| bool | SaveExtracts () |
| | Generates extracts. More...
| bool | GetIsSubProxy () |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| | vtkSMSaveAnimationExtractsProxy () |
| | ~vtkSMSaveAnimationExtractsProxy () |
| | vtkSMProxy () |
| | ~vtkSMProxy () override |
| | Cleanup code. More...
| | Add a sub-proxy. More...
| | vtkSMRemoteObject () |
| | Destructor. More...
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
generate extracts using animation scene
vtkSMSaveAnimationExtractsProxy is used to generate extracts by using the animation scene to drive the pipeline updates. Essentially, this will play through the animation scene associated with the session for this proxy and for each frame in the animation, generate extracts based on the extract generators defined.
As with any other vtkSMProxy and subclass, one does not directly instantiate this class instead use vtkSMSessionProxyManager::NewProxy. One definition for this proxy is under proxy-group "misc" and proxy-name "SaveAnimationExtracts".
Definition at line 37 of file vtkSMSaveAnimationExtractsProxy.h.
