| void | InitGarbageCollector (vtkSMSession *, vtkUndoStack *) |
| | By initializing the garabage collector the stored state get removed once their is no more chance for them to be reused inside the session. More...
| virtual bool | FindState (vtkTypeUInt32 globalID, vtkSMMessage *stateToFill, bool useParent=true) |
| | Fill the provided State message with the state found inside the current locator or one of its parent. More...
| virtual void | RegisterState (const vtkSMMessage *state) |
| | Register the given state in the current locator. More...
| virtual void | UnRegisterState (vtkTypeUInt32 globalID, bool force) |
| | Remove a state for a given proxy inside the local locator. More...
| virtual void | UnRegisterAllStates (bool force) |
| | Remove all the registered states if force is true, it will also remove it from its hierarchical parents. More...
| virtual bool | IsStateLocal (vtkTypeUInt32 globalID) |
| | Return true if the given state can be found locally whitout the help of on the hierarchical parent. More...
| virtual bool | IsStateAvailable (vtkTypeUInt32 globalID) |
| | Return true if the given state do exist in the locator hierarchy. More...
| virtual void | RegisterFullState (vtkSMProxy *proxy) |
| | Register the given proxy state as well as all its sub-proxy state so if that proxy need to be renew all its sub-proxy will be renew in the exact same state. More...
| virtual void | SetParentLocator (vtkSMStateLocator *) |
| | Set/Get a parent locator to search which is used as a backup location to search from if a given state was not found locally. More...
| virtual vtkSMStateLocator * | GetParentLocator () |
Class used to retrieve a given message state based on its GlobalID.
vtkSMStateLocator allow a hierarchical way of finding a message state.
Definition at line 35 of file vtkSMStateLocator.h.
