animateable properties are shown in the GUI only in advanced mode.
Internal properties are not saved in state and should not be displayed in the user interface.
The value can be one of:
By default, standard properties have "default" visibility, while information_only properties have "never" visibility.
This will copy both checked and unchecked values, if applicable.
Reimplemented in vtkSMDoubleVectorProperty, vtkSMProxyProperty, vtkSMStringVectorProperty, vtkSMIntVectorProperty, vtkSMIdTypeVectorProperty, vtkSMVectorProperty, vtkSMDoubleMapProperty, and vtkSMMapProperty.
Returns the documentation for this proxy.
The return value may be NULL if no documentation is defined in the XML for this property.
| void vtkSMProperty::ResetToDefault | ( | ) |
inlinevirtual |
Default implementation does nothing.
Reimplemented in vtkSMProxyProperty, vtkSMStringVectorProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, vtkSMIdTypeVectorProperty, and vtkSMDoubleMapProperty.
Definition at line 426 of file vtkSMProperty.h.
indicate that it can set a default value and did so. Returns true if any domain can setup a default value for this property. Otherwise false.
vtkSMVectorProperty overrides this method to add support for setting default values using information_property.
In symmetric MPI mode (i.e. when vtkProcessModule::GetSymmetricMPIMode() == true), domains need not have correct values since data information is not collected by doing any reduction in parallel. To avoid setting incorrect values, or worse, different values on different ranks, this method does nothing in the case. Except for vtkSMProxyProperty. For vtkSMProxyProperty, we don't have any domain that is runtime data dependent and hence we let the property reset itself. This ensures that properties with vtkSMProxyListDomain, for example, are initialized correctly.
Reimplemented in vtkSMVectorProperty.
The name assigned by the xml parser.
Used to get the property from a proxy. Note that the name used to obtain a property that is on a subproxy may be different from the XMLName of the property, see the note on ExposedProperties for vtkSMProxy.
If repeatable, a property can have 1 or more values of the same kind.
This ivar is configured when the xml file is read and is mainly useful for information (for example from python).
Hints are metadata associated with the property. The Server Manager does not (and should not) interpret the hints. Hints provide a mechanism to add GUI pertinant information to the server manager XML. Returns the XML element for the hints associated with this property, if any, otherwise returns NULL.
| void vtkSMProperty::SetHints | ( | vtkPVXMLElement * | hints | ) |
inlineoverridevirtual |
Definition at line 491 of file vtkSMProperty.h.
| vtkSMProxy* vtkSMProperty::GetParent | ( | ) |
Note that is this property is belong to a sub-proxy of a proxy, the returned value will indeed be that sub-proxy (and not the outer container proxy).
inlinevirtual |
Definition at line 514 of file vtkSMProperty.h.
inlinevirtual |
Reimplemented in vtkSMStringVectorProperty, vtkSMProxyProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, and vtkSMMapProperty.
Definition at line 521 of file vtkSMProperty.h.
| bool vtkSMProperty::HasDomainsWithRequiredProperties | ( | ) |
This typically indicates that the property has a domain whose values change at runtime based on input dataset or file being processed.
inlinevirtual |
Reimplemented in vtkSMStringVectorProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, vtkSMIdTypeVectorProperty, vtkSMProxyProperty, and vtkSMVectorProperty.
Definition at line 533 of file vtkSMProperty.h.
Need to be deleted after use.
protectedvirtual |
Reimplemented in vtkSMStringVectorProperty, vtkSMProxyProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, vtkSMIdTypeVectorProperty, and vtkSMDoubleMapProperty.
inlineprotectedvirtual |
Definition at line 561 of file vtkSMProperty.h.
protectedvirtual |
Reimplemented in vtkSMProxyProperty, vtkSMStringVectorProperty, vtkSMDoubleVectorProperty, vtkSMIntVectorProperty, vtkSMIdTypeVectorProperty, vtkSMVectorProperty, vtkSMDoubleMapProperty, vtkSMInputProperty, and vtkSMMapProperty.
Overwritten by vtkSMProxyProperty and sub-classes.
Reimplemented in vtkSMProxyProperty.
Definition at line 573 of file vtkSMProperty.h.
protectedvirtual |
Internal.
Used during XML parsing to get a property with given name. Used by the domains when setting required properties.
Internal.
Used by the domains that require this property. They add themselves as dependents.
This is automatically called after SetUncheckedXXX() to tell all dependent domains to update themselves according to the new value. Note that when calling Update() on domains contained by this property, a NULL is passed as the argument. This is because the domain does not really "depend" on the property. When calling Update() on dependent domains, the property passes itself as the argument.
protectedvirtual |
This method create the property definition and rely on SaveStateValues to fill this definition with the concrete property values
protectedvirtual |
Reimplemented in vtkSMStringVectorProperty, vtkSMIntVectorProperty, vtkSMDoubleVectorProperty, vtkSMProxyProperty, vtkSMIdTypeVectorProperty, and vtkSMDoubleMapProperty.
protectedvirtual |
protectedvirtual |
Returns 0 on failure.
Reimplemented in vtkSMProxyProperty, vtkSMStringVectorProperty, vtkSMIntVectorProperty, vtkSMDoubleVectorProperty, vtkSMIdTypeVectorProperty, vtkSMDoubleMapProperty, and vtkSMMapProperty.
protectedvirtual |
protectedvirtual |
protectedvirtual |
inlineprotected |
Definition at line 680 of file vtkSMProperty.h.
protectedvirtual |
This gets cleared when Modified() is called.
protectedvirtual |
protectedvirtual |
protectedvirtual |
friend |
Definition at line 545 of file vtkSMProperty.h.
friend |
Definition at line 546 of file vtkSMProperty.h.
friend |
Definition at line 547 of file vtkSMProperty.h.
friend |
Definition at line 548 of file vtkSMProperty.h.
friend |
Definition at line 549 of file vtkSMProperty.h.
friend |
Definition at line 550 of file vtkSMProperty.h.
friend |
Definition at line 551 of file vtkSMProperty.h.
Definition at line 638 of file vtkSMProperty.h.
Definition at line 640 of file vtkSMProperty.h.
Definition at line 642 of file vtkSMProperty.h.
Definition at line 644 of file vtkSMProperty.h.
Definition at line 645 of file vtkSMProperty.h.
Definition at line 646 of file vtkSMProperty.h.
Definition at line 647 of file vtkSMProperty.h.
Definition at line 649 of file vtkSMProperty.h.
Definition at line 650 of file vtkSMProperty.h.
Definition at line 651 of file vtkSMProperty.h.
Definition at line 654 of file vtkSMProperty.h.
Definition at line 655 of file vtkSMProperty.h.
Definition at line 656 of file vtkSMProperty.h.
Definition at line 658 of file vtkSMProperty.h.
Definition at line 660 of file vtkSMProperty.h.
Definition at line 663 of file vtkSMProperty.h.
Definition at line 666 of file vtkSMProperty.h.
Definition at line 669 of file vtkSMProperty.h.
Definition at line 671 of file vtkSMProperty.h.
Definition at line 674 of file vtkSMProperty.h.
Definition at line 699 of file vtkSMProperty.h.
Definition at line 703 of file vtkSMProperty.h.
Definition at line 705 of file vtkSMProperty.h.
